greetings.
i just recently switched over to a new computer at work and using another designer's workstation w/ cs3. for some reason unknown to me, the "ESC" (escape) key will not work for me when trying to deactivate a text box.
i looked under the keyboard shortcuts menu and found where to input this shortcut (keybord shortcuts/product area: tools/selection tool (highlighted) ...and see the current shortcuts set at "default: v" and "text: escape" so i know it's there.
however, when i try to input a new shortcut and hit the escape key, it's not being recognized at all. same thing happens when trying to set the escape key for any other shortcut.
i'm experiencing the same issue in illustrator, as well.
any thoughts are greatly appreciated.
I wish this issue had been resolved! I'm now experiencing the same issue. When I have InDesign open, the escape key does NOT work. Even if I alt-tab to a different program all together, the escape just doesn't work. Once I close InDesign, the escape key regains its normal functionality in all other programs. In InDesign, If I hold down the windows key and hit the escape key, that DOES work. I checked my keyboard shortcuts and they currently have the default configuration, with the escape key selecting the selection tool while in text mode. I'm using CS3 on Windows 7. I have another machine with CS3 on Windows 7, and its works just fine. Both computers have all windows and adobe updates installed. Please help.
Is this a laptop? I don't have an answer, but I suspect this may be a BIOS or keyboard driver issue rather than an ID or Windows problem. We used to see reports of the Enter keys not working correctly with some laptops because the hardware manufacturers mapped them together, but Esc is a new one.
Actually, it's on my desktop computer. The one that's working is my laptop. It was working previously on the desktop, but I got a new wireless card and had an issue, and had to format my computer and re-install everything. And now the escape key won't work when Adobe In Design is open. Because of this issue with the esc key, I formatted and re-installed again. Initially, immediately upon installing CS3, I didn't have the esc key issue. But as I continued to re-install software and updates the esc key issue developed.
Check this, it is for Photoshop but who knows...http://forums.adobe.com/thread/372523
I just tried formatting and re-installing again so I could track when the problem occured for me. This time, it started from the outset. I also had seen that photoshop esc-key problem thread before and tried the solution suggestions in that thread to no avail. Anybody have any other ideas?
Well, I just figured out what the issue was on my machine. It is my latest Catalyst Control Center Video Driver (10.6) for an ATI 3xxx series on Windows 7. Previously, during testing, I had just closed the catalyst control center in my system tray. But apparently, that doesn't fully shut down the program. I did a ctrl+alt+del to get to the task manager, and closed down CCC.exe in processes. Now, the issue is gone. So now I just need to figure out how to prevent ccc.exe from running ever again.
Any ideas?
Ps CS4 11.0.2 (64-bit)
Windows 7 Pro SP1
Apologies for bumping this oldie. Escape key is completely dead in and outside of Ps.
The weird thing is that it can only be reproduced by opening Ps (with or without a file) while CCC.exe is running (AMD VISION Engine Control Center).
So one would be inclined to blame Ps.
Adobe staff and users carrying a tarred and feathered ATI driver writer, out of town on a train rail :
The problem returned with the following AMD/ATI driver :
[QUOTE]Driver Packaging Version 8.872-110707b-122569C-ATI
Catalyst Version 11.7
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1171
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-1 1CE-BFC1-08002BE10318}/0000
Direct3D Version 7.14.10.0847
OpenGL Version 6.14.10.10907
AMD VISION Engine Control Center Version 2011.0707.2346.40825
[/QUOTE]
Closing CCC.exe in the Windows task manager, then restarting Ps cured it.
