Widget Browser not installing on Mac OS X 10.6.3
Jul 16, 2010 8:20 AM
I am using Air 2.0.2. On downloading Widget Browser and installing I get the Widget Browser window on the screen but is just consists of lines and a box - see portion of window below. Have tried uninstalling and installing again, both ways. Automatic install and by hand but get the same result. Have also uninstalled Ait and installed again but to no avail.
    Jul 20, 2010 1:26 AM   in reply to PepperStreet
    I have the same problem...
    Jul 20, 2010 9:14 AM   in reply to ahanj14
    I am unable to reproduce this problem on Mac 10.6.4.  So the install works fine and you can launch the Widget Browser.  You just can't see any Widgets?  Can you send a screen shot.  I will see if anyone else can reproduce this problem.
    -Scott Richards
    Dreamweaver Team
    Jul 20, 2010 10:00 AM   in reply to PepperStreet
    It looks like you are getting bitten by permissions problems. The Widget Browser creates a preferences file in your username/library/preferences folder named com.adobe.WidgetBrowser.################## where #### is a hex value.
    Can you make sure that you have write access to the preferences folder and this subfolder.  You should probably just delete this folder and launch again after making sure you have write access to the preferences folder.   If that doesn't work as a test can you create a new user and login to that account then try launching the Widget Browser.
    Let me know if that fixes it.
    -Scott Richards
    Dreamweaver Team
    Jul 20, 2010 11:20 AM   in reply to Scott DRichards
    Thank you very much for your support.
    I have a new MacBook Pro.
    I recently downloaded the trial version of Dreamweaver and Flash Pro.
    Then, following the procedures on this site:
    http://labs.adobe.com/technologies/widgetbrowser/
    I downloaded adobe Air and installed it. Then I downloaded Widget browser but
    when I want to install it, the installation doesn't complete. I get always the
    following window:
    Application Install
    Adobe Widget Browser
    Sorry an error has occurred
    The application could not be installed. Try installing it again. If the problem
    persists, contact the application author.
    Error# 2038
    By the way, I checked but the file com.adobe.widgetBrowser... doesn't exist in my username/library/preferences folder.
    Your help is highly appreciated,
    Jul 20, 2010 4:32 PM   in reply to PepperStreet
    There is another file that could have the wrong permissions can you try deleting username/library/Application Support/Adobe/AIR/ELS/com.adobe.WidgetBrowser.##############.  Then restart the widget browser.  If it cannot recreate this folder than AIR does not have the correct permissions to write to this folder. Can you run other AIR applications on your machine?  For Example Launch the Adobe Community Help System, From Dreawmeaver's Help menu, select Dreamweaver Help.
    If all else fails try re-installing AIR 2.0.2 from here: http://get.adobe.com/air/
    -Scott
    Jul 20, 2010 4:37 PM   in reply to ahanj14
    ahanj,
    Make sure you save the .air file locally (not save it to  a network location), and try to install it from there.
    Also make sure that you have air 2.0.2 installed from here: http://get.adobe.com/air/
    If that is not the problem could you try to enable logging  of the AIR application installs, as explained in this document: http://kb2.adobe.com/cps/403/kb403123.html.
    And post back with the contents of  your log file, please?
    Thanks and sorry for the inconvenience,
    Scott Richards,
    Dreamweaver Team.
    Jul 24, 2010 8:40 AM   in reply to PepperStreet
    I just tried using the widget browser as well and I am getting the same issue...Box with lines and can't do or see anything.  Has anyone has any success getting this to work.  I am running 10.6.4, I already uninstalled and reinstalled.  The permissions in my preferences are read/write.
    Jul 26, 2010 11:44 AM   in reply to Waluley13
    Sorry that you are having this problem.  We have not been able to reproduce this problem at Adobe I am trying on my MacBook Pro with 10.6.4.  And on my Quad Core Tower it is running fine on 10.6.3 and I just updated to 10.6.4 still works fine.  Can you see the thumbnails for the Widgets in the Adobe Exchange view okay?  From the other screenshots it looked like there was a problem displaying text, perhaps it is a font selection issue we are using Arial but should default to another appropriate font for Asian OS.  Can you post a screen shot of what you are seeing? What language version of the Operating System are you using?  Do you have any font utilities installed?
    Can you try creating a new user account on the machine and see if that enables you to see the Widget Browser.  Also can you make sure that you have latest version of AIR installed 2.0.2 which you can get from here. And can you run other AIR applications, for example launch the Dreamweaver Help System the Adobe Community Help Client is an AIR app. If creating a new account fixes the problem can you delete the following files and relaunch Widget Browser username/library/application support/Adobe/AIR/ and /username/library/preferences/com.adobe.WidgetBrowser.########## where ###### is a long hex number. And username/library/application support/Adobe/WidgetBrowser.
    Thanks in advance for helping us figure out what is causing this problem!
    Scott Richards
    Dreamweaver Team
    Aug 31, 2010 1:20 PM   in reply to PepperStreet
    I think this is a permissions issues since it works fine with a new account. I am seeing similar behavior, if I delete the com.adobe.WidgetBrowser.##### in username/library/preferences set the permissions to preferences folder and subfolders to Read Only and try to launch Widget Browser it is displaying the menu items but no blank screen with lines on it.
    Can you make sure that the Preferences folder and all subfolders have write permissions by clicking on yourUsername/library/preferences folder select Get Info. For the current user make sure the Privilege is set to Read & Write.
    For good measure do the same to
    username/library/Caches
    username/library/Appplication Support
    Delete the com.adobe.WidgetBrowser.##### folder and all its subfolders  launch and it should recreate this folder with subfolders /Local Store/Images Cache (where we download and cache the thumbnail images of the widgets).  We want to resolve this problem so if this doesn't work could I set up a connect session with you to see what is going wrong on your machine?  Email me privately
    Thanks and apologies,
    Scott Richards
    Dreamweaver Team
    Aug 29, 2010 6:31 PM   in reply to Scott DRichards
    This Adobe Widget Browser is really frustrating. I tried installing it today and got the same results that other people posting have noted and an exact replica of one person's screen shot.
    I had tried re installing and restarting but no luck.
    I read the "fixes" and tried changing permissions and re installing Air.
    Then I tried deleting and re installing the widget browser and got:
    So now I'm really stuck.
    I also do not know what is meant by delete the com.adobe.WidgetBrowser.##### folder
    I too am using a mac pro laptop and OS 10.6.4
    Is there no simple fix for this?
    Bill Oudegeest
    Sep 9, 2010 5:26 PM   in reply to PepperStreet
    I'm having a similar problem on 10.6.4. I have tried all of the above suggestions but can't get WB to launch completely. Last attempt required a force quit.
    Sep 10, 2010 9:28 AM   in reply to photofred
    I suspect that this may is a problem with the Arial font either not being installed or corrupted.  We are specifying "_sans" as a fallback but on these machines it does not appear to be mapping to an appropriate sans serif font like Helvetica.  On my Macbook Pro running 10.6.4 I remove Arial and I can still not reproduce the problem.  Can you make sure that you have Arial installed on your machine and it is enabled?  To do this open FontBook from Applications and make sure Arial is available and enabled.  If it is available and on can you try disabling all the Arial font families log out and try launching Widget Browser.  In Leopard and Snow Leopard OSX should have Arial.ttf installed in your /Library/Fonts folder. Are you using Suitcase or other third party font managers?
    If that doesn't work can you try creating a new user account on your machine and logging in as that user.  Everyone else who experienced this problem was able to fix this problem when they logged in with a new account.
    We are investigating what we can do on our side to work around this problem but it has proven difficult as we have not been able to reproduce it. In the interim,  thanks for your help and patience.
    -Scott Richards
    Dreamweaver Team
    Sep 10, 2010 10:31 AM   in reply to Scott DRichards
    Scott,
    I am not in front of that machine until tonight but I can tell you
    that I do use Linotype FontExplorerX to manage my fonts. I'll check on
    Arial tonight. Also, I downloaded the DW CS5 trial (had been using
    CS4) to see if that made a diff, but no.
    Thanks for working on this,
    Fred
    Fred Ehmann
    Acting Art Director,
    NJN Public Television
    Sep 10, 2010 11:34 AM   in reply to photofred
    Thanks for checking tonight on Arial.  Could you also try disabling LinoType Explorer?  This problem has nothing to do with which version of Dreamweaver you have installed since Widget Browser is a separate AIR application.  Note that you will need CS5 if you want to get the Insert Widget, Menu Item to insert the Widgets in your page using Dreamweaver.
    -Scott Richards
    Dreamweaver Team
    Sep 10, 2010 7:44 PM   in reply to Scott DRichards
    I disabled FontExplorerX, restarted finder, then checked font book--there were duplicate Arial files which I resolved. Then I tossed the widget prefs again before attempting to launch WB, but still got the blank window.
    Sep 16, 2010 10:01 AM   in reply to PepperStreet
    Thank you all for your patience and help in narrowing down this Mac problem with the blank screen on launch.  I have posted builds with 4 potential fixes. Since we are unable to reproduce this problem we need your help to try out these fixes.  Can you try installing the builds at the following location and let me know which one(s) fix the problem. Can you please try all of the builds out?  We need to figure out the best fix to go with that will fix it for everyone experiencing the problem.
    I am specifying the following fonts:
    WidgetBrowser1.air = Arial, Helvetica, "_sans";
    http://srichards.host.adobe.com/widgetBrowser/WidgetBrowser1.air
    WidgetBrowser2.air = Helvetica, "sans";
    http://srichards.host.adobe.com/widgetBrowser/WidgetBrowser2.air
    WidgetBrowser3.air = Arial, Helvetica;
    http://srichards.host.adobe.com/widgetBrowser/WidgetBrowser3.air
    WidgetBrowser4.air = Clean; (Adobe Clean Font embedded)
    http://srichards.host.adobe.com/widgetBrowser/WidgetBrowser4.air
    Thanks in advance,
    -Scott Richards
    Dreamweaver Team
    Sep 16, 2010 5:05 PM   in reply to Scott DRichards
    My results are as follows:
    Installer-1 closer than before but no
    Installer-2  Yes
    Installer-3 No
    Installer-4 also Yes
    Thanks for staying on this. I'm loving widgets so far...
    Jan 4, 2011 8:49 PM   in reply to Scott DRichards
    Sorry for being off topic, but my problem is very similar. After update to Adobe AIR 2.5 I can't run Adobe Media Player or Rosetta Stone (application that requires AIR 2.5). Works if I log in as another user - similar to the Widget Browser issue in this thread.
    Suggestions?
