Adobe Media Encoder -> Encore - H.264 Blu-ray
Aug 10, 2010 10:45 AM
I just exported a Premiere Pro timeline using the Media Encoder with H.264 Blu-ray format and the 1080i 29.97 HQ preset. Presumably, you would choose this so that you do not have to transcode when you get to Encore. However, when I put my 16GB M4V file in a timeline, it wants to transcode saying it is "Untranscoded". Why? It also says the Blu-ray disc is only 11GB.
Please tell me there is something I can do to prevent from having to re-encode or transcode this file when it is already in a Blu-ray format.
Replies 1 2 Previous Next
    Aug 10, 2010 12:20 PM   in reply to Nick Marques
    Aug 10, 2010 12:44 PM   in reply to Nick Marques
    >should already be a Blu-ray
    Well, it would seem that Encore doesn't like SOMETHING about the file and therefore wants to transcode
    3 choices I know of are dimensions or data rate or sound type
    Since you say your file matches to the "yadda yadda" degree, then I have no other ideas
    Aug 10, 2010 12:50 PM   in reply to John T Smith
    Please post a screenshot of your En project panel, including the column headers.
    -Jeff
    Aug 10, 2010 1:38 PM   in reply to Nick Marques
    >wonder if it's the presets that are wrong or if Encore has a bug
    Bug Report and Feature Request https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Aug 10, 2010 3:33 PM   in reply to Nick Marques
    It appears that setting the Profile to Main instead of High as suggested in other posts from CS4 works
    Did you verify this yourself, or are you relying on second-hand information?  You should definitely test for yourself in case that's not the right solution for you.
    -Jeff
    Aug 11, 2010 1:00 AM   in reply to Nick Marques
    I have verified this with AME H264 - blu ray Preset 1080i 29.97 generated m4v file.
    and the status is showing don't transcode for blu ray.
    Please share AME preset screenshot.
    Sep 2, 2011 5:38 PM   in reply to Nick Marques
    I'm getting the same thing. I setup AME and then Encore reports needs transcoding. So sad that this is not fixed yet.
    Also, I have tried encoding from within Enocore and have tried making a custom setting. Encore selects the custom setting and then encodes at the lowest setting anyway. So instead of a 15GB 1.5 hour long Blu Ray, I get a 4.5 GB Blu Ray.
    Sep 2, 2011 7:24 PM   in reply to Nick Marques
    is it that stupid "2 pass VBR" bug showing its ugly head?
    <vent> i swear.... when it comes to DVD authoring encore is great, but encore BD authoring is just atrocious. if i had a first born son to sell, i would totally pony up for Sony Blu-Print and be done with it once and for all... but alas i'm dealing with what i have.... i really wish for CS6 they would give Sonic the middle finger if sonic won't update authorcore for adobe, and recreate encore from ground up to better work with BD on their own terms (like the work they did with overhauling/rewriting Audition) or have 2 seperate apps. Encore DVD with sonic authorcore engine and Encore BD with some new adobe proprietary nonsense. or try to hit-up sony to see if they would lend a scaled down engine of blu-print to be the backbone and say "up yours sonic, we got sony." i just wish encore BD was a smidge comparable to scenarist/blu-print/dostudio or such. why can't i make a flipping simple pop-up menu with backgrounds without jumping through all the layer edge hoops?!? i realize those apps are priced that way for a reason.... but i have yet to really be creatively inhibited when it comes to DVD authoring, but i'm constantly hitting walls and upsets with BD authoring when i step outside a few familiar templates. i want more interactivity. ah well... </vent>
    Sep 12, 2011 9:02 AM   in reply to Nick Marques
    I can't believe, even with CS 5.5, this "bug" exists. It's ridiculous. If you're going to have a H.264 BluRay preset in Media Encoder, I should be able to drag those files in to Encore 5.5 with NO ISSUE. Yet it still wants to transcode.
    Sep 12, 2011 8:51 PM   in reply to LeeWarner
    This bug is with only H264 VBR 2 Pass presets and if you change to VBR 1 Pass keeping evverything same, the bug should not be there.
    Sep 13, 2011 6:05 PM   in reply to ram8kumar
    hello,
    "This bug is with only H264 VBR 2 Pass presets and if you change to VBR 1 Pass keeping evverything same, the bug should not be there."
    honestly speaking, most everyone agrees that 2 pass is better quality than 1 pass
    and if this issue has been happening since cs4 and we just received our first update
    to cs5.5.1 for ppro, why does adobe still require us to 'lower' quality settings...
    it's almost like adobe doesn't want us exporting a full quality BD...
    doesn't adobe have the resources to fix this issue already?
    unless there is an acceptable answer, then shouldn't this be unacceptable...?
    this is almost like saying, "yeah the full hd presets don't work, but if you use the standard def presets, you should be okay..."
    especially if other authoring programs can do 2pass BD discs...
    is there an acceptable answer as to why this issue hasn't been fixed?
    is there any plans to update encore?
    thanks,
    jeffrey
    Sep 13, 2011 6:26 PM   in reply to tfi productions 44
    maybe they are not aware. to think of it.... i don't think i've posted a bug report. i should proabably do that. maybe no one has??
    Sep 13, 2011 6:45 PM   in reply to Andy Ramone
    hello,
    i disagree...
    this 2pass vbr BD issue has been happening since cs4
    if i've read the forum threads correctly,
    this thread just exposes the issue again...
    it would be nice to get an official answer other than speculation...
    jeffrey
    Sep 13, 2011 7:30 PM   in reply to tfi productions 44
    jeffrey,
    Did you try setting the Profile to Main instead of leaving it at the default High setting?  I just did, and En ingested the file from the AME as "Don't Transcode".
    Setting it to Main is a much better workaround than going from 2-pass to 1-pass, and if you save the modified preset, it's always just a single click away in the Preset control of the Export Settings dialog.
    And please do fill out a bug report as you see the bug: is the bug that the included preset defaults to the High profile when only Main will work with 2-pass VBR in En without transcoding?  Or is the bug that using the High profile with 2-pass VBR results in a file that En thinks it has to transcode?  Or both?  And consider that with all the bugs in En that need fixing, the fact that this issue has at least 2 viable workarounds (OK, maybe one-and-a-half viable workarounds) may likely push it to the bottom of the fix-it list.
    -Jeff
    Sep 13, 2011 7:43 PM   in reply to Jeff Bellune
    hello,
    it was my understanding that the 2pass issue is separate from
    the main/high issue...
    i thought all 2pass BD would be shirked by encore...
    ""Setting it to Main is a much better workaround than going from 2-pass to 1-pass, and if you save the modified preset, it's always just a single click away in the Preset control of the Export Settings dialog""
    i interpret this as a 'main/2pass BD project' works,
    but a 'high/2pass BD project' doesn't work...
    i'm confused with the 'going from 2 pass to 1 pass' because the forum threads say that 2pass doesn't work...
    sorry for adding any confusion to a confusing matter...
    thanks for helping
    i don't mind workarounds as long as users don't have to sacrifice quality
    which seems to be the issue going from 2 pass to 1 pass regardless of  the main/high thing...
    jeffrey
    Sep 13, 2011 7:59 PM   in reply to tfi productions 44
    Nope.
    Correct.
    ...unless you change the profile from High to Main.
    thanks for helping
    You're welcome.
    -Jeff
    Sep 13, 2011 8:02 PM   in reply to Jeff Bellune
    hello Jeff,
    i think i understand
    and will execute tests tomorrow night
    after work
    thank you so much for the clarity
    have a blessed night,
    jeffrey
    Sep 16, 2011 2:54 PM   in reply to Jeff Bellune
    Just did a 2pass with profile set to main instead of high. Still didn't work. Encore shows it as untranscoded. I'm using CS5.5.
    Either way, main, high, whichever. It's ludicrous for this bug to still be around.
    Sep 16, 2011 3:24 PM   in reply to LeeWarner
    Then:
    MeGUI
    It's free and x264 is a better H.264 encoder than MainConcept anyway.
    -Jeff
    Sep 19, 2011 3:28 PM   in reply to Nick Marques
    I just wanted to say this bug, encore wanting to re-transcode, also happens with the PP Blu-ray MEG2 setting. I made a Blu-ray disc for the first time. Just used all default settings in adobe media encoder and a Blu-ray meg2 file. Encore wants to re-transcode the file. This should be fixed!! Plan and simple. Fix it. :-(
    I love Premiere Pro, etc. But I hate that Adobe makes us, the end user, shell out $350 bucks just to get something fixed. The fix should be a free update.  Stop creating a new version and work on fixing the current one. :-(. Bugs like this has been around since at least version CS2 and I am sick and tired that Adobe can't or won't fix the bugs. And we, the end user have to find our own work around. Plus I love the integration in CS5. that I don't have to render in a 3rd party app as a middle step as I had to in version CS3 to produce high quality DVDs. Adobe did finally implement a better and good quality workflow for authoring DVDs if you export/transcode one sequence at a time that is.
    John Gerard
    Oct 17, 2011 3:14 PM   in reply to Jeff Bellune
    hello Jeff,
    finally got around to trying out your suggestions...
    i exported from PPRO cs5.03 as 1920x1080, 29.97 interlaced (upper), h264 main, 2pass
    unmuxed (separate audio track ac3 and separate video track) that are imported as assets into encore
    and encore still wants to transcode
    so i used the same settings to transcode, too..
    then encore at the end of the transcode states
    BluRay Ojbect "<timeline> emilyshelby" error: "invalid format" code: "14" note: "error" this stream
    doesn't include Pitcture Timing SEI unit offset = 150690284
    can you please comment...i really don't want to have to use megui
    thanks,
    j
    Oct 17, 2011 3:45 PM   in reply to Jeff Bellune
    hello Jeff,
    i just read the thread '
    Aug 21, 2010 2:23 AM
    How do I fix an error with "Picture Timing SEI"?
    and i checked my files and the export from PPRO is interlaced upper field first
    and the transcode (that didn't complete) is also interlaced upper field first
    i trashed the encore preferences before i started
    so i think i've done everything correctly
    again, i don't want to have to use another program
    and i don't want to be limited to 1 pass...
    thanks again,
    j
    Oct 18, 2011 8:15 AM   in reply to tfi productions 44
    This "bug" has been going on for so long that it's reached a point of insanity. Plain and simple. I don't want to have to use a separate program...for example megui is PC based and I'm on a mac.
    It's very simple to me...I should be able to use ADOBE! Media Encoder to be able to create the best quality output to put into ADOBE! Encore.
    Come on. Just fix the damn problem. The end.
    Oct 18, 2011 9:07 AM   in reply to LeeWarner
    I don't know why setting the profile to main isn't working for you guys.  It works here.  All I can do is suggest you delete all of the cache files associated with the media you're using, and clean the media cache database.
    Consider trashing your preferences as well.
    -Jeff
    Oct 18, 2011 9:17 AM   in reply to Jeff Bellune
    hello Jeff,
    can you reply back with the specific locations
    of the cache files and the cache database to delete please
    (is it a cache within the Encore folder
    or the media cache that cs5 uses that you see
    within PPRO preferences that you can change the location of)
    i am hoping it is the media cache attached to PPRO
    because then i still have hope because the other oddity
    of my project was that i re encoded the bluray from PPRO
    to use the main profile setting at the export came out to be
    like 24GB but Encore was still reading it as 32GB
    (so it is picking up wrong information somewhere
    which i'm hoping is the media cache database or media cache)
    again thanks for helping me get through this
    jeffrey
    Oct 18, 2011 9:24 AM   in reply to tfi productions 44
    In Premiere Pro, go to Edit | Preferences | Media.  There you will find the location of your media cache files.  There is also a "Clean" button for the database -- you don't have to delete anything in the database.  See attached.
    -Jeff
    Nov 7, 2011 8:33 AM   in reply to Jeff Bellune
    I have now tried these exact settings on both my PC and my Mac. Nothing, nada, zip, zilch. Encore still thinks it's untranscoded. Ugh.
    Nov 30, 2011 9:05 PM   in reply to LeeWarner
    I am reporting the exact same problem.
    Main
    VBR 2 Pass
    Encore will take it as untranscoded.
    However, another project looks just fine, exact the same setting.
    Could someone explain to me whether High just does not work?  I have m4v from past project whcih are encoded by default setting (so High instead of Main).  Am I left with the only option to re-encode?  This is my biggest concern.
    Nov 30, 2011 9:22 PM   in reply to Howard Hoffman
    And can someone tell me where to find the cache file?
    .pek, .cfa are for ac3.
    .mpgindex is for m2v
    What's the cache file for m4v?
    I can confirm that most of m4v with High (reported by MediaInfo) works fine.  All files I have are encoded in VBR 2 Pass.
    Dec 18, 2011 10:38 AM   in reply to Diana1314
    Thanks so MUCH Diana1314. You will now be reported to the Spam Patrol. If that isn't a PR line, I'm not sure what is.
    Dec 18, 2011 11:23 AM   in reply to LeeWarner
    Lolz.
    Jan 4, 2012 1:46 PM   in reply to Nick Marques
    Just wanted to jump in here and say I am having the same exact issue.
    http://forums.adobe.com/message/4117698#4117698
    http://forums.adobe.com/message/4117565#4117565
    Trying all the same stuff, Encore wants to transcode 2-Pass VBR High/Main m4v files.  If I encode just a minute or two of my sequence, it'll take it fine but the whole thing ~1.5 hrs it wants to re-transcode it.
    Very odd and VERY frustrating, especially considering trying to find work arounds involves waiting for six hour + encodes to complete
    This has been around since CS4?
    That is ridiculous.
    Jan 4, 2012 3:03 PM   in reply to HarpuaFSB
    http://forums.adobe.com/message/4118773#4118773
    I have a message from Adobe developer saying it's fixed in Encore.  I am hoping we will get that as an update/patch.
1 2 Previous Next
