Just installed it and have been everywhere trying to find where to edit a question slide. Can't find the Easter egg.
Anybody know where Adobe hid it?
Thanks.
Hi there
Yeah, the areas where you make changes diffuse a bit with Captivate 5. Where you make the changes depend on what element you want to edit.
For the text styling, click on the element you wish to style or change, then either open the Properties panel and style it in the panel or open the Object Style Manager and style there.
If you want to change the options, open the Quiz Properties panel and change things like point value and feedback captions shown and buttons. Or the Action to perform
Cheers... Rick ![]()
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Yes - that's correct. I cannot edit a question slide.
This is an existing Cap 4 project. The first time I opened it in Cap 5, it didn't show the Quiz Properties.
I closed the file and opened it again. Now that I see the Quiz Properties, but I still can't get to any of the main quiz options.
This slide is a hot spot slide. I can't, for example, add another hot spot in the Quiz Properties. Quiz Properties are different from "Edit the Question Slide" button in previous Captivates, which used to be a button under the timeline. Now it doesn't exist? If I want to add a hotspot, do I have to delete the slide and start over now?
Edit: I see now how to add a hot spot.
Looks like I get to learn a new application. I wish their documentation were better. Fortunately, there are helpful folks on the forum for most questions.
Hello,
Just another suggestion: try to use the workspace 'Quizzing' when you are editing the Question slides: then you'll have the panel "Quiz Properties" in left docking station and the panel "Properties" in the right docking station. With the first panel you'll configure the question (like Edit Question slide in CP4) and with the second you'll do the fromatting. If you use the default Classic workspace, both panels will be in the right docking station and you have to click quite a lot. Be also sure to check out the Object styles (you can use the Object Style Manager - SHIFT-F7) where you'll find the styles for Quizzing objects.
Lilybiri
LOL, sorry about that Lilybiri. Totally spaced off that we had that strange arrangement of panels available!
Then again, the workspace arrangement is rendered moot if the question really cannot be edited, no?
Your best bet is to stick to CP4 to edit existing material while you learn the new interface, for reasons such as the following: try creating a "Fill-in-the-blank" in CP4 and porting it to CP5. Notice anything askew?
Kvetch: Flash users should be a bit more comfortable with CP5, but that is no excuse for Adobe requiring CP users to learn anew. What would be helpful is if they created adequate training for CP5 newbies (which I assume we all are) instead of relying on developers to train each other using the Adobe portal. Hey, I have an idea, perhaps Adobe could use CP5 to create training on how to use CP5? Naw, that would never work.
P.S. To create a Fill-in-the-blank in CP5 type the entire sentence or phrase and then highlight the word or phrase to be blank, right-click (Win) and mark as blank. Now wasn't that easy? I would add a smiley here, but that would go against my New Year's resolution.
P.P.S. It is relatively easy once you get the hang of it, but who said my relatives were easy, ba-dump-bump.
