the error "invalid plugin detected. Adobe Reader will quit"
Jul 29, 2008 10:19 PM
  Latest reply: sobreits, May 29, 2012 7:47 AM
Replies 1 2 Previous Next
    Jul 30, 2010 3:15 AM   in reply to (bruce628)
    uninstalling babylon will work, but if you still need babylon
    just delete the babylon plugin in both adobe and babylon system folder
    it really work for me !! feel so grateful to those of you who suggested this solution
    Aug 4, 2010 1:40 PM   in reply to RubenOF
    Babylon is the definite enemy.  Once I
    "uninstalled" it my Adobe
    9 worked just like it use to.
    Aug 4, 2010 1:46 PM   in reply to (bruce628)
    I too downloaded Babylon translator. right after that I got the "invalid plugin detected" error message.  I didn't put the 2 together until I read this thread. Last night I uninstalled Babylon translator, and so far I have been able to view pdf files and  I have not got the error message anymore. Keeping fingers crossed that it's fixed.
    Aug 4, 2010 5:29 PM   in reply to Normaswats
    Yes it works sure. However, It would be better achieve that both
    programs (Babylon and Acrobat reader) works well when both were
    installed in your PC. I don't know what to do. I have written to Babylon
    people but I have not any answer yet.
    I hope some patch correct soon this problem. Good luck
    Aug 5, 2010 3:09 AM   in reply to (bruce628)
    You are using pirate version of babylon 8, right? i'm so sure about it... Rename BabylonRPI.api inC:\Program Files\Babylon\Babylon-Pro\Utils\ to anythinge.g BabylonRPI.api_OLD or just delete it ! i will not copy api to acrobat reader plugin dir again at C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins  ENJOY... please support the developer when u buy it ... using genuine software ...
    Aug 5, 2010 7:55 AM   in reply to malaysia_crc
    I was using a Evaluation version of Babylon, and babylon had the nerve to ask me to purchase that software! Even after it messed up Adobe Reader 9, which I use all the time!
    Aug 5, 2010 10:52 AM   in reply to malaysia_crc
    Sorry, I don't know which Babylon it was.  It was the free on on the
    internet about a month ago.
    bw99
    Aug 6, 2010 8:34 AM   in reply to malaysia_crc
    Not pirated software trial software straight off there website. We all
    support our developers assuming that they make a product that works. It's
    not like Adobe is a small fry in the software world.
    Aug 13, 2010 4:32 AM   in reply to bullwinkle99
    It was the free version. But you can imagine: if the free version is for
    encouraging  you buy the professional one, you must forget to install
    any Babylon version if you want to use Adobe Reader.
    bw99
    Jan 7, 2011 6:57 AM   in reply to (bruce628)
      Bruce, click start then, click My Computer, then left double click Local Dic:C, then left double click Program Files, then left double click Adobe, then left double click Reader 9, then left double click Reader, then delete Plug_ins, delete Plug_ins3d and delete SPPlugins. Now exit and go to Add and Remove Programs and Remove Adobe 9, after removeing then go to Adobe. com and download again. You should be up and running.
    Aug 24, 2010 10:43 AM   in reply to riv6
    Quick, simple and easy....thanks a million.....
    ...... it worked the first time and now I am back to using my reader....
    Aug 24, 2010 12:05 PM   in reply to akp189
    akp189,
    Glad I was able to help, Your welcome.
    Dec 9, 2010 1:31 AM   in reply to Fiona808
    you solution is right thanks for your exertion
    Dec 10, 2010 7:53 PM   in reply to Eng. Bishoy
    your welcome
    Jan 7, 2011 3:01 AM   in reply to *gembeau*
    I have Solved This Problem Via SPPI and 3d Files.
    Apr 24, 2011 10:02 PM   in reply to *gembeau*
    ok thanks your solution for an error
    Feb 23, 2012 10:32 PM   in reply to (bruce628)
    The version I am using is the Adobe Reader X (10.1.2). I also got the same problem which allows me no chance to fix it when I click ok on the popup. I tried to repair it with the installation file, but I got another problem- cannot find some kinda file. Damn...I've never got this bug before.
    May 29, 2012 7:47 AM   in reply to chineseinterpreter
    I was having a plug-in error after I received a loaner laptop from IT. I tried to remove and reinstall Reader 10.3.1 and had the same error. (No Babylon installed)
    The plug-in error was due to some old plug ins that were still installed on the PC. Make sure all your plugins have the latest dates. I found a plug in dated 1999, one dated 2000 and another dated 2003. Once these were removed from the plugin folder, I was able to launch Acrobat Reader 10.3.1 with no errors.
    Path for plugins:  C:\Program Files\Adobe\Reader 10.0\Reader\plug_ins
    Good Luck All!!
1 2 Previous Next
Actions
