I am trying to generate a tabular report, but I encountered a weird bug: if the content of a column exceed the first page height, in the second page the borders of the other columns (that don't exceed the first page) don't display.
The result is obviously ugly because it breaks the table-like layout.
In this second image, note that the borders of "Short Column 1" and "Short Column 2" don't appear
I tried all the settings (stretch etc...) of report band and fields, with no success.
I could also provide a sample test page, with a simple report that behaves exactly as our production report. I ran it to produce the attached images.
Any suggestion will be greatly appreciated
Thanks in advance
I think you need to take a look at the option called
'Stretch with overflow' under the formatting section. This basically means it will stretch if the text in the cell is bigger than the cell at its current size.
In the print control section you should select the strech type to be 'relative to band height'. This will then make the cell the same height as the largest cell.
