Aongus Collins
Adobe releases update to Illustrator CS5
Aug 6, 2010 3:28 PM
Illustrator 15.0.1 now available. Fixes a bug with gradient meshes that had messed up my workflow; many thanks:)
Other fixes, according to Adobe:
Out of memory problems specific to Macs with RAM exceeding 4gb, including failure of shortcut keys, rulers, or file open have been addressed.
Glyph Panel issues have been addressed.
Several crashes occurring at launch or quit have been addressed.
A crash when traversing a variable data set containing linked images has been addressed.
Aongus
    Aug 6, 2010 8:44 PM   in reply to Aongus Collins
    Doesn't appear in the Adobe Application Manager and when I download manually it just gives an error.
    Aug 6, 2010 9:32 PM   in reply to Jeremy AB
    @Jeremy:
    The issue you are facing must be some download issue. You may try downloading again or wait for the Adobe Application Manager(AAM) to start showing you this update. I normally see some lag between AAM and adobe.com pages for Adobe products. I am personally waiting for it to appear on AAM.
    Aug 6, 2010 10:43 PM   in reply to Jeremy AB
    @Jeremy,
    The error comes while downloading or installing? a screenshot of the error would be nice.
    Anirudh
    Aug 7, 2010 12:07 AM   in reply to bhatnaga
    The error came with installing, it said an error occurred and it can't finish the install. I tried rebooting, no effect. I tried the Adobe Ap Manager again, the update still didn't show up.
    When I tried the updater later, it wouldn't even launch, saying that the App Manager was already running and I need to quit it first.
    My next step was to reinstall Illustrator. Then check the App Manager again, still no update listed.
    But this time when I ran the downloaded updater it worked.
    Aug 7, 2010 7:06 AM   in reply to Jeremy AB
    Is there some odd reason Adobe refuses to name their downloads with descriptive names? I mean "Setup.dmg" could not be more ambiguous if Adobe tried. Is it really so hard to name a file "AdobeIllustrator15.0.1Update.dmg" or even "AI15.0.1UD.dmg". I guess it's assumed the Application Manager will be handling all files and it doesn't need descriptive names.
    Aug 9, 2010 1:48 AM   in reply to Jeremy AB
    Hi Jeremy,
    Can you do me a favour and post the failed patch log here? Its location would be:
    win: \Program files\Common Files\Adobe\Adobe Illustrator CS5 15.0.1 ... .log.gz
    mac: /Library/Logs/Adobe/Adobe Illustrator CS5 15.0.1 ... .log.gz
    where ... is the date stamp and will help you identify the failure log. Be careful as installer logs are also in the same folder and are named in a similar manner but have 15.0 in the name after CS5 instead of 15.0.1 which is for patch.
    Anirudh
    Aug 9, 2010 6:56 AM   in reply to Aongus Collins
    I get this error: http://yfrog.com/0g9fop
    Aug 9, 2010 8:04 AM   in reply to Ahmed Nuaman
    That was the error I got too, I believe.
    Aug 9, 2010 8:08 AM   in reply to bhatnaga
    Visit http://www.adobe.com/go/loganalyzer/ for more information
    START - Installer Session
    RIBS version: 3.0.122.0
    OSX version: 10.6.4
    ::START TIMER:: [Total Timer]
    CHECK: Single instance running
    CHECK : Credentials
    Load Deployment File
    deploymentFile option not given
    Create Required Folders
    Assuming install mode
    Looking up install source path
    Sync Media DB ...
    ::START TIMER:: [Sync Media DB]
    Pre check media db sync
    End of Pre check media db sync. Exit code: 0
    :: END TIMER :: [Sync Media DB] took 295 miliseconds (0.295 seconds) DTR = 27.1186 KBPS (0.0264831 MBPS)
    Ready to initialize session to start with ...
    ::START TIMER:: [CreatePayloadSession]
    -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
    Updated source path: /Volumes/AdobeIllustratorCS5/AdobeIllustratorCS5
    Updating media info for: {7A75E573-6909-4D48-BDFA-D8ED118605A6}
      Type: 1, Volume Order: 1, Media Name: AdobeIllustratorCS5
      Path: /Volumes/AdobeIllustratorCS5/AdobeIllustratorCS5/payloads/AdobeIllust rator15-mul-030810123040/AdobeIllustrator15-mul-030810123040.dmg
    --------------------  END  - Updating Media Sources -  END  --------------------
    [       0] Fri Aug  6 19:01:08 2010  INFO
    Supported RIBS version range: [0.0.66.0,3.0.122.0]
    ----------------- CreatePayloadSession: machine is x86 ---------------
    ______ Verify Dependency Subscribers ______
    [       0] Fri Aug  6 19:01:10 2010  INFO
    Overwrite property "extensionsOnly" to: 1
    Overwrite property "mode" to: silent
    Overwrite property "patchesOnly" to: 1
    Overwrite property "workflow" to: updater
    Found payload actions:
    Deciding what installer mode to use...
    BEGIN Setting requested payload actions
    Value returned on lookup of payload: {7A75E573-6909-4D48-BDFA-D8ED118605A6} Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul is: false
    Action string for  {7A75E573-6909-4D48-BDFA-D8ED118605A6} Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul  is install
    END Setting requested payload actions
    Collected advanced path check information for INSTALLDIR
    INSTALLDIR is a well-formed path
    INSTALLDIR is not the root path
    INSTALLDIR is on a local volume
    INSTALLDIR is on a writable volume
    INSTALLDIR is not on a case sensitive volume
    INSTALLDIR passed path basic path validation: /Applications
    Payloads passed preflight validation.
    Call PreSession Custom Hook
    [       0] Fri Aug  6 19:01:11 2010  INFO
    Calling the custom action code for pre-install for payload {7A75E573-6909-4D48-BDFA-D8ED118605A6}
    ::START TIMER:: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}]
    [       1] Fri Aug  6 19:01:11 2010  INFO
    Installer Operation: PayloadInstaller
    Request to install payload
    [       1] Fri Aug  6 19:01:12 2010  INFO
    CustomizedPatch property not found in database
    Beginning installation for payload at /private/tmp/.tempdirfPEU1n1R/Install.db
    [       1] Fri Aug  6 19:01:34 2010 ERROR
    985 Unable to locate file at "/Library/Preferences/com.adobe.Illustrator.15.0.0.plist"
    985 Command ARKMoveFileCommand failed.
    [       1] Fri Aug  6 19:01:34 2010  INFO
    Completing installation for payload at /private/tmp/.tempdirfPEU1n1R/Install.db
    985 Unable to move file at "/Library/Preferences/com.adobe.Illustrator.15.0.1.plist" to "/Library/Preferences/com.adobe.Illustrator.15.0.0.plist" Error 0
    985 Error rolling back command ARKMoveFileCommand
    [       0] Fri Aug  6 19:01:37 2010  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 26271 miliseconds (26.271 seconds) DTR = 0.913555 KBPS (0.000892143 MBPS)
    User specified overrideFile:
    Calling the ROLLBACK custom action code for pre-install for payload {7A75E573-6909-4D48-BDFA-D8ED118605A6} Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul
    No operation.  We're done:
    Updating driver data - Action: Remove driver entry
    Updating driver data successful. Driver entry was removed. ARP estimated size 0KB
    [       0] Fri Aug  6 19:01:40 2010  INFO
    Total components installed: 0
    Total components repaired: 0
    Total components removed: 0
    [       0] Fri Aug  6 19:01:40 2010 ERROR
    The following payload errors were found during install:
    - Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul: Install failed
    Call PostSession Custom Hook
    :: END TIMER :: [Total Timer] took 36875 miliseconds (36.875 seconds) DTR = 40.5695 KBPS (0.0396186 MBPS)
    -------------------------------------- Summary --------------------------------------
    - 0 fatal error(s), 6 error(s), 0 warning(s)
    ERROR: 985 Unable to locate file at "/Library/Preferences/com.adobe.Illustrator.15.0.0.plist"
    ERROR: 985 Command ARKMoveFileCommand failed.
    ERROR: 985 Unable to move file at "/Library/Preferences/com.adobe.Illustrator.15.0.1.plist" to "/Library/Preferences/com.adobe.Illustrator.15.0.0.plist" Error 0
    ERROR: 985 Error rolling back command ARKMoveFileCommand
    ERROR: The following payload errors were found during install:
    ERROR:  - Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul: Install failed
    Search the same string above to find when the error occured.
    Exit Code: 7 - Unable to complete Silent workflow
    END - Installer Session
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 305 miliseconds (0.305 seconds)
    [       0] Fri Aug  6 20:36:43 2010  INFO
    [       0] Fri Aug  6 20:36:45 2010  INFO
    [       0] Fri Aug  6 20:36:46 2010  INFO
    [       1] Fri Aug  6 20:36:47 2010  INFO
    [       1] Fri Aug  6 20:36:49 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdirEXDZbEtZ/Install.db
    [       1] Fri Aug  6 20:37:20 2010 ERROR
    [       1] Fri Aug  6 20:37:20 2010  INFO
    Completing installation for payload at /private/tmp/.tempdirEXDZbEtZ/Install.db
    [       0] Fri Aug  6 20:37:23 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 36379 miliseconds (36.379 seconds) DTR = 0.659721 KBPS (0.000644259 MBPS)
    [       0] Fri Aug  6 20:37:25 2010  INFO
    [       0] Fri Aug  6 20:37:25 2010 ERROR
    :: END TIMER :: [Total Timer] took 47287 miliseconds (47.287 seconds) DTR = 0.676719 KBPS (0.000660858 MBPS)
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 186 miliseconds (0.186 seconds) DTR = 580.645 KBPS (0.567036 MBPS)
    [       0] Fri Aug  6 20:57:38 2010  INFO
    [       0] Fri Aug  6 20:57:40 2010  INFO
    [       0] Fri Aug  6 20:57:42 2010  INFO
    [       1] Fri Aug  6 20:57:43 2010  INFO
    [       1] Fri Aug  6 20:57:45 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdirDGrWQ1bB/Install.db
    [       1] Fri Aug  6 20:58:45 2010  INFO
    Completing installation for payload at /private/tmp/.tempdirDGrWQ1bB/Install.db
    UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{7A75E573-6909-4D48-BDFA-D8ED118605A6}.db
    [       0] Fri Aug  6 20:58:46 2010  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 63566 miliseconds (63.566 seconds) DTR = 2395.87 KBPS (2.33972 MBPS)
    Updating driver data - Action: Add driver entry
    Updating driver data successful. Driver entry was added. ARP estimated size 0KB
    [       0] Fri Aug  6 20:58:47 2010  INFO
    Calling the custom action code for post-install for payload {7A75E573-6909-4D48-BDFA-D8ED118605A6} Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul
    Updating driver data successful. Driver entry was added. ARP estimated size 184645KB
    [       0] Fri Aug  6 20:58:50 2010  INFO
    Successfully installed 1 component:
    :: END TIMER :: [Total Timer] took 77748 miliseconds (77.748 seconds) DTR = 1973.14 KBPS (1.9269 MBPS)
    - 0 fatal error(s), 0 error(s), 0 warning(s)
    Exit Code: 0 - No error
    Aug 9, 2010 8:32 AM   in reply to Jeremy AB
    exactly the same error message here
    Aug 9, 2010 8:34 AM   in reply to .maybe
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 514 miliseconds (0.514 seconds)
    Updated source path: /Users/al/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS5-15.0/15 .0.1/AdobeIllustratorCS5
    Ignoring original data since install source is local
      Type: 0, Volume Order: 1, Media Name: AdobeIllustratorCS5
      Path: /Users/al/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS5-15.0/15 .0.1/AdobeIllustratorCS5/payloads/AdobeIllustrator15-mul-030810123040/ AdobeIllustrator15-mul-030810123040.dmg
    [       0] Tue Aug 10 01:21:33 2010  INFO
    [       0] Tue Aug 10 01:21:35 2010  INFO
    [       0] Tue Aug 10 01:21:36 2010  INFO
    [       1] Tue Aug 10 01:21:36 2010  INFO
    [       1] Tue Aug 10 01:21:38 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdirIklAmCLh/Install.db
    [       1] Tue Aug 10 01:21:58 2010 ERROR
    [       1] Tue Aug 10 01:21:58 2010  INFO
    Completing installation for payload at /private/tmp/.tempdirIklAmCLh/Install.db
    [       0] Tue Aug 10 01:22:01 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 25128 miliseconds (25.128 seconds) DTR = 2.70614 KBPS (0.00264272 MBPS)
    [       0] Tue Aug 10 01:22:03 2010  INFO
    [       0] Tue Aug 10 01:22:03 2010 ERROR
    :: END TIMER :: [Total Timer] took 45133 miliseconds (45.133 seconds) DTR = 102.453 KBPS (0.100052 MBPS)
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 92 miliseconds (0.092 seconds)
    [       0] Tue Aug 10 01:24:16 2010  INFO
    [       0] Tue Aug 10 01:24:17 2010  INFO
    [       0] Tue Aug 10 01:24:24 2010  INFO
    [       1] Tue Aug 10 01:24:24 2010  INFO
    [       1] Tue Aug 10 01:24:26 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdirTax58H9Y/Install.db
    [       1] Tue Aug 10 01:24:45 2010 ERROR
    [       1] Tue Aug 10 01:24:45 2010  INFO
    Completing installation for payload at /private/tmp/.tempdirTax58H9Y/Install.db
    [       0] Tue Aug 10 01:24:48 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 24132 miliseconds (24.132 seconds) DTR = 1.32604 KBPS (0.00129496 MBPS)
    [       0] Tue Aug 10 01:24:49 2010  INFO
    [       0] Tue Aug 10 01:24:51 2010  INFO
    [       0] Tue Aug 10 01:24:51 2010 ERROR
    :: END TIMER :: [Total Timer] took 47608 miliseconds (47.608 seconds) DTR = 0.336078 KBPS (0.000328201 MBPS)
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 101 miliseconds (0.101 seconds)
    [       0] Tue Aug 10 01:29:08 2010  INFO
    [       0] Tue Aug 10 01:29:09 2010  INFO
    [       1] Tue Aug 10 01:29:10 2010  INFO
    [       1] Tue Aug 10 01:29:11 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdir0hr5AHdg/Install.db
    [       1] Tue Aug 10 01:29:31 2010 ERROR
    [       1] Tue Aug 10 01:29:31 2010  INFO
    Completing installation for payload at /private/tmp/.tempdir0hr5AHdg/Install.db
    [       0] Tue Aug 10 01:29:34 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 24126 miliseconds (24.126 seconds) DTR = 0.828981 KBPS (0.000809552 MBPS)
    [       0] Tue Aug 10 01:29:36 2010  INFO
    [       0] Tue Aug 10 01:29:36 2010 ERROR
    :: END TIMER :: [Total Timer] took 41900 miliseconds (41.9 seconds) DTR = 0.668258 KBPS (0.000652595 MBPS)
    Aug 9, 2010 9:15 AM   in reply to .maybe
    Thank you Jeremy for the log file. What I infered from log file was that the following file was missing in your machine:
    '/Library/Preferences/com.adobe.Illustrator.15.0.0.plist'
    Out of curiosity, did you ever try to clean up preferences? If so, please take care not to delete this file in future as it is a system specific path and this file is only regenerated when you re-install. That is why your patch worked after re-install.
    And ::Maybe,
    Same is the problem on your machine. The file I mentioned for Jeremy is missing on your machine too. Please do a re-install and then try applying the patch.
    Ahmed,
    You can try reinstalling too, also do post your log files here as well.
    Aug 9, 2010 9:57 AM   in reply to bhatnaga
    That's interesting. I had switched hard drives and copied all the CS5 apps and supporting files over manually hoping it would save me time instead of re-installing. Both InDesign and Illustrator ran fine, no problems, only Photoshop gave me an error that some supporting files were missing. When I got the update error for Illustrator then I reinstalled. I was sure I copied over the prefs file too, and even so, once I launched Illustrator after the initial hard drive move you'd think it would create a new one if it were missing or at least give me an error? Hmmmmmm...
    Aug 9, 2010 10:01 AM   in reply to bhatnaga
    I am wondering if they moved or installed the application from another disk or cloned the installation?
    Might be a reason not to have the .plist?
    Most important is that the update addresses the problems in an excellent way, even Hans would be impressed.
    I would say Adobe's response has never been better and bringing features like transparency to gradient mesh points is fantastic.
    The fix for the gradient mesh work beautiful as well and perhaps it is just a perception but gradient meshes never look so beautiful.
    Aug 9, 2010 12:07 PM   in reply to Aongus Collins
    I just find it absolutely shocking that a company like Adobe who made a huge fuss over CS5 would release something of such poor quality! I want to down-grade!
    Aug 9, 2010 2:00 PM   in reply to Ahmed Nuaman
    Hi Ahmed,
    Would you care to elaborate on the problems you are facing? Making random, harsh statements like that dont help anyone. If you actually make constructive criticism, you never know, Adobe might just listen.
    Anirudh
    Aug 9, 2010 2:09 PM   in reply to bhatnaga
    That's a fair point, apologies; here are my issues:
    • Photoshop
      • It's about 50% slower than CS4 when loading files
      • It doesn't work properly with Spaces on OSX, for example if I'm in space 1 and Photoshop has been told to stay in space 2, if I load a file, it'll load in space 1 and then tab to space 2 but I then can't access the file cos it's in space 1 and Photoshop is in space 2
      • General performance is slower, although it's meant to be native 64bit?
    • Dreamweaver
      • AIR extension is unable to save anything if FileVault is on; turning off FileVault is *not* a solution; Dreamweaver CS4 worked perfectly fine with FileVault
      • Has the same issues with spaces as Photoshop has
    • Illustrator
      • Is actually the only program that seems to be working well and faster, but the biggest problem is the update manager that doesn't work, again, may be due to FileVault
    • Flash
      • This is the worst of them all, it's such a pain that it can't debug a SWF when FileVault is on is astonishing; how are Adobe programs having this many issues when CS4 didn't?
      • The font menu is still messed up, compared to Photoshop and Illustrator
      • Saving a file is slower than it was in CS4
      • I can't save down to CS3 (some clients are still on CS3)
      • Saving down to CS4 doesn't work as clients with CS4 can't load it
    It's just annoying, I was really excited to go to CS5, but I've just been so disappointed and being a freelancer with a very busy schedule I haven't got time to down-grade, and work around issues that shouldn't exist in a near £2k application suite.
    Aug 9, 2010 2:14 PM   in reply to Aongus Collins
    I'm running into this error when switching between Illustrator and Flash - this has only happened after the recent update.
    Also, within Flash, I don't have an option to Paste "using Illustrator Import preferences", and can only paste as a bitmap, which does not help in this situation at all.
    Any help resolving this would be awesome.
    Also, does anyone know of a way to roll back the update until this issue has been addressed? Thanks!
    Aug 9, 2010 2:19 PM   in reply to iamsquink
    In the meantime, for anyone who may be interested, I found that if I save the portions of my Illustrator piece that I need into a separate Illustrator file and import that into Flash (instead of pasting), everything works smoothly.
    Of course, this is not optimal, but is sufficient as a workaround.
    Aug 9, 2010 2:21 PM   in reply to iamsquink
    That's probably the only thing that does work for me
    Aug 9, 2010 2:43 PM   in reply to Ahmed Nuaman
    The both of you have other problems which are not Flash or Illustrator related and perhaps have nothing to do with FileVault as well.
    The only people who can find out what the problem is is probably the both of you share a common conflict it would seem.
    Because I can do this
    And this
    Aug 9, 2010 4:11 PM   in reply to Aongus Collins
    I'm having issues updating to Illustrator 15.0.1 as well. This is my updater log:
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 155 miliseconds (0.155 seconds) DTR = 51.6129 KBPS (0.0504032 MBPS)
    Updated source path: /Users/cmbelped/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS5-1 5.0/15.0.1/AdobeIllustratorCS5
      Path: /Users/cmbelped/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS5-1 5.0/15.0.1/AdobeIllustratorCS5/payloads/AdobeIllustrator15-mul-0308101 23040/AdobeIllustrator15-mul-030810123040.dmg
    [       0] Mon Aug  9 15:58:39 2010  INFO
    [       0] Mon Aug  9 15:58:44 2010  INFO
    [       0] Mon Aug  9 15:58:45 2010  INFO
    [       1] Mon Aug  9 15:58:45 2010  INFO
    [       1] Mon Aug  9 15:58:46 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdir46W0W4Dh/Install.db
    [       1] Mon Aug  9 15:58:48 2010 ERROR
    45 Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"
    45 Command ARKPatchCommand failed.
    [       1] Mon Aug  9 15:58:48 2010  INFO
    Completing installation for payload at /private/tmp/.tempdir46W0W4Dh/Install.db
    45 Unable to delete file at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"
    45 Error rolling back command ARKPatchCommand
    [       0] Mon Aug  9 15:58:49 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 4005 miliseconds (4.005 seconds) DTR = 1.9975 KBPS (0.00195069 MBPS)
    [       0] Mon Aug  9 15:58:51 2010  INFO
    [       0] Mon Aug  9 15:58:51 2010 ERROR
    :: END TIMER :: [Total Timer] took 26763 miliseconds (26.763 seconds) DTR = 18.9814 KBPS (0.0185366 MBPS)
    ERROR: 45 Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"
    ERROR: 45 Command ARKPatchCommand failed.
    ERROR: 45 Unable to delete file at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"
    ERROR: 45 Error rolling back command ARKPatchCommand
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 90 miliseconds (0.09 seconds)
    [       0] Mon Aug  9 16:06:05 2010  INFO
    [       0] Mon Aug  9 16:06:06 2010  INFO
    [       0] Mon Aug  9 16:06:07 2010  INFO
    [       0] Mon Aug  9 16:06:08 2010  INFO
    [       1] Mon Aug  9 16:06:08 2010  INFO
    [       1] Mon Aug  9 16:06:10 2010  INFO
    [       1] Mon Aug  9 16:06:11 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdirx561hEAu/Install.db
    [       1] Mon Aug  9 16:06:13 2010 ERROR
    [       1] Mon Aug  9 16:06:13 2010  INFO
    Completing installation for payload at /private/tmp/.tempdirx561hEAu/Install.db
    [       0] Mon Aug  9 16:06:14 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 6013 miliseconds (6.013 seconds) DTR = 0.665225 KBPS (0.000649634 MBPS)
    [       0] Mon Aug  9 16:06:15 2010  INFO
    [       0] Mon Aug  9 16:06:18 2010  INFO
    [       0] Mon Aug  9 16:06:18 2010 ERROR
    :: END TIMER :: [Total Timer] took 34101 miliseconds (34.101 seconds) DTR = 0.234597 KBPS (0.000229099 MBPS)
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 35 miliseconds (0.035 seconds)
    [       0] Mon Aug  9 18:23:49 2010  INFO
    [       0] Mon Aug  9 18:23:50 2010  INFO
    [       1] Mon Aug  9 18:23:50 2010  INFO
    [       1] Mon Aug  9 18:23:52 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdira2AqEMUi/Install.db
    [       1] Mon Aug  9 18:23:53 2010 ERROR
    [       1] Mon Aug  9 18:23:53 2010  INFO
    Completing installation for payload at /private/tmp/.tempdira2AqEMUi/Install.db
    [       0] Mon Aug  9 18:23:53 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 3021 miliseconds (3.021 seconds) DTR = 1.32406 KBPS (0.00129303 MBPS)
    [       0] Mon Aug  9 18:23:55 2010  INFO
    [       0] Mon Aug  9 18:23:55 2010 ERROR
    :: END TIMER :: [Total Timer] took 16305 miliseconds (16.305 seconds) DTR = 2.45324 KBPS (0.00239574 MBPS)
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 33 miliseconds (0.033 seconds) DTR = 484.848 KBPS (0.473485 MBPS)
    [       0] Mon Aug  9 18:34:36 2010  INFO
    [       0] Mon Aug  9 18:34:37 2010  INFO
    [       1] Mon Aug  9 18:34:37 2010  INFO
    [       1] Mon Aug  9 18:34:39 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdir34aislMo/Install.db
    [       1] Mon Aug  9 18:34:40 2010 ERROR
    [       1] Mon Aug  9 18:34:40 2010  INFO
    Completing installation for payload at /private/tmp/.tempdir34aislMo/Install.db
    [       0] Mon Aug  9 18:34:40 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 3022 miliseconds (3.022 seconds) DTR = 1.32363 KBPS (0.0012926 MBPS)
    [       0] Mon Aug  9 18:34:41 2010  INFO
    [       0] Mon Aug  9 18:34:43 2010  INFO
    [       0] Mon Aug  9 18:34:43 2010 ERROR
    :: END TIMER :: [Total Timer] took 15773 miliseconds (15.773 seconds) DTR = 1.77519 KBPS (0.00173358 MBPS)
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 15 miliseconds (0.015 seconds)
    [       0] Mon Aug  9 19:01:52 2010  INFO
    [       0] Mon Aug  9 19:01:53 2010  INFO
    [       1] Mon Aug  9 19:01:53 2010  INFO
    [       1] Mon Aug  9 19:01:55 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdirEdptBImH/Install.db
    [       1] Mon Aug  9 19:01:55 2010 ERROR
    Completing installation for payload at /private/tmp/.tempdirEdptBImH/Install.db
    [       0] Mon Aug  9 19:01:56 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 3027 miliseconds (3.027 seconds)
    [       0] Mon Aug  9 19:01:58 2010  INFO
    [       0] Mon Aug  9 19:01:58 2010 ERROR
    :: END TIMER :: [Total Timer] took 16234 miliseconds (16.234 seconds) DTR = 1.23198 KBPS (0.00120311 MBPS)
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 14 miliseconds (0.014 seconds)
    [       0] Mon Aug  9 19:03:01 2010  INFO
    [       0] Mon Aug  9 19:03:02 2010  INFO
    [       1] Mon Aug  9 19:03:02 2010  INFO
    [       1] Mon Aug  9 19:03:03 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdiryPLhAUSg/Install.db
    [       1] Mon Aug  9 19:03:04 2010 ERROR
    [       1] Mon Aug  9 19:03:04 2010  INFO
    Completing installation for payload at /private/tmp/.tempdiryPLhAUSg/Install.db
    [       0] Mon Aug  9 19:03:04 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 2021 miliseconds (2.021 seconds)
    [       0] Mon Aug  9 19:03:06 2010  INFO
    [       0] Mon Aug  9 19:03:06 2010 ERROR
    :: END TIMER :: [Total Timer] took 15182 miliseconds (15.182 seconds) DTR = 0.52694 KBPS (0.00051459 MBPS)
    I'm on my way out the door, so I haven't had a chance to check for that file. Any ideas?
    Aug 9, 2010 6:19 PM   in reply to CraigularB
    Yes did you move the application to a new location or install it by way of cloning your system to a different location?
    Aug 9, 2010 8:20 PM   in reply to Wade_Zimmerman
    It has not been moved or cloned; everything was installed to the default location and has not been moved or cloned at all.
    Aug 9, 2010 8:34 PM   in reply to Wade_Zimmerman
    It's almost like it's mistakenly looking for a Spanish language version (es.lproj). I have an en.lproj folder and an en_US folder inside the Resources directory. Maybe if I duplicate the en.lproj directory and rename it? I'm going to try that now...
    Nevermind, that didn't work....
    Message was edited by: CraigularB
    This is my new installer log. It's complaining about something else now. so I guess duplicating the directory and renaming it had some effect.
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    [       0] Mon Aug  9 23:30:05 2010  INFO
    [       0] Mon Aug  9 23:30:06 2010  INFO
    [       1] Mon Aug  9 23:30:06 2010  INFO
    [       1] Mon Aug  9 23:30:07 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdirykwbvnvr/Install.db
    [       1] Mon Aug  9 23:30:08 2010 ERROR
    [       1] Mon Aug  9 23:30:08 2010  INFO
    Completing installation for payload at /private/tmp/.tempdirykwbvnvr/Install.db
    [       0] Mon Aug  9 23:30:09 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 3021 miliseconds (3.021 seconds) DTR = 2.64813 KBPS (0.00258606 MBPS)
    [       0] Mon Aug  9 23:30:11 2010  INFO
    [       0] Mon Aug  9 23:30:11 2010 ERROR
    :: END TIMER :: [Total Timer] took 15884 miliseconds (15.884 seconds) DTR = 1.0073 KBPS (0.000983694 MBPS)
    - 0 fatal error(s), 3 error(s), 0 warning(s)
    Aug 9, 2010 10:55 PM   in reply to Aongus Collins
    What about the bug when saving from Illustrator CS5 to AFP network share ??
    For anyone not in the loop: When saving a file from Illustrator CS5 to AFP, file is created and saved, but remains hidden for some reason. You have to manually change the hidden flag from Terminal (chflags).
    Edit: Just installed the update, and the bug is still present.
    Aug 10, 2010 12:54 AM   in reply to CraigularB
    Hi CraigularB,
    Some localization data for every language is installed no matter on what language you install AI CS5 in. I have en_US only installed and I have directories for es.Iproj, de.Iproj and so on for many languages at the location you mentioned. Simply duplicating wont help as each file is unique and has different attributes which patch will error out on if it doesnt find the right attribute of the file. I guess either your last install was not complete or some files were deleted by mistake. Try the following:
    - Uninstal AI CS5 with the option to delete preferences.
    - Trash only the Adobe Illustrator CS5 folder if left behind.
    - Install AI again.
    - Now try to patch.
    Anirudh
    Aug 10, 2010 1:08 AM   in reply to Aongus Collins
    I am also getting an error with the 15.0.1 update installation.
    The installer provides the following 'helpful' information that I can contact support with.
    'installation failed'
    I ran the adobe support application, and get the information 'no problems found at this time'
    I tried to log a support case., but got an error page when I submitted.. stating simply 'error page - contact support'
    quite what I am supposed to do now I am not sure.
    Aug 10, 2010 1:37 AM   in reply to englishmaniac
    Hi Englishmaniac,
    Please post the log files here which are located at:
    Anirudh
    Aug 10, 2010 8:21 AM   in reply to bhatnaga
    I did use XSlimmer to clean up my applications at one point after the CS5 install; I don't remember if I cleaned the languages or not. I'm going to try and restore that (XSlimmer has the option to keep backups in case something goes wrong), and if that doesn't work I'll uninstall/reinstall.
    One quick thing though: I have the Master Collection, will this complicate the uninstall/reinstall process to do just one app? I'd rather not uninstall and reinstall the entire suite.
    Craig
    Aug 10, 2010 9:06 AM   in reply to CraigularB
    Craig
    I take it you have a mac in that case go to Applications/Utilities/Adobe Installers and use the uninstaller to remove only Illustrator when you go to reinstall from disk or disk image it will only give you the option to install Illustrator Look in the application Support Adobe for anything related to Adobe Illustrator CS 5 and remove it, also the cache files.
    Make certain this is also gone
    Go to User/username/Library/Preferences/ Adobe illustrator CS5 Settings and trash the settings folder, the whole folder not just the contents of the folder..
    Aug 10, 2010 9:10 PM   in reply to Wade_Zimmerman
    I finally got home about an hour ago and was able to use XSlimmer to restore Illustrator to its original state; after that I ran the updater and it succeeded with no problems. Thanks for the help!
    -Craig
    Aug 10, 2010 10:50 PM   in reply to iamsquink
    Embarrassingly, it seems the solution to what I made out to be a big deal was a simple restart. In case anyone was entrenched in that drama.
    Genius.
    Aug 11, 2010 1:39 AM   in reply to Aongus Collins
    Hi Anirudh
    In response to your email :
    I can't find any files in the /Library/Logs/Adobe/Adobe Illustrator CS5 15.0.1 ... .log.gz folder stated
    There is a file named Adobe Illustrator CS5 15.0.1 08-10-2010.log.gz which is in /Library/Logs/Adobe/Installers
    Contents of which are as follows :
    [       0] Tue Aug 10 08:37:25 2010  INFO
    OSX version: 10.6.4
    CHECK : Credentials
    Sync Media DB ...
    :: END TIMER :: [Sync Media DB] took 209 miliseconds (0.209 seconds)
    Updated source path: /Users/billambrose/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS 5-15.0/15.0.1/AdobeIllustratorCS5
      Path: /Users/billambrose/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS 5-15.0/15.0.1/AdobeIllustratorCS5/payloads/AdobeIllustrator15-mul-0308 10123040/AdobeIllustrator15-mul-030810123040.dmg
    [       0] Tue Aug 10 08:37:29 2010  INFO
    [       0] Tue Aug 10 08:37:30 2010  INFO
    [       1] Tue Aug 10 08:37:30 2010  INFO
    [       1] Tue Aug 10 08:37:31 2010  INFO
    Beginning installation for payload at /private/tmp/.tempdir5bYfeJEU/Install.db
    [       1] Tue Aug 10 08:37:31 2010 ERROR
    7 Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Plug-ins.localized/Extensions.localized/SVGFilterEffect.aip/Conte nts/Resources/nl.lproj/InfoPlist.strings"
    7 Command ARKPatchCommand failed.
    Completing installation for payload at /private/tmp/.tempdir5bYfeJEU/Install.db
    7 Unable to delete file at "/Applications/Adobe Illustrator CS5/Plug-ins.localized/Extensions.localized/SVGFilterEffect.aip/Conte nts/Resources/nl.lproj/InfoPlist.strings"
    7 Error rolling back command ARKPatchCommand
    [       0] Tue Aug 10 08:37:33 2010  INFO
    :: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 3004 miliseconds (3.004 seconds) DTR = 1.33156 KBPS (0.00130035 MBPS)
    [       0] Tue Aug 10 08:37:35 2010  INFO
    [       0] Tue Aug 10 08:37:35 2010 ERROR
    :: END TIMER :: [Total Timer] took 13836 miliseconds (13.836 seconds) DTR = 308.76 KBPS (0.301523 MBPS)
    ERROR: 7 Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Plug-ins.localized/Extensions.localized/SVGFilterEffect.aip/Conte nts/Resources/nl.lproj/InfoPlist.strings"
    ERROR: 7 Command ARKPatchCommand failed.
    ERROR: 7 Unable to delete file at "/Applications/Adobe Illustrator CS5/Plug-ins.localized/Extensions.localized/SVGFilterEffect.aip/Conte nts/Resources/nl.lproj/InfoPlist.strings"
    ERROR: 7 Error rolling back command ARKPatchCommand
    Kind Regards,
    Bill
    Aug 11, 2010 2:51 AM   in reply to englishmaniac
    Hi Bill,
    I did mention that ... is the date in Adobe Illustrator CS5 15.0.1 ... .log.gz. It doesn't matter, you did figure it out and posted the right log file.
    From the logs, the following file is missing on your machine:
    There may be many more such files that are missing.
    I have seen a lot of issues of this kind lately and most of the folks had an app like XSlimmer to slim down the application. Did you do the same? You can try restoring from the backup if thats the case.
    If that doesnt help, then Uninstall AI CS5, Delete AI CS5 folder from /Applications and install AI CS5 again. Now try to install patch for AI CS5 again.
    Anirudh
    Aug 11, 2010 3:17 AM   in reply to Aongus Collins
    Hi Anirudh,
    No I have never used the application you describe, nor am I using any kind of application of that nature.
    The only apps I use and have installed are audio applications (and associated plugins)
    website development apps, video editing apps, office apps and CS5 apps.
    The only thing which happened recently, and seemed to cause problems was when I installed Open Office to use the database app, and then uninstalled it after I realised it didn't do what i wanted.
    This seemed to cause problems of some nature ( i can't remember precise details as it was a month or so ago) - which caused me to reinstall some programmes.
    About a year ago I used a programme called monolingual, which ended up causing no end of problems with Adobe Creative Suite 4. I also used Onyx for a while back then, which also caused problems with Adobe products.
    As a direct result of this, I uninstalled both of these programmes, and haven't used them for at least a year, and certainly not since installing CS5.
    It does seem odd that Adobe seems far more susceptible to these kinds of programmes than any other I have used.
    I uninstalled CS5 Ilustrator,and then reinstalled about a month ago, after it seemed to be having problems exporting to PDF - until I realised that the addition of the new (to me)  'print' option for layers was causing the problem (as it is turned off by default on install - with the net effect that all pdfs output by Illustrator CS5 are blank)
    I finally tracked down the solution to this on a forum.. So my previous uninstall and reinstall wasn't actually necessary.
    I'll now uninstall CS5 Illustrator and reinstall and see where that gets me and report back to this forum
    Cheers
    Bill (an english maniac !!)
    Aug 11, 2010 3:45 AM   in reply to Aongus Collins
    Hi Anirudh,
    Thanks, that has resolved the issue. A simple uninstall and reinstall.
    I note that when installing Adobe apps they always create duplicate fonts ?
    This causes problems and slows my system down, and so i always have to go in and use resolve duplicates in Apple's font book to resolve
    Cheers
    Bill
