ColeLundstrom
Outline Fonts from PDF
Jul 15, 2010 12:53 PM
When I view a PDF file within Adobe Reader the finished artwork can be viewed in its entirety.  However, when I open the PDF in AI if the customer did not outline his fonts or provide me with a TTF I am unable to open and adjust the originally intended Artwork.  How can I open the file in AI so that it matches the view Reader provides?  I Feel like it is possible since the information is obviously somewhere in the file.
    Jul 15, 2010 1:57 PM   in reply to ColeLundstrom
    You need Acrobat so you can use the Transparency Flattener tools which allows you to outline the text.
    Jul 16, 2010 6:14 AM   in reply to ColeLundstrom
    Workaround:
    Link place the file into a blank Illustrator document.
    Select the link, Object>flatten transparency with the convert text to outlines checked.
    Variation: Copy the outlined text out using the above method
    Open the original pdf in Illustrator (fonts will default)
    Delete text and paste in place the outlined text.
    Pro: Retains transparency
    Con: Both variants yield outlined text
    Jul 16, 2010 9:42 AM   in reply to John Kallios
    Hi John. Long time no see.
    Jul 16, 2010 12:37 PM   in reply to John Kallios
    Hi John,
    Very pleased to see you here agin.
    Welcome back.
