Converting XMLList to ArrayCollection
Nov 13, 2008 2:31 AM
Hi, I have an XML List as follows :
<items name="total">
<item name="value1" percentage="35"/>
<item name="value2" percentage="25"/>
<item name="value3" percentage="47"/>
<item name="value4" percentage="89"/>
</items>
<items name="somesub">
<item name="value1" percentage="15"/>
<item name="value2" percentage="27"/>
<item name="value3" percentage="56"/>
<item name="value4" percentage="43"/>
</items>
and I need to dynamically convert it to an array collection as follows (I'm loading the XML externally and the component only allows for an arrayCollection) :
myArray = new ArrayCollection(
{ name:"total", value1:35, value2:25, value3:47, value4:89},
{ name:"somesub", value1:15, value2:27, value3:56, value4:43}
I'm totally stuck on how to do this so any help putting me in the right direction would be highly appreciated.
    Nov 13, 2008 3:29 AM   in reply to woutek
    Two things come to mind:
    You can set the result type to object and let HTTPService to the heavy lifting of converting XML to Objects for you:
    http://blog.flexexamples.com/2007/09/19/converting-xml-to-objects-usin g-the-flex-httpservice-mxml-tag/
    or you receive data as XML and use SimpleXMLDecoder class to convert it into objects and add them to a ArrayCollection
    ATTA
    Nov 26, 2009 2:32 AM   in reply to woutek
    its been a year since there was any activity on this thread so, is the question answered ?
    if not... you can you an intermediate array and push elements one by one inside it and the convert this array into arraycollection.
    Jul 20, 2010 4:26 PM   in reply to sagisid
    This works partiallly but it keeps all the XML Node names??  AND WHEN USED WITH A DATAGRID SEARCH iT BLOW UP IN FLEX
    so help would still be nice
    myData = new ArrayCollection(mx.utils.ArrayUtil.toArray(xmlStudents));
    I found it on:
    http://www.flexdeveloper.eu/forums/actionscript-3-0/converting-xml-to- arraycollection/
    I ultimately needed it for this code examples:
    HOW TO SEARCH A DATAGRID?
    http://www.flex-blog.com/arraycollection-filter-example/
    Thanks.
    Doug Lubey of Louisiana
    www.douglubey.com
    SEARCH ENGINE REFERENCE:
    flex4 datagrid search filter 2010
    flex4 datagrid search filter columns
    flex4 datagrid example with search filters
    adobe flex4 convert fx:XMLList to arraylist
    flex4 convert XMLList to arraylist
    flashbuilder4 convert xml to arraylist
    flex xml to arraylist
    convert xmllist to arraycollection in flex
    Implicit coercion of a value of type XMLList to an unrelated type mx.collections:ArrayList
    Jul 20, 2010 11:47 PM   in reply to woutek
    Here is the code which converts XMLList to an arraycollection...
    <?xml version="1.0" encoding="utf-8"?>
    <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init();" layout="absolute">
    <mx:Script>
      <![CDATA[
       import mx.collections.ArrayCollection;
       import mx.rpc.xml.SimpleXMLDecoder;
       private var acAllNodes:ArrayCollection;
       private var acOpenNodes:ArrayCollection;
       private function init():void
        convertXmlListToArrayCollection();
       private function convertXmlListToArrayCollection():void
        var strXML:String = dpNodes.toXMLString();
        strXML = "<root>" + strXML + "</root>";
        var xml:XML = new XML(strXML);
        var xmlDoc:XMLDocument = new XMLDocument(xml);
        var decoder:SimpleXMLDecoder = new SimpleXMLDecoder(true);
        var resultObj:Object = decoder.decodeXML(xmlDoc);
        acAllNodes = new ArrayCollection();
        if(resultObj.root.hasOwnProperty("items"))
         if(resultObj.root.items is ArrayCollection)
          acAllNodes = resultObj.root.items;
         else if(resultObj.root.items is Object)
          acAllNodes.addItem(resultObj.root.items);
    </mx:Script>
    <mx:XMLListCollection id="dpNodes">
            <mx:source>
                <mx:XMLList>
        </items>
        </items>
                </mx:XMLList>
            </mx:source>
        </mx:XMLListCollection>
    </mx:Application>
    If this post answers your question or helps, please kindly mark it as such.
    Bhasker Chari
    Jul 21, 2010 12:28 PM   in reply to BhaskerChari
    Bhasker,
    YES your solution worked...thanks.
         It does appear to be customized for each Xml document which uses different node names.  Took me 5 minutes to figure out your XML Set started with "items" where as mine started with "student"...thanks.
    other than it worked perfectly:
    var strXML:String = xmlStudents.toXMLString();
    strXML =
    //Alert.show(strXML, 'Alert Box', mx.controls.Alert.OK);
    myData =
    if(resultObj.root.hasOwnProperty("student"))
    if(resultObj.root.student is ArrayCollection)
    myData = resultObj.root.student;
    else if(resultObj.root.student is Object)
    myData.addItem(resultObj.root.student);
    HERE IS MY fx:XMLLIST I based
    <fx:XMLList id="xmlStudents">
         <student>
         <id>1</id>
         <name>Christina Coenraets</name>
         <phone>555-219-2270</phone>
         <email>ccoenraets@fictitious.com</email>
         <active>true</active>
         <image>images/arrow_icon_sm1.png</image>
         </student>
    </fx:XMLList>
    Jul 21, 2010 10:13 PM   in reply to AICC
    Hi AICC,
    I am glad it worked for you....Have a happy coding..
    Bhasker
    Jun 5, 2011 4:22 PM   in reply to BhaskerChari
    How i can do. if i want also childern from xml list.
    if i am doing same way you show here and bind with tree its only give me the parent node its not give to me the childerns.
    i stuck with my tree please let me know the solution.
    thanks in advanced
    Mar 8, 2012 4:01 AM   in reply to woutek
