(Sorry for multiple post, just moving this from elsewhere)
Disabling MPE (and make software only) does not work for me. I have tried onboard and add on firewire cards with no luck. I tried VIA and TI chipset cards. I tried default and legacy drivers. nothing works. Not just MPE, the CS5 timeline without MPE won't even play on the firewire device.
Asus P6T Deluxe mobo (built in VIA chipset firewire 400)
12 GB 1600 ram
Nvidia GTX285 graphics
Windows 7 Ultimate 64bit
Sony Z1U camera, firewire dv in using as a deck
Canon Optura Pi camera - firewire in
Panasonic AJ-D250 deck - firewire in
PPro CS5 5.0.1
I have the playback settings set correctly and the check status shows ONLINE. The units rewind, record and everything but the picture will be a still of the CTI, no live video.
I am going from SD timeline to SD DV/DVCAM format recording.
Time code is set right - DF on the timeline and DF on the recorder, both 30fps.
Cannot export the timeline. Does not play out on the firewire. Only scrubbing shows on the external unit, play does not. Export will get a still of the CTI still frame recorded on the tape. Capture works fine.
So for now I have to export my SD timeline as a DV file and open PPro CS3 and export the file to tape. Every week two half hour TV shows will have to be exported to tape this way. Everything else is wonderful with CS5 PPro but this is frustrating. MPE on or off, does not make any difference. May be it's my combination of hardware. Anybody with this hardware?
-Bala Chandran
If MPE is set to software only and the playback settings are set to DV device, there is no problem with the signal over firewire to a DV deck and external monitor. No problem with DV seguences nor with AVCHD seuences. All the three test sequences in the PPBM5 Benchmark have no problem in giving out the signal over firewire.
Make sure your playback settings are like this:
But how many Premiere users will send out audio as well? Seems like most will use Desktop Audio as the norm.
Only those that do not want serious out-of-sync issues. Signals over firewire have a noticeable delay of nearly 1 second, and if you want to hear that all the time, you would use Desktop Audio. If you want video and audio synched, you want External Audio.
Good News! I was able to print to tape using the "firewire" connection. I followed Harm's directions and seemingly have no problem..I set a test "print to tape" and all is well. Since I don't have a CUDA video card, the MPE Options are greyed out. One odd thing happened that may or may not be related. After foolinjg around with connections and settings, I unplugged the firewire cable from the deck, then plugged it back in. Immediately CS3 opened! Suddenly my firewire connection from CS3 was live. Then I switched back to CS5 and it also was live. Weird!
As long as it works! Fortunately most of the Broadcasters and Cable Co's I deliver content to are accepting either .MOV or MPEG-2 files. I can actually see the day when Tape will be "quaint".
Thanks for everyone's help on this. If any of you need me to perform tests, just ask.
It's not quite that bad on my system, maybe only a few frames. Certainly not enough to worry about even when a client is watching.
But even with the delay, I bet Desktop audio is still the far more common usage. DV out really does need to work correctly with that option selected.
Having followed the advice on this and previous threads my problems also seem to have been resolved so thanks to all. I would welcome clarifiaction on just on more point. In order to make it work I have switched MPE to software only. Is this still necessary having made all the other settings adjustments and what am I losing by not using MPE for this function please? I would love to know.
It sounds like the Auto-Play was set, at some point, to open CS3 when a firewire device is connected. There's a system preference for that.
I am beginning to gain a better understanding of the problem. I am using a new high spec PC running Windows 7 with a GeForce GTX 285.
I am running a trial version of Premiere Pro CS5.
My input/output of audio/video is via Firewire to a JVC MiniDV player/recorder.
I feed output from the JVC player/recorder via an S-VHS cable to a Hi Resolution JVC broadcast monitor.
When I complete a project rendered with MPE nothing gets to either the player/recorder or monitor.
When I re-render in software only mode the player/recorder receives the footage and records it on the tape and displays it on the monitor. But, the image in the PC output monitor freezes. If I scrub the timeline thing start to move for a bit then stop.
This is something I never experienced using PP5.1.1.
I have not yet worried about audio as this is not essential at this stage and can be monitored during editing.
Not sure if this helps clarify or just confuse the issue but would welcome any areas of similar experience of indeed solutions.
