CarlMarket
How do I Output SQL query (cfquery) to screen
May 1, 2006 11:34 AM
I'd like to output the completed SQL Query that I'm writing to CFQuery to the screen so I can see what the report is querying the database.
I tried <cfoutput>#myquery#</cfoutput> but that didn't work.
    May 3, 2006 2:26 PM   in reply to CarlMarket
    <cfquery>
    some query
    <cfabort>
    </cfquery>
    May 3, 2006 7:16 PM   in reply to CarlMarket
    in cf7 you can get several bits of of metadata about a cfquery's resultset:
    result_name.sql: The SQL statement that was executed.
    result_name.recordcount: Current row of query that cfoutput is processing.
    result_name.cached: True if the query was cached; False otherwise.
    result_name.sqlparameters: An ordered Array of cfqueryparam values.
    result_name.columnList: Comma-delimited list of the query columns.
    result_name.ExecutionTime: Cumulative time required to process the query.
    in your case, replace "result_name" w/"myquery".
    May 8, 2006 8:19 AM   in reply to CarlMarket
    It sounds like you want to output the result set of the query.
    One way:
    <cfdump var="#myquery#">
    Another way:
    <cfoutput query="myquery">
    #[Column1]# #[Column2]# #[Column3]# (etc...) <br>
    </cfoutput>
