I wonder what will happen if more than one members of
a netgroup publish video and audio with the same stream name at the same time; and all the members of the netgroup play the very same stream. the video will come in one by one or whatever? By the way, the the netgroup enables multicast
groupSpecifier.multicastEnabled = true;
groupSpecifier.postingEnabled = true;
groupSpecifier.serverChannelEnabled = true;
The scenario is quite common in a video conference room.
Thanks in advance
if more than one stream is published to a group with the same name, then the data for all of the streams will flow through the group. however, each subscriber to that named stream will select/latch onto just one of them. there's no way to control which one each subscriber selects, though. if they're all active, then the first one from which a subscriber receives any data wins. if the stream onto which a subscriber has latched goes idle, then the subscriber will un-latch and selection will again be up-for-grabs to the first of the streams from which data is received.
each time a subscriber latches onto a new/different stream, you'll get a NetStream.MulticastStream.Reset NetStatusEvent.NET_STATUS event. you won't get one of those if the subscriber un-latches but then reselects the same stream.
if you're concerned with rogue publishers in a group, same name or not, consider adding a publish password to the group specification.
if the 4 streams each have different names, you can make 4 NetStreams for the same group/groupspec and play one of the streams in each. regardless, all 4 streams will pass through every peer, so if your application isn't going to show all 4 streams simultaneously, they should probably be in separate groups.
if the 4 streams each have the same name, then each receiver will select at most one of them to display to the user, but all 4 will pass through each peer.
if that's not what you meant, please be more specific about what you mean by "issues".
yes, as long as each stream has a different name. you can watch for the NetGroup.MulticastStream.PublishNotify/UnpublishNotify events to see what streams are available in the group and adapt dynamically.
note that in the N:N case, where everyone in the group is publishing and subscribing, it's more efficient to use DIRECT_CONNECTIONS, since the same amount of stream bandwidth (on average) needs to flow AND you can eliminate the group and multicast stream overhead.
So by listening to the publishnotify event I should be able to get the stream name right??
And how should i go about the Direct_Connections method if I dont know the peer ids of the group members...
Right now I am just creating a new NetGroup for each user and publishing his stream in that netgroup and at the same time listen to the incoming streams coming from the other netgroups. I know that the process in not proper but I am not sure how to do it with direct connections....
Thanks for your help..
