Does anyone know what causes this warning to appear on the jboss log:
[com.adobe.workflow.template .document.DefaultProcessTemplateDocument] The varible UserLCID can not be matched with exact same case, assuming case insensitive.
Thanks in advance!!
You should log a bug so the message is being removed.
This message shouldn't be exposed in the log file. This is something that's going on internally and, without going in the details, should not be exposed in the log.
This is most likey happening with an old template.
You can just ignore it.
Jasmin
What does this warning complain about?
I don't know if the warning is related to an issue we are getting. A user task doesn't get created and the process sits at that operation in running status. When I check the variables, it does have a valid name.
The same operation works sometimesm, hence, making it an intermittent issue. Can anyone help?
Aditya
