The most recent versions of IE and Firefox allow the user to zoom in or out on the text only, independently of the graphic content on the page. It looks like Google Chrome, Safari and Opera do not allow for text-only zooms. With these browsers, the user can only zoom in or out on the total content on the page, enlarging or reducing the entire view size, but otherwise keeping text and graphic objects in proper proportion without affecting the layout. In my view Google, Safari and Opera have it right.
My problem is that, even though I take care to try to minimize the potential bad effects that go with a user changing text size only, I still occasionally see some really unwanted effects on my page layout.
A simple solution, if it were available, would be to simply disable the text-only zooming feature on the browsers that offer this capability. Does anyone know of code that might be inserted to the website pages using Dreamweaver CS4. Or, a CSS rule that can be applied?
I know that it's text that's the problem. Another option would be to elminate all text and just insert images with text embedded. I don't consider this a viable option for a number of reasons (more difficult to do, and not SEO friendly). Does anyone have thoughts about using this method?
Help and comments greatly appreciated.
Tom
P.S. I learned just after this post (from another blog) that specifying text sizes in pixels rather than ems may prevent the user from changing size of text only -- or at least, it will minimize the adverse affect on the layout. Is this true???
Definitely untrue. IE6 and earlier versions were flummoxed by text sized in pixels, although no other browser in the universe is. So this would only help you if your entire audience were using one of those browsers. <barf>
Sure they do. With a little effort, anyone can change their default text sizes and other preferences in browsers.
Safari
http://www.downloadatoz.net/download/safari-for-mac/how-to-change-font -size-on-safari_g.html
Opera
http://www.opera.com/support/kb/view/773/
Google Chrome
http://www.google.com/support/forum/p/Chrome/thread?tid=0c19f08937bece 78&hl=en
A simple solution, if it were available, would be to simply disable the text-only zooming feature on the browsers that offer this capability. Does anyone know of code that might be inserted to the website pages using Dreamweaver CS4 to accomplish this? Or, is there a CSS rule that can be applied to do this?
You're asking all the wrong questions. Instead of hijacking people's browsers and sabotaging their preferences (which you can't do anyway) you should be re-examining your design/layout strategy. Evidently, you have some problems at your end that need fixing. But without a link to your test page, it's impossible to make meaningful suggestions.
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
http://alt-web.com/
http://twitter.com/altweb
Hi Nancy,
I stand corrected. I dug a little deeper on these browsers, and the text-only
change capability is there, as you've correctly indicated. It may be a little
harder to find and do on the others, whereas, on IE and Firefox, it's right
there and obvious on the menu bar.
I appreciate that text resizing is designed for accessibility, but wouldn't it
just be better if the only resizing option was for the entire view (i.e., text
plus graphics)? The images would be larger, but as long as the text size
increases, wouldn't that do it? This way, the layout wouldn't be affected. I
know that better layout design will help this, but I've seen few layouts that
aren't adversely changed with too much text resizing.
Tom
but wouldn't it just be better if the only resizing option was for the entire view (i.e., textplus graphics)?
Better for who?
Browsers go through a lot of beta testing with actual users before they arrive on the scene. Obviously you are among the minority if you think all browsers should behave this way. I for one hate Zoom and keep it turned off.
I've seen few layouts that aren't adversely changed with too much text resizing.
Change to appearance is one thing. It comes with the territory. But this should not adversely effect a page's performance or usability. If it does, you need to fix it. ![]()
Nancy O.
http://alt-web.com/
Hi Nancy,
I share your opinions on this.
Since I obviously can't change the way the browsers operate, I'll do my best to
design with the possibility of text resizing in mind. So far, I've been lucky
(with the exception of one page). From now on, in addition to testing in five
browsers while designing the site in Dreamweaver, I'll also test the text zoom
settings on each just to see how much the view is changed. As you say,
performance and usability need to remain in tact.
Thanks again for your help.
Tom
Hi Tom,
Would be interested to hear how you get on with this! I have just designed my first site using templates and it looks fine except when I zoom it all breaks up.
I was thinking surely there must be some code I can insert that will enable all of the parts of the template to stay in the same position regardless of zoom settings? Or is there some code that restricts the size of the editable region regardless? This may be something really obvious in which case, I apologise.
Without seeing your site, it is hard to know if your problem is the same one I have, but I have googled it to death and yours is the closest problem I have found.
Good luck with it!
Kate x
This is often a symptom of having used absolute positioning as a layout method. Without seeing your page and its code, we can only guess why it's breaking up, though. Can you post a link to the page, please?
There is not. The only way to deal with text zoom is to use layout methods that allow the page to accommodate it without breaking apart. Again, we'd need to see your code to know what it is you might have done or not done.
Remember that template editable regions are NOT layout tools - they are content tools. An editable region has no layout properties. If you are seeing the content in an editable region break up, it's because of the code that contains the editable region, not the editable region itself.
So - bottom line as it was with Tom. To help, we need to see the code.
The link is below:
http://www.hargravesmith.com/k9/
Code may be a total mess, I am just picking things up as I go along.
Thanks in advance for any help you can provide :-)
Kate x
Yep. It is.
From the top:
<title>K9 Patrol - Comprehensive canine security throughout Yorkshire.</title>- this means that the title of each child page will not be editable. That's bad from an SEO perspective. Each page should have a keyword-dense, page-specific title.
That's not going to cause your page to render improperly, but it does make the browser get worried.... ![]()
Hi Kate,
I'm far from an expert on troubleshooting code. Perhaps other forum members may
have some good comments to offer.
One useful tip I received recently is to go this URL and enter your website home
page (or any other page where there are problems): http://validator.w3.org/
Tom
Kate:
I've really found the issue on only one page (of 5 sites I've designed so far).
I probably didn't have the problem with the other sites by shear luck. Anyway,
now I test not only viewing at standard zoom in 5 browsers when I design the
sites in Dreamweaver -- I also check text zooming only.
I fixed my one-page problem by eliminating a right-floated image in a container
that had two right-floated images. I converted the section with the second image
to a table and the images now stay put no matter what the text size. The first
right-floated image doesn't move, so I think I'm fine.
I think that in the future, for navigation menus, rather than using simple text
links (which are subject to resizing), I'll use a Spry menu or a canned flash
extension (like f-Source). Also, if I feel a bit of text is necessary and really
critical to retain size, I'll insert that as a .png image (with suitable
Alt-text, of course).
I'm not an expert by any means, and I'm sure other users on this form will have
a lot more to contribute. Hope this helps.
Tom
VERY BAD DECISION!
A Spry menu will be just as sensitive to text size as a regular one. And a Flash menu is just BAD BAD BAD. You eliminate the site for those who don't have the Flash plugin, or for those who are using screen assistive devices, or for those using iPhones/iPads.
"Recognizing that your HTML skills may not allow this, I'm afraid that the effort to 'fix' this page may not be within your grasp either."
Not sure how to respond to that comment!! Obviously I had a problem or I wouldn't have asked for help however I didn't realise I had attached my CV to the post.... I have every faith in my ability to learn the skills, and apply the effort, required.
Historically, I used to handcode in notepad. It took me a long while to relinquish complete control though, and I have only just started using templates and dreamweaver to enable me to create sites more quickly and in a more visual way. I had figured that dreamweaver, being an industry standard web tool, would include basics (like including a default doctype when I select 'new'!) and have an element of 'damage limitation'.
1, 2 (and 3 or not as per 4). No problem to fix these at all - I may even ask my child to do it for me ;-)
5. Oh. Can't have a worried browser can we? ;-)
6. I am not aware of image ready and haven't allowed any graphics editor to write any of my html...? I use a mix of using dreamweaver in design mode and code mode. Could this explain the mish mash you mentioned..? Maybe I should just stick to code in future.... again, I didn't think that it would be a major problem given that both options are available simultaneously.
And then we get to, hurrah, point 7. A starting point to fix my problem! I shall check out the site you mentioned.
Thanks for the help.
Kate x
Your code tells a different story, though. ![]()
<!-- ImageReady Slices (k9templatebevelled.jpg) -->
<table width="901" height="853" border="0" align="center" cellpadding="0" cellspacing="0" id="Table_01">
<tr>
<td colspan="16">
<img src="images/headerbar.gif" width="900" height="93" alt=""></td>
<td>
<img src="images/spacer.gif" width="1" height="93" alt=""></td>
</tr>
<tr>
<td rowspan="10">
HTML pages with missing doc types, tables with colspan, rowspan and spacer.gifs throughout are all signs that Photoshop was used to generate code on the page.
You are correct about one thing. When you open a new HTML page from DW, it does correctly assign a valid document type to the top of the page. My advice is to use Split View so you can see the code and design at the same time.
Nancy O.
http://alt-web.com/
Just a comment about point 6.
I sliced my template in photoshop but have just gone back in and just discovered the option to save in css format.....
When I tested this, the template includes the doctype and has none of the messy tables that the other option had. In future I will be ensuring that the css box is ticked :-)
Thanks for pointing me into a direction from which I could tangent off and inadvertently discover this!!!!
Kate x
Ugh!
For best results, use your graphics app to slice/optimize images ONLY.
Use DW to build your HTML and CSS code.
Taking a Fireworks (or Photoshop) comp to a CSS based layout in DW
Part 1 --
http://www.adobe.com/devnet/fireworks/articles/web_standards_layouts_p t1.html
Part 2 --
http://www.adobe.com/devnet/fireworks/articles/web_standards_layouts_p t2.html
Nancy O.
http://alt-web.com/
Kate:
I'm confused. Could the e-mail addresses have gotten mixed up?
I intended no disrespect. I just want to point out that I'm not an expert in
troubleshooting html problems. I listed what I did on my one problem page to
(hopefully) resolve my problem with text-only sizing. I received an e-mail
earlier about a site link -- this wasn't my website, as I never provided the URL
for my site, nor the code.
I think there's been some kind of mixup here on the forum. Again, I did not
intend to offend you or anyone.
Tom
Kate & Nancy,
I feel like a dummy! I was replying from my e-mail account, thinking that these comments were addressed me (based on the way the message was addressed). I didn't realize you were talking with each other on this issue. That's why the comments about the website, your code and Image Ready didn't make sense to me.
Please excuse my ignorance on this -- I'll send my messages from the Forum for now on, rather than trying to reply from Yahoo e-mail. This way, I'll see the true flow of the posts.
Best regards,
Tom
P.S. Thanks, Murray, as well.
Tom,
Kate sort of chimed into your thread with a question of her own. So you're getting emailed every time someone posts a reply to this discussion on the web forum. If you don't want to receive email notifications, you can turn this option off in your Adobe profile.
Nancy O.
http://alt-web.com/
