Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
simple calculation in ES8
Avatar
Level 1
i am trying to put a simple calculation with an if exception
if(Field2>Field3) then field1=(Field3-Field2)
I cannot get this basic thing to work and I am by no means a programmer.
Thansk for any help!
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
If they are numeric fields the following FormCalc applies to field1.
// form1.page1.field1::calculate - (FormCalc, client)
if (field2 > field3) then
  field3 - field2
endif
Steve
Avatar
Place this script (as FormCalc) in the script editor under calculate:
if (Field2 > Field3) then Sum (Field3 - Field2)
else null
endif
null can also be 0, or whatever calculation you want.
Avatar
Correct answer by
  field3 - field2
endif
Steve
Avatar
Level 1
Thank you! I finally got htis to work. I don't know if the issue was the fact I was trying to put this all on one lline. Very helpful though.
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
