Hi there,
I've got a bug that's driving me insane and would love for someone to suggest a solution!
Basically Dreamweaver CS5 has started losing FTP usernames and passwords every time I quit (I'm running Mac OS X latest version)... The other guys in the office get the same on CS4 too.
We think it's a corrupted link between Dreamweaver and Keychain as the passwords are all still there... reimporting the site def does the trick although the details are lost again when I quit.
Any ideas would be awesome... I've submitted a help request to Adobe too but haven't ever heard back from them in the past... fingers crossed as I'm going slowly mad!
Neil
Glad it's not just me... I wonder if they've messed something up during yesterday's update, as another guy in the office just had this yesterday on CS5 for the first time.
Plus I amazingly had a reply back from Adobe saying that trial versions aren't eligible for full support(!) but they pointed to the FTP troubleshooting doc in the help area... not a lot of help there then!!
Hey there - we've been having the same problems and repairing the Mac OS X Keychain files (followed by a restart) did fix and restore all our FTP site settings. This has also been discussed in various other forum posts with mixed reviews or outcomes. But I recommend you try the following:
1. Quit Dreamweaver.
2. Launch Keychain Access App.
3. Select Keychain First Aid (Verify then Repair).
4. Restart your Mac.
Hope this helps.
Frank
Hello,
I got exactly the same problem: my login/password for the FTP are lost averytime I close the application.
I checked the Keychain: no problem found with both Verify and Repair.
I also reboot my computer, pressing the cmd + S button and make a "fsck -f" (that sometime saved me): the volume is OK.
Do you have any idea of what's happening? Is it a way to solve this problem?
Many thanks for your support...
I start Dreamweaver, import all my *.ste files. I can connect the servers, so the FTP login/password are OK. I close the application.
I repair the Keychain, start again Dreamweaver. And it's agin impossible to connect: the login/password are lost...
I got Dreamweaver installed on two machine:
- macbook pro, under snow leopard, with the latest updates
- imac, under snow leopard, with the latest updates
Both computer are installed exactly the same way (even user account, password, etc...). I have this problem only on the macbook: everything is running perfectly with my imac!!!
Any idea or suggestion?
Thanks again....
This was linked to from my posting of a similar problem: http://forums.adobe.com/thread/681538?tstart=0. My problem is with Version Control login information, not FTP.
I followed the suggested solution, but it did not solve the problem for me. After repairing my keychain and restarting my MacBook Pro (OS X 10.6), Dreamweaver didn't have my username and password saved. I entered them, saved, and then restarted Dreamweaver. Still the same thing. ![]()
Same Problem,
Completely clean install of Mac 10.6.4 on my laptop, new HD, 8gig of ram, all updates, repaired permissions, verified and repaired key chain access, several times, restarted. No Luck.
Very Frustrated, I have several sites I have to keep re-entering this information for.
Any Suggestions?
Joe
Joe Scarpetta
Hi there, I did almost the same: uninstall DW, reboot, fsck -fy, reboot, repairing the keychain, install DW, reboot, import *.ste profiles... And the result was exaclty the same! Finally, I just decide the re-import my profiles everytime I start Dreamweaver. And two days later, I started one more time my Dreamweaver, connect directly to one of my profile, without importing it before, and..... I can connect to my server! i tried with the other one: same result, everything is working fine again. And I didnt do anything! If anyone can explain this... I hope Adobe can finally fix the boring trouble, because it seems it came very often on the table, also with previous release... So good luck to you, and thanks for the many tips and tricks given on this forum!
Success! I had two problem sites. I fixed one by reestablishing the site, but that did not work on another. I fixed the other by following the advice above: quitting Dreamweaver, deleting the stored password from the Keychain, repairing the Keychain, restarting Dreamweaver and re-entering the user name and password worked on one site.
All you guys out there with CS3, 4 and 5; it even happens with good "old" Dreamweaver 8. As this is no longer supported I am stuffed regarding a fix.
Have tried deleting the one affected site from Site Manager and then re-creating the cache but login still lost.
Have been using Dreamweaver continuously from Dreamweaver 3 onwards, when part of Macromedia, but got fed up with upgrading with features I didn't use and high cost. I even purchased the Director 7 suite (at the cost of an arm and a leg!).
The keychain repair + restart did nothing here.
I deleted the server information and added the server again with another name.
Then I opened Keychain and sorted the list in date order. My latest instance was from yesterday even tho I just made a change with a password involved.
Then I searched for the keychain instance holding the server information and deleted it.
Back to DW and I once more deleted the server information and added it back.
Then I looked in the Keychain app and there it was – a new instance on top in the date order.
So it looks like the keychain repair may work in some cases but in my case the old instance in the keychain could not be written to for some reason. I am guessing that deleting the keychain instance could be a fix without a need to restart the computer. Repair, delete the particular keychain instance, then addthe server info in DW.
My experience was now with Dreamweaver 5.5.
I have seen this password problem for years and years in Dreamweaver.
I use the Keychain for everything else but never have any other problems.
This is getting embarrasing... sorry, it was getting embarrasing in 2009.. now it's 2011.
Same problem... Dreamweaver CS5 on Lion everything updated and I can't remember the last time that Dreamweaver actually remembered the passwords for any of my sites. I webmaster about 10 sites so you can imagine how much I like this! I just tried the Keychain First Aid, restarted, nothing. Tried it again, nothing. I have SO many problems with Adobe, but this one is a doozy! Adobe, what do you do with all those employees besides protect your serial numbers? It seems that nothing except Photoshop works right anymore. There is no support for the people that do buy the extremely expensive software! What's with the interface on CS5 Dreamweaver? It looks like pre-Windows XP design! And don't get me going about how you undermined my Flash career by never improving a thing on Flash since Macromedia owned it! FIX IT!
I have been having this same issue with my FTP login and password not saving the information and finally had the time to work on solving the problem over the Holidays. The Keychain answer worked but only after I deleted ALL the dreamweaver keychains first. I also had a couple of CS3 keychains stuck in the system.
Thanks for the help! Happy holidays everyone.
Josh
I believe that Mr. Anderson has the correct approach.
I noticed on some of my older sites that I had several keychain files for one site.
I experimented with deleting one of them at a time to see if any were good, but I believe that they all became corrupt. I simply deleted all of the dreamweaver keychain files. (it's not obvious which is a DW keychain file, but it's pretty easy to guess. Some of them say siteserver, and others are just an application password with the sites name on it)
Then I went back and entered the log/pass into the site definition, saved, tested, and launched the remote site.
Quite DW
tested again
they all remained their logins
I tested several times and it worked everytime.
This is a huge PITA ..
I was fine on a new mac, new cs5 install from april 2012 to june 27, 2012 when I ran a dreamweaver update ..
I was left with 47 site definitions with EMPTY user/pwd combos !
THIS DID ABSOLUTELY NOTHING
// THIS DID ABSOLUTELY NOTHING
i had to save the login info manually for all sites, from the keychain logins .. then delete them..
Closed DW, rebooted, opened DW and tried adding a site definition,
connect/disconnect to make sure it worked... .. closed DW .. opened DW ..login INFO MISSING !
What was concerning is that no new logins were appearing in the keychain manager when i would recreate the site definitions.
i even tried creating my own password items in my login keychain, but they would not save 'dreamweaver' when i selected it as an approved application for that password.
3 hours .. i finally uninstalled DW and tried to reinstall it...
got some funky errors about repair items existing but not having been ran.. installation failed
I had to install dreamweaver inside a folder within the Applications folder to finally get it to complete without errors..
at least now it saves my login info .. but I am scared to update DW
We pay hundreds of dollars for this program and expect it to help productivity, not hinder it ..
Fetch, a simple thirty dollar program even has thought far enough ahead to include a toggle option to add to keychain
I guess I am relieved to know it hasn't just happened to me, but based on the amount of time since the first post in even just this thread, I find it quite unacceptable that it is still happening at all.
Adobe ?
-wendy
Ditto with me.
DW cs5.5 was working fine until the latest update.
Now it has cleared my usernames and passwords, along with my 2-monitor workspace.
If I enter the user/pw again and save ftp will work, but upon quit it's back to blank fields.
This IS a PITA.
I haven't tried the Keychain trick, but c'mon Adobe, don't you test this?
os X 10.6.8 btw.
