DonRonito
Illustrator CS5 shortcuts - don´t work
Jul 15, 2010 12:40 AM
Hi everyone,
after upgrading to CS5 on my work Mac, all of my favourite keyboard shortcuts (which are not custom) seems not to work. Here are the basics functions I´m missing:
cmd+space = ZOOM IN
tab when resizing objects = keeps the aspect ratio/proportions og the object
holding alt then dragging objects = duplicate them
These are very important funtions for me, but they don´t work for some reason. Scaling objects and keeping the same proportions is now a much longer process than I am used to.
Would be glad if someone have a solution to this problem. The shortcuts are not listet in the properties, so I don´t know where to find them either.
Best regards from Norway!
    Community Member
    Jul 15, 2010 6:25 AM
    They are listed through the Edit Menu at the bottomEdit>Keyboard Shortcuts.
    Also you can try this to reset them
    1. Quit Illustrator.
    2.Go to User/username/Library/Preferences/ Adobe illustrator CS4 Settings and trash the settings folder, the whole folder not just the contents of the folder..
    3. Start Illustrator. Illustrator creates a new preferences file.
    Or you might have some software and or haxy install that is in conflict for some Entourage causes this problem for others Quicken.
    Community Member
    Jul 15, 2010 11:37 AM
    Just wanted to chime in and say that I had the same problem for a while. In my case, iTunes was hanging, and once I force quit it, everything was okay in Illustrator. I don't know enough (i.e. anything) about processes to say what was happening, but if several other people have experienced the same issue, it's enough to warrant investigation and, I hope, a fix.
    Community Member
    Jul 15, 2010 11:52 AM
    There are also reports of certain Firefox add-ons that cause this problem.
    Jul 20, 2010 8:09 AM
    hello,
    i've been having the same problem for quite a month and it's been really annoying.
    i was restarting the computer every time it happened, but then i realized that it would only happen when i switch windows between firefox and illustrator.
    so the thing that works for me is: close firefox when your shortcuts stop working.
    adobe should really fix this annoying bud huh?!
    Jul 20, 2010 8:24 AM
    For me, whenever I start Illustrator, my keyboard layout at the OS level is changed from EN (US) to French (Canada), which kills all shortcuts and makes typing text into the text fields pretty tough!  Once I change it back to the EN (US) everything is fine until I close and re-launch Illustrator, when the same thing happens again.
    I'm on Windows XP sp3 with a clean CS5 Web Premium install (no Adobe products were installed prior to CS5 because my computer was re-imaged a week or so prior to receiving CS5).
    Sep 9, 2010 9:39 AM
    For what it's worth, I recently discovered this problem on my computer as well, while running AI 15.0.1 and Firefox 3.6.8. Ceratin key commands just stopped working in Illustrator with no noticable warning. Quiting Firefox corrected the problem immediately. Strange.
    Oct 31, 2010 10:50 AM
    FWIW
    I solved this problem by quiting Safari. I have Firefox, but hardly ever use it. The shortcuts immediately worked again, after quiting Safari, didn't even restart Illustrator CS4. Also noteworthy is that they kept working after restarting Safari. So it's not per se FF.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
