How do I change the p0 in the document set up to inches? I already tried changing in the preferences, but it reverts back to the p0 which I don't even know what that is.
Welcome to the world of graphic design. First time visitor, are you? "p0" is nothing -- it's "0p0", and that stands for zero pica's and zero pica points.
The online help for "measurement units" answers your question: http://indesignsecrets.com/change-measurement-systems-on-the-fly.php
p is picas and points. 2p would be 2 picas. 2p6 is 2 picas, 6 points. There are 12 pts in a pica.
Open a new ID doc, click in the ruler at the top and right click. Convert to inches. Click in the ruler along the left side, right click and convert to inches. This should now be your new default setting.
To change your default unts:
Close all open documents.
Open InDesign Preferences
Go to Units & Increments
Set Horizontal and Vertical Ruler Units to desired option (such as Inches)
Click OK
That will set your units for all future documents.
Existing documents will have to be changed when opened.
Personally, I use Points, set to 72 pts per inch. I feel I have more control over object size and placement.
I do not use picas, so I cannot comment on how useful they would be. 6p0 would be equivalent to 1 inch, or 72 points.
I use points beacuse:
Still, it is my personal preference. It is not the only way to do things.
-mt
PS: When you set the preference using the rules, you are setting the document preference. Though, each ruler can be different. For instance you can have inches vertical and picas horizontal.
You can leave your document as Pica for the measurement.
When you create a new documeent simply type in
8.5 inches
10 inches
and it will convert to the pica equivalent.
That's fine. You can then use Picas as the ruler.
I used to do all my measurements in picas but I found that others couldn't use them so I reverted to millimeters.
In fact - you can type in any measurement anywhere
Say if you are using inches as you're ruler and you want to move the X Co-ord a fraction of an inch.
You can simply type into the X Cords in the top right which will read say 4 in - after this type in "+1p"
Which will move the selected item 0.166 of an inch, your new coord will be 4.166
And you can do that with loads of things in indesign, simply add, substract, divide using "+", "-", "*", "/" anywhere where a numerical meaurement is used, and use any measurement available.
It is not a bug, though at first glance it may seem to be.
With no documents open, changing the preference sets the new preference for
future documents without altering any existing documents without your
direct intervention..
With a document open, changing the preference affects ONLY the open
document without chancing your workspace.
So, if you prefer to work in Pica's and have a one-off project that demands
the file be delivered in mm, you can change the document without impacting
your personal workspace.
It may seem like a hassle to work the preferences this way, but I believe
it gives more control to the designer.
-mt
For additional information on specifying measurements, see Rulers & Measurement Units help article. The article also contains a table with examples on how to specify values using non-default units.
