I'm hoping for some help as the Adobe Illustrator 15.0.1 Update installation failed on me. Please see the screen grab of the message below. I own the Design Premium Creative Suite (Education version) and run it on my MacBook Pro OS X 10.6.4. I haven't had an update error before.
The support pages seem to give me a runaround when trying to email Adobe regarding the issue though they suggest I telephone them for $39. I'd rather not pay that for a problem with their update.
Has anyone else run into this? I've searched the forums and found nothing else. I think I sent a message to Adobe using their Adobe Support Advisor program but haven't heard anything yet.
I would really appreciate some suggestions.
Thank you!
Hi Twis and CraigularB
Please post the log files here which are located at:
win: \Program files\Common Files\Adobe\Adobe Illustrator CS5 15.0.1 ... .log.gz
mac: /Library/Logs/Adobe/Adobe Illustrator CS5 15.0.1 ... .log.gz
where ... is the date stamp and will help you identify the failure log. Be careful as installer logs are also in the same folder and are named in a similar manner but have 15.0 in the name after CS5 instead of 15.0.1 which is for patch.
Anirudh
Here's my log - after several attempts / failures to update Illustrator.
2010-07-28 10:53:58 -0400: Log created
2010-07-28 10:53:59 -0400: Adobe Acrobat Updater encountered errorCode 260
2010-07-28 10:53:59 -0400: Adobe Acrobat Updater encountered errorCode 1001
2010-07-28 10:54:00 -0400: Adobe Acrobat Updater Helper received exception:
Stopping due to error
2010-07-31 16:59:14 -0400: Adobe Acrobat Updater encountered errorCode 260
2010-07-31 16:59:14 -0400: Adobe Acrobat Updater encountered errorCode 1001
2010-07-31 16:59:14 -0400: Adobe Acrobat Updater Helper received exception:
2010-07-31 18:32:57 -0400: Adobe Acrobat Updater encountered errorCode 260
2010-07-31 18:32:58 -0400: Adobe Acrobat Updater encountered errorCode 1001
2010-07-31 18:32:59 -0400: Adobe Acrobat Updater Helper received exception:
2010-08-01 16:11:23 -0400: URL 'https:/armmf.adobe.com/arm-manifests/mac/9/current_version_url_templ ate.txt' contents: '/{MAJREV}/9.3.3/current_version.txt'
2010-08-01 16:11:23 -0400: URL 'https:/armmf.adobe.com/arm-manifests/mac/9/9.3.3/current_version.txt ' contents: '9.3.3'
2010-08-05 07:34:46 -0400: URL 'https:/armmf.adobe.com/arm-manifests/mac/9/current_version_url_templ ate.txt' contents: '/{MAJREV}/9.3.3/current_version.txt'
2010-08-05 07:34:48 -0400: URL 'https:/armmf.adobe.com/arm-manifests/mac/9/9.3.3/current_version.txt ' contents: '9.3.3'
2010-08-09 07:23:02 -0400: URL 'https:/armmf.adobe.com/arm-manifests/mac/9/current_version_url_templ ate.txt' contents: '/{MAJREV}/9.3.3/current_version.txt'
2010-08-09 07:23:03 -0400: URL 'https:/armmf.adobe.com/arm-manifests/mac/9/9.3.3/current_version.txt ' contents: '9.3.3'
Hi Alex,
Log files are located at:
Anirudh
OK. I was using the library folder inside the user account rather than the boot volume. Sorry.
Here's one of the logs:
Visit http://www.adobe.com/go/loganalyzer/ for more information
START - Installer Session
RIBS version: 3.0.122.0
OSX version: 10.6.4
::START TIMER:: [Total Timer]
CHECK: Single instance running
CHECK : Credentials
Load Deployment File
deploymentFile option not given
Create Required Folders
Assuming install mode
Looking up install source path
Sync Media DB ...
::START TIMER:: [Sync Media DB]
Pre check media db sync
End of Pre check media db sync. Exit code: 0
:: END TIMER :: [Sync Media DB] took 528 miliseconds (0.528 seconds)
Ready to initialize session to start with ...
::START TIMER:: [CreatePayloadSession]
-------------------- BEGIN - Updating Media Sources - BEGIN --------------------
Updated source path: /Users/Alex/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS5-15.0/ 15.0.1/AdobeIllustratorCS5
Updating media info for: {7A75E573-6909-4D48-BDFA-D8ED118605A6}
Ignoring original data since install source is local
Type: 0, Volume Order: 1, Media Name: AdobeIllustratorCS5
Path: /Users/Alex/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS5-15.0/ 15.0.1/AdobeIllustratorCS5/payloads/AdobeIllustrator15-mul-03081012304 0/AdobeIllustrator15-mul-030810123040.dmg
-------------------- END - Updating Media Sources - END --------------------
Supported RIBS version range: [0.0.66.0,3.0.122.0]
----------------- CreatePayloadSession: machine is x86 ---------------
[ 0] Tue Aug 10 07:32:41 2010 INFO
______ Verify Dependency Subscribers ______
[ 0] Tue Aug 10 07:32:51 2010 INFO
Overwrite property "extensionsOnly" to: 1
Overwrite property "mode" to: silent
Overwrite property "patchesOnly" to: 1
Overwrite property "workflow" to: updater
Found payload actions:
Deciding what installer mode to use...
BEGIN Setting requested payload actions
Value returned on lookup of payload: {7A75E573-6909-4D48-BDFA-D8ED118605A6} Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul is: false
Action string for {7A75E573-6909-4D48-BDFA-D8ED118605A6} Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul is install
END Setting requested payload actions
Collected advanced path check information for INSTALLDIR
INSTALLDIR is a well-formed path
INSTALLDIR is not the root path
INSTALLDIR is on a local volume
INSTALLDIR is on a writable volume
INSTALLDIR is not on a case sensitive volume
INSTALLDIR passed path basic path validation: /Applications
Payloads passed preflight validation.
Call PreSession Custom Hook
[ 0] Tue Aug 10 07:32:52 2010 INFO
Calling the custom action code for pre-install for payload {7A75E573-6909-4D48-BDFA-D8ED118605A6}
::START TIMER:: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}]
[ 1] Tue Aug 10 07:32:52 2010 INFO
Installer Operation: PayloadInstaller
Request to install payload
[ 1] Tue Aug 10 07:32:54 2010 INFO
CustomizedPatch property not found in database
Beginning installation for payload at /private/tmp/.tempdir3DIqzrMi/Install.db
[ 1] Tue Aug 10 07:32:56 2010 ERROR
45 Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"
45 Command ARKPatchCommand failed.
[ 1] Tue Aug 10 07:32:56 2010 INFO
Completing installation for payload at /private/tmp/.tempdir3DIqzrMi/Install.db
45 Unable to delete file at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"
45 Error rolling back command ARKPatchCommand
[ 0] Tue Aug 10 07:32:56 2010 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 4227 miliseconds (4.227 seconds) DTR = 0.946298 KBPS (0.000924119 MBPS)
User specified overrideFile:
Calling the ROLLBACK custom action code for pre-install for payload {7A75E573-6909-4D48-BDFA-D8ED118605A6} Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul
No operation. We're done:
Updating driver data - Action: Remove driver entry
Updating driver data successful. Driver entry was removed. ARP estimated size 0KB
[ 0] Tue Aug 10 07:32:58 2010 INFO
Total components installed: 0
Total components repaired: 0
Total components removed: 0
[ 0] Tue Aug 10 07:32:58 2010 ERROR
The following payload errors were found during install:
- Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul: Install failed
Call PostSession Custom Hook
:: END TIMER :: [Total Timer] took 23213 miliseconds (23.213 seconds) DTR = 1.20622 KBPS (0.00117795 MBPS)
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 6 error(s), 0 warning(s)
ERROR: 45 Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"
ERROR: 45 Command ARKPatchCommand failed.
ERROR: 45 Unable to delete file at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"
ERROR: 45 Error rolling back command ARKPatchCommand
ERROR: The following payload errors were found during install:
ERROR: - Adobe Illustrator CS5_15.0.1_AdobeIllustrator15-mul: Install failed
Search the same string above to find when the error occured.
Exit Code: 7 - Unable to complete Silent workflow
END - Installer Session
[ 0] Tue Aug 10 08:24:07 2010 INFO
OSX version: 10.6.4
CHECK : Credentials
Sync Media DB ...
:: END TIMER :: [Sync Media DB] took 917 miliseconds (0.917 seconds)
[ 0] Tue Aug 10 08:24:11 2010 INFO
[ 0] Tue Aug 10 08:24:42 2010 INFO
[ 0] Tue Aug 10 08:24:43 2010 INFO
[ 0] Tue Aug 10 08:24:44 2010 INFO
[ 1] Tue Aug 10 08:24:44 2010 INFO
[ 1] Tue Aug 10 08:24:48 2010 INFO
Beginning installation for payload at /private/tmp/.tempdireWcLMNbK/Install.db
[ 1] Tue Aug 10 08:24:52 2010 ERROR
[ 1] Tue Aug 10 08:24:52 2010 INFO
Completing installation for payload at /private/tmp/.tempdireWcLMNbK/Install.db
[ 0] Tue Aug 10 08:24:53 2010 INFO
:: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 9304 miliseconds (9.304 seconds) DTR = 1.71969 KBPS (0.00167939 MBPS)
[ 0] Tue Aug 10 08:24:55 2010 INFO
[ 0] Tue Aug 10 08:24:58 2010 INFO
[ 0] Tue Aug 10 08:24:58 2010 ERROR
:: END TIMER :: [Total Timer] took 92913 miliseconds (92.913 seconds) DTR = 15.2401 KBPS (0.0148829 MBPS)
OSX version: 10.6.4
CHECK : Credentials
Sync Media DB ...
:: END TIMER :: [Sync Media DB] took 626 miliseconds (0.626 seconds)
[ 0] Tue Aug 10 08:39:49 2010 INFO
[ 0] Tue Aug 10 08:39:59 2010 INFO
[ 0] Tue Aug 10 08:40:00 2010 INFO
[ 1] Tue Aug 10 08:40:01 2010 INFO
[ 1] Tue Aug 10 08:40:03 2010 INFO
Beginning installation for payload at /private/tmp/.tempdirOiY7FL6h/Install.db
[ 1] Tue Aug 10 08:40:05 2010 ERROR
[ 1] Tue Aug 10 08:40:05 2010 INFO
Completing installation for payload at /private/tmp/.tempdirOiY7FL6h/Install.db
[ 0] Tue Aug 10 08:40:05 2010 INFO
:: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 4324 miliseconds (4.324 seconds)
[ 0] Tue Aug 10 08:40:07 2010 INFO
[ 0] Tue Aug 10 08:40:07 2010 ERROR
:: END TIMER :: [Total Timer] took 23562 miliseconds (23.562 seconds) DTR = 1.69765 KBPS (0.00165786 MBPS)
Hi Alex,
Following file is missing on your system:
Either you install was not complete or some files have been deleted from your machine. Maybe you tried to copy from some drive. But the point is, its missing. I ran a quick check check on my machine and it was pesent on it. You'll need to uninstall, delete Adobe Illustrator CS5 folder if left behind and install again.
Anirudh
I had exactly the same problem this morning trying to update to Illustrator 15.0.1 from Design Premium using OSX 10.6.4 . This is also the first time I have ever had an Adobe update fail.
Following the advice to uninstall and reinstall and the update has worked perfectly.
MANY THANKS to Anirudh for such good advice.
Here's my log file. Should I deinstall and reinstall too?
OSX version: 10.6.4
CHECK : Credentials
Sync Media DB ...
:: END TIMER :: [Sync Media DB] took 389 miliseconds (0.389 seconds) DTR = 30.8483 KBPS (0.0301253 MBPS)
Updated source path: /Users/tedbattye/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS5- 15.0/15.0.1/AdobeIllustratorCS5
Path: /Users/tedbattye/Library/Caches/Adobe/AAMUpdater/AdobeIllustratorCS5- 15.0/15.0.1/AdobeIllustratorCS5/payloads/AdobeIllustrator15-mul-030810 123040/AdobeIllustrator15-mul-030810123040.dmg
[ 0] Mon Aug 9 04:22:32 2010 INFO
[ 0] Mon Aug 9 04:22:39 2010 INFO
[ 0] Mon Aug 9 04:22:40 2010 INFO
[ 1] Mon Aug 9 04:22:40 2010 INFO
[ 1] Mon Aug 9 04:22:42 2010 INFO
Beginning installation for payload at /private/tmp/.tempdirPJWU4kn3/Install.db
[ 1] Mon Aug 9 04:22:43 2010 ERROR
13 Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Required/Plug-ins/PDF Suite.aip/Contents/Resources/no.lproj/InfoPlist.strings"
13 Command ARKPatchCommand failed.
[ 1] Mon Aug 9 04:22:43 2010 INFO
Completing installation for payload at /private/tmp/.tempdirPJWU4kn3/Install.db
13 Unable to delete file at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Required/Plug-ins/PDF Suite.aip/Contents/Resources/no.lproj/InfoPlist.strings"
13 Error rolling back command ARKPatchCommand
[ 0] Mon Aug 9 04:22:44 2010 INFO
:: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 4225 miliseconds (4.225 seconds) DTR = 0.946746 KBPS (0.000924556 MBPS)
[ 0] Mon Aug 9 04:22:46 2010 INFO
[ 0] Mon Aug 9 04:22:46 2010 ERROR
:: END TIMER :: [Total Timer] took 19690 miliseconds (19.69 seconds) DTR = 1.01574 KBPS (0.000991938 MBPS)
ERROR: 13 Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Required/Plug-ins/PDF Suite.aip/Contents/Resources/no.lproj/InfoPlist.strings"
ERROR: 13 Command ARKPatchCommand failed.
ERROR: 13 Unable to delete file at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Required/Plug-ins/PDF Suite.aip/Contents/Resources/no.lproj/InfoPlist.strings"
ERROR: 13 Error rolling back command ARKPatchCommand
OSX version: 10.6.4
CHECK : Credentials
Sync Media DB ...
:: END TIMER :: [Sync Media DB] took 133 miliseconds (0.133 seconds)
[ 0] Mon Aug 9 04:27:46 2010 INFO
[ 0] Mon Aug 9 04:27:47 2010 INFO
[ 1] Mon Aug 9 04:27:47 2010 INFO
[ 1] Mon Aug 9 04:27:49 2010 INFO
Beginning installation for payload at /private/tmp/.tempdirvTivZ1IR/Install.db
[ 1] Mon Aug 9 04:27:50 2010 ERROR
[ 1] Mon Aug 9 04:27:50 2010 INFO
Completing installation for payload at /private/tmp/.tempdirvTivZ1IR/Install.db
[ 0] Mon Aug 9 04:27:50 2010 INFO
:: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 3223 miliseconds (3.223 seconds) DTR = 1.24108 KBPS (0.00121199 MBPS)
[ 0] Mon Aug 9 04:27:51 2010 INFO
[ 0] Mon Aug 9 04:27:53 2010 INFO
[ 0] Mon Aug 9 04:27:53 2010 ERROR
:: END TIMER :: [Total Timer] took 11913 miliseconds (11.913 seconds) DTR = 0.671535 KBPS (0.000655796 MBPS)
OSX version: 10.6.4
CHECK : Credentials
Sync Media DB ...
:: END TIMER :: [Sync Media DB] took 107 miliseconds (0.107 seconds)
Updated source path: /Volumes/AdobeIllustratorCS5/AdobeIllustratorCS5
Type: 1, Volume Order: 1, Media Name: AdobeIllustratorCS5
Path: /Volumes/AdobeIllustratorCS5/AdobeIllustratorCS5/payloads/AdobeIllust rator15-mul-030810123040/AdobeIllustrator15-mul-030810123040.dmg
[ 0] Mon Aug 9 14:37:58 2010 INFO
[ 0] Mon Aug 9 14:37:59 2010 INFO
[ 1] Mon Aug 9 14:37:59 2010 INFO
[ 1] Mon Aug 9 14:38:00 2010 INFO
Beginning installation for payload at /private/tmp/.tempdirUO6zW45V/Install.db
[ 1] Mon Aug 9 14:38:01 2010 ERROR
[ 1] Mon Aug 9 14:38:01 2010 INFO
Completing installation for payload at /private/tmp/.tempdirUO6zW45V/Install.db
[ 0] Mon Aug 9 14:38:01 2010 INFO
:: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 2233 miliseconds (2.233 seconds)
[ 0] Mon Aug 9 14:38:03 2010 INFO
[ 0] Mon Aug 9 14:38:05 2010 INFO
[ 0] Mon Aug 9 14:38:05 2010 ERROR
:: END TIMER :: [Total Timer] took 12457 miliseconds (12.457 seconds) DTR = 0.642209 KBPS (0.000627157 MBPS)
OSX version: 10.6.4
CHECK : Credentials
Sync Media DB ...
:: END TIMER :: [Sync Media DB] took 451 miliseconds (0.451 seconds)
[ 0] Mon Aug 9 14:49:26 2010 INFO
[ 0] Mon Aug 9 14:49:37 2010 INFO
[ 0] Mon Aug 9 14:49:38 2010 INFO
[ 1] Mon Aug 9 14:49:38 2010 INFO
[ 1] Mon Aug 9 14:49:41 2010 INFO
Beginning installation for payload at /private/tmp/.tempdirSn7vLOQr/Install.db
[ 1] Mon Aug 9 14:49:41 2010 ERROR
Completing installation for payload at /private/tmp/.tempdirSn7vLOQr/Install.db
[ 0] Mon Aug 9 14:49:41 2010 INFO
:: END TIMER :: [Payload Operation :{7A75E573-6909-4D48-BDFA-D8ED118605A6}] took 3205 miliseconds (3.205 seconds) DTR = 1.24805 KBPS (0.0012188 MBPS)
[ 0] Mon Aug 9 14:49:42 2010 INFO
[ 0] Mon Aug 9 14:49:44 2010 INFO
[ 0] Mon Aug 9 14:49:44 2010 ERROR
:: END TIMER :: [Total Timer] took 22964 miliseconds (22.964 seconds) DTR = 0.348371 KBPS (0.000340206 MBPS)
Yes Twis,
Please go ahead and do a uninstall and re-install.
Following file is missing from your machine:
and maybe a whole lot more of such files. Patch errored out on the first instance.
Out of curiosity, were you using some aplication utility to trim down application size as well??
Anirudh
For Mac OS, start by looking in /Library/Logs/Adobe/Installers find the newest .gz file double click to expand.
Look inside for errors, for me it was this:
ERROR: 985 Unable to locate file at "/Library/Preferences/com.adobe.Illustrator.15.0.0.plist"
ERROR: 985 Command ARKMoveFileCommand failed.
ERROR: 985 Unable to move file at "/Library/Preferences/com.adobe.Illustrator.15.0.1.plist" to "/Library/Preferences/com.adobe.Illustrator.15.0.0.plist" Error 0
ERROR: 985 Error rolling back command ARKMoveFileCommand
Looking at your log it looks like the only things it's unhappy about is a missing Norwegian localization file for the PDF plugin... I say just give it a dummy file, unless you actaully need Norwegian?
In Terminal, must be admin:
touch "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Required/Plug-ins/PDF Suite.aip/Contents/Resources/no.lproj/InfoPlist.strings"
That will give it a 0 byte file of that name, might be happy after that? This patcher needs a more graceful error handling routine.
I had previously used XSlimmer on my Mac to delete unnecessary binaries and languages, which turned out was the problem for Illustrator. Thankfully, XSlimmer has the option to make backups of what you slim, and I did that when I ran it. So I just used XSlimmer to restore the application, ran the updater, and all is well!
-Craig
I have CleanApp but never used to remove language lproj folders. I also have monolingual but I excluded all Adobe and MS Office products from removing lproj folder. My log below indicates Dependency Subscribers Error, but nothing else. Please help. Thanks. *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=* Visit http://www.adobe.com/go/loganalyzer/ for more information *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=* *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=* START - Installer Session *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=* RIBS version: 3.0.122.0 OSX version: 10.6.4 ::START TIMER:: [Total Timer] CHECK: Single instance running CHECK : Credentials Load Deployment File deploymentFile option not given Create Required Folders Assuming install mode Looking up install source path Sync Media DB ... ::START TIMER:: [Sync Media DB] Pre check media db sync End of Pre check media db sync. Exit code: 0 :: END TIMER :: [Sync Media DB] took 107 miliseconds (0.107 seconds) Ready to initialize session to start with ... ::START TIMER:: [CreatePayloadSession] -------------------- BEGIN - Updating Media Sources - BEGIN -------------------- Updated source path: /Volumes/AdobeIllustratorCS5/AdobeIllustratorCS5 Updating media info for: {7A75E573-6909-4D48-BDFA-D8ED118605A6} Type: 1, Volume Order: 1, Media Name: AdobeIllustratorCS5 Path: /Volumes/AdobeIllustratorCS5/AdobeIllustratorCS5/payloads/AdobeIllust rator15-mul-030810123040/AdobeIllustrator15-mul-030810123040.dmg -------------------- END - Updating Media Sources - END -------------------- Supported RIBS version range: [0.0.66.0,3.0.122.0] ----------------- CreatePayloadSession: machine is x86 --------------- [ 0] Thu Aug 12 20:58:45 2010 INFO ______ Verify Dependency Subscribers ______ [ 0] Thu Aug 12 20:58:45 2010 ERROR The base product has been moved or trashed, Unable to proceed with the patch operation [ 0] Thu Aug 12 20:58:45 2010 INFO :: END TIMER :: [Total Timer] took 13196 miliseconds (13.196 seconds) DTR = 0.303122 KBPS (0.000296018 MBPS) -------------------------------------- Summary -------------------------------------- - 0 fatal error(s), 1 error(s), 0 warning(s) ERROR: The base product has been moved or trashed, Unable to proceed with the patch operation Search the same string above to find when the error occured. --------------------------------------------------------------------- ---------------- Exit Code: 29 - The base product has been moved *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=* END - Installer Session *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* =*=*=*=*=*=*=*=*
