When I run FlexPMD 1.1 via Maven, it only checks the main source tree (src/main/flex). How can I get it to also check the test source tree (src/test/flex)?
We removed the read-only flag on this parameter. It is still defaulted to the build sourceDirectory though.
Tom's solution would now work then.
The trunk and the snapshot repository have been updated.
Cheers,
Xavier
In your POM you can add a configuration option:
<plugin> <groupId>com.adobe.ac</groupId> <artifactId>flex-pmd-maven-plugin</artifactId> <version>1.1</version> <configuration> <ruleSet>${basedir}/your-flex-pmd-ruleset.xml</ruleSet> <sourceDirectory>${basedir}/src</sourceDirectory></configuration> </plugin>
Tried that. Build breaks and I get:
[INFO] Error configuring: com.adobe.ac:flex-pmd-maven-plugin. Reason: ERROR: Can not override read-only parameter: sourceDirectory in goal: flex-pmd:report
Cheers,
Xavier
This works as far as running the rules, but the pmd.xml reports the packages wrong (they all start with main.flex or test.flex). Not a huge deal -- I can just add two executions, but then I'll end up with two files.
