This discussion is archived
New Nikon D3 and D700 "Camera" v2 beta profiles
Mar 23, 2010 12:23 PM
  Latest reply: Noel Carboni, Nov 12, 2011 5:33 PM
Replies 1 2 3 Previous Next
    Jul 6, 2010 6:56 AM   in reply to MadManChan2000
    Is there an estimate for when the final profiles will be out?
    What happens if I then remove those beta profiles? Will LR fall back to the official profiles or will it not find any profile?
    Thomas
    Jul 12, 2010 8:26 AM   in reply to MadManChan2000
    Am I assuming (hoping) correctly that the upgrade installation of Lightroom 3 doesn't update these camera profiles? I've been noticing a lot of posterizing as well as magenta and green colour artifacts in neutral tones since upgrading to my D700. I'm really hoping that updating my profiles when I get home will fix things.
    Sep 2, 2010 3:36 PM   in reply to MadManChan2000
    LR 3.2 final - any news? Is there an estimated release date for the final profiles?
    Thomas
    Sep 3, 2010 8:30 AM   in reply to MadManChan2000
    Any word on when these will be out of beta?  Will they be replacing the D3 and D700 profiles that are currently included in the Camera Raw 6.2 and LR 3.2 releases or are they going to be added as permanent alternate profiles alongside the current "V1" versions?
    I tried searching Adobe Labs for updated information and can't even find any references to the beta profiles ... is there any place to keep tabs on their status?  It's been a long time since the betas came out.
    SJH
    Oct 11, 2010 9:11 AM   in reply to Michael Perlov
    Will a D3 fit into this Pelican camera case?
    http://www.pelicanonline-ralphs.com/1200-case.htm
    Oct 25, 2010 11:40 AM   in reply to MadManChan2000
    I'm also wondering if there any sort of ETA on the final versions of these profiles; it's basically been a half year since the V2 beta. Seems like sort of an indefinite project right now?
    Nov 8, 2010 10:53 PM   in reply to MadManChan2000
    I may be doing something wrong, but I'm getting drastically different results when I open an NEF file in Capture NX2 versus Lightroom 3 (using both the boxed camera profiles and these beta v2 profiles) from images shot on a D700.
    In NX2, I ensured that I was using the "Standard" profile, and in the case of LR3, "Camera Standard v2".
    Here are the two different results:
    NX2
    http://brucebracken.com/photography/v/pptest/1a.jpg.html
    LR3
    http://brucebracken.com/photography/v/pptest/1b.jpg.html
    The LR3 image looks much more color saturated, among other things, but from what I remember, the NX2 image was much closer to how the scene looked when I was doing the shooting.
    Can someone help me understand why LR3 produces such a different default image from the NEF file than NX2?
    Thanks in advance!
    Nov 9, 2010 2:35 AM   in reply to Geronimosan
    There were many posts about this in the past. So I took a look into Adobe's profiles for D700 (original and beta v2). I have some experience with this, because I made my own program for making dng profiles for some Canon cameras, that are not supported by Adobe. I noticed several things:
    First, in the lookup table of both versions of the profile, values for Value segment 0 (= total black) are a simple copy of segment 1 (=dark midtones). My opinion is that this approach is a bit oversimplified, resulting with big differences in dark tones between ACR and NX (oversaturated blue and orange/brown on your picture). Midtones and highlights are much better
    Obviously, points for total black can't be calibrated at all. What I did in my program was that I made calibration on very dark tones, and did some recalculation to aproximatelly match camera jpegs. It's not possible to get total match, but I came much closer
    Second, there is a difference in tone curve between original D700 profile and beta v2. Tone curve in the original profile has a "notch" in the lowest part, caused by the fact that blacks slider default value should be 5 (according to Adobe). On the beta v2 profile, bottom part of the tone curve is smooth and looks similar to what I got on my profiles with blacks slider set to 0. So I suppose that for this profile (and some other latest profiles), blacks should be set to 0.
    It would be nice to get some comment about this from Eric or Jeff
    I attached a printscreen from my program that can display a lookup table in the profile, and this is how Hue segment 0 (= red) looks like.
    On the left pane, there are value and saturation remapping points (in Photo Pro color space), and on the right, there are hue shifts
    Also, there is a tone curve on the left pane (displayed in 3 different scales)
    Nov 9, 2010 9:38 PM   in reply to MadManChan2000
    It was set at the default "Nikon sRGB". Changing it to use the normal sRGB override resulted in pretty much the same image. using the "Adobe RGB" override also produces about the same image.
    Nov 9, 2010 10:57 PM   in reply to Geronimosan
    I'm not familiar with Nikon software, but in the case of Canon, there can also be some differences between sRGB and AdobeRGB. Canon has separate profiles for these color spaces and a kind of perceptual rendering is used. In ACR, there is only one profile for both color spaces. So in case you choose Adobe RGB, you will get aproximation of Canon's perceptual profile, bacause calibration is made on this one I presume, bacause it has bigger gamut. If you choose sRGB, out of gamut colors will be simply clamped into sRGB, instead of compressing into range, which would be done by the camera or DPP software
    Nov 10, 2010 1:16 AM   in reply to Geronimosan
    Hello,
    I don't know how things work technically in these two converters, but, from my experience with D700 camera which I own, NX almost completely desaturate dark tones, probably to mask shadow color noise or I don't know why but... I had really hard time to get any saturation for example in people faces when I do shooting in backlight situation, using flash fill, but flash was not enough powerful so it left them relatively dark. These areas in NX are simply gray, no matter what I do to boost saturation there. This looks like "feature" from NX, but I don't really like it, and ACR does much better job for these dark areas - at least for my eyes if not technically.
    Nov 10, 2010 2:11 AM   in reply to coldplug
    Canon compacts behave exactly the same way - very dark tones on in-camera jpegs are desaturated or completely gray, for the reason you mentioned. It's usually ok for the photo as is, but if you try to brighten it, in case it's too dark, you get strange results. Fortunately, my 400D doesn't seem to have this 'feature'
    So, it's quiestionable whether Adobe camera profiles should precisely copy shadow parts of the camera profile (or other similar features) or do it in more acceptable way. But it was stated by Adobe that intention was to copy the profile as is, no mater how good or bad it is, because that's what people asked for,  which turns out not to be the case here
    Nov 11, 2010 5:23 AM   in reply to MadManChan2000
    Can you comment the difference between the tone curve of original Camera standard profile and v2 profile (I attached similar diagram for v2 profile below). On original profile, tone curve has a "step" on the beginning (visible on middle curve - the brown one), while v2 profile tone curve doesn't. This "step" is compensation for Blacks=5. So, is v2 profile supposed to be used with Blacks=0, or there is some other reason
    It's also evident that lookup table is different (especially hue shifts in this Hue segment = 0) , but this is because table in v2 profile maps from raw color space to PhotoPro, while in original profile it just remaps values in PhotoPro color space (I used the same way for CHDK profiles, because it has some advantages we allready discussed before)
    Nov 15, 2010 12:12 AM   in reply to MadManChan2000
    Thanks. I was just courious about the way you calibrated this profile, because I was dealing with similar problematic for my cameras
    I also tried smoothing the bottom part of tone curve when making a profile for 400D, in combination with Blacks=5, but this resulted in deep shadows being darker than on jpeg (like in the case of your v2 profile for D700). After looking at the SDK code and some experimenting, it turned out that Blacks=5 clips bottom part of histogram, and that's why strange bottom part of TC needed. So i decided to use Blacks=0 in my case, which gave accurate result and simplified the calculation
    Any chance of eliminating BaselineExposure (and blacks=5) in the future ? However, I'm aware that baseline exposure isn't fixed for the camera. For instance, it's usually -0.25 on 400D, but could be different in some occasions (longer exposure, usage of flash etc)
    Nov 23, 2010 8:15 AM   in reply to MadManChan2000
    I am a newbie here and just wanna say Hi to everyone. I am Crystal from Louisiana, US.
    __________________
    free photoshop tutorials
    Dec 8, 2010 10:48 AM   in reply to MadManChan2000
    Hi Eric,
    Are you still planning on releasing a finalized version of these profiles? (It'd be nice to get a version with similar-to-Nikon colors, but also without a dramatically steeper tone curve - even if it had to have blacks=0).
    If not I'm wondering if it's possible to just adjust the tone curve of an existing profile (but I'm guessing that the color-matching is probably interdependent on the tone curve).
    Dec 8, 2010 10:59 AM   in reply to photo81
    When you alter tone curve, as implemented in ACR, saturation is also altered, but hue remains constant
    Dec 11, 2010 5:37 AM   in reply to MadManChan2000
    I'd love to see it as well!
    DM
    Jan 6, 2011 1:24 AM   in reply to DHayMil
    __________________
    Dec 13, 2010 6:24 AM   in reply to Crystal Evans
    I tried running the DNG Profile Editor (chart tab) on a D700 image of the ColorChecker using Camera Standard version 2 profile and I get the following error message:
    A fatal runtime error has occurred.
    Description: invalid hue
    Source filename: pe_recipe.cpp
    Source line: 2734
    The DNG Profile Editor works fine with the D700 Camera Standard regular profile.  I only have a problem with version 2 profiles.  Any comments?
    Dec 15, 2010 11:00 AM   in reply to b2martin_a
    Before I tear into this and start the project...can anyone tell
    me if these presets are compatible w/LR v2.4  ??  Thanks
    Dec 29, 2010 5:12 AM   in reply to MadManChan2000
    ManManChan2000, any comment on why the DNG Profile Editor Chart Tab will not run when I select a D700 version 2 profile.  I get an error message as listed in the post above.
    Dec 29, 2010 4:18 PM   in reply to MadManChan2000
    Hi Eric,
    Nice work, i realy like people getting this deep into color.
    My observations:
    A lot better, indeed the burned out highlight are better.But stil i need to export to PS to make the image "pop"
    In dark area's reds and orange are too saturated still. I'd like to sow you samples but i would not put them on public display.
    In these files you can easily see what happens when push he blacks slider up. In dark tones a yellow blanket turns first orange and then red.
    Same happens with faces. Which is still the biggest problem: The over saturated reds in bronzed (older) faces when a bit underexposed.
    Second, i wonder, is it possible to develop an evan better tahn Nikon profile? With real natural colors? Natural greens and yellows for example?
    i know, it's not what was the original request but wouldn't that be an awsome selling point?
    But i remain very thankful for your work.
    Menno
    Dec 30, 2010 12:13 PM   in reply to menno1000
    So, how do you define natural colors ?
    If you for example tako a photo through the window, then display it in ACR or any other similar software and expect that you will see on the monitor exactly the same as through the window in the nature, I'm affraid that's not gonna happen with any profile
    Jan 3, 2011 8:16 AM   in reply to Vit Novak
    Hi Vit,
    You are absolutly right. Natural is hard to define and non existing. On the other hand, unnatural is pretty easy to define. Like if yellow turns orange, blue is too purple. We are all trying to calibrate printers and monitors and i have the feeling that nikon colors could be improved. Maybe one could closer to natural or high end camera's. Or maybe just different, say Canon like..
    I think the new v2 profiles are a lot better in that perspective already. Some odd purple green cast in shadows is now gone.
    I noticed you are into improving the colors, interesting, I owned a 400d as well and liked it. Would share your profiles?
    Menno
    Jan 3, 2011 10:53 PM   in reply to menno1000
    Well, I wouldn't say I wanted to improve colors. I just happened that a group of programmers wrote a software that enabled getting the raw from some Canon compacts. Unfortunately, there were no color specialists among them, so finally I made a software to make camera profiles for them, after I found out that I couldn't come reasonably close with dng profile editor (and also, I didn't have a color checker chart). As a byproduct, I also made a camera standard profile for 400D (with another program), as I wasn't entirely satisfied with the one from Adobe. It is closer to jpeg than the one from Adobe (at least in sRGB space), but to be ownest, on most real life photos, there is no big difference. I will publish it in CHDK forum in a day or two, so check there (I already had intention to do it, but since there was almost nobody interested in profiles for compacts, I didn't do it so far)
    Jan 5, 2011 12:43 AM   in reply to Vit Novak
    Ok,Thanks.
    Menno
  • Pierre Courtejoie
    Jan 11, 2006
    Jan 6, 2011 1:29 AM   in reply to menno1000
    Menno, You can send files using yousendit, or dropbox to Eric by using {his username} at yahoo dot com
    Jan 6, 2011 3:15 AM   in reply to MadManChan2000
    Hi!
    Some months ago I installed the Beta Profiles (D3) on my Mac (OS X 10.6.5).
    Till yesterday I was able to choose the V2 Profiles during the import or later.
    Now they are in LR3 (3.3) not available any more.
    In PS CS4 I can see them.
    I copy the beta profiles to  /Library/Application/Support/Adobe/CameraRaw/CameraProfiles twice without success.
    Does any one know what's the fault?
    greetings,
    safo
    Jan 10, 2011 9:43 AM   in reply to MadManChan2000
    Hi Eric,
    I only use RAW files.
    greetings,
    safo
Actions
Bookmarked By (1)
