CS4 Photoshop How do I reverse a clipping path.
Mar 15, 2010 11:15 AM
I made a clipping path and accidently clipped the outside of the bottle instead of the bottle. How do I reverse the clipping path? I know there is some icon that is supposed to show up on the top control bar but I am not finding anything.
Thank you.
    Mar 15, 2010 11:29 AM   in reply to NTC Ann
    Select>Inverse -or- Shift+Command+i
    I think you will have to convert the path to a selection first though.
    Mar 15, 2010 12:14 PM   in reply to NTC Ann
    Control+Click inside the selection and choose Make Selection.
    Once you have made the change then you can use the same command to change the selection back into a Path.
    Mar 15, 2010 1:10 PM   in reply to NTC Ann
    Select the path with the path selection tool (solid arrow). Then click on the Add icon (1st of 4) in the options bar at the top. Let me know if that doesn't work.
    Mar 15, 2010 3:15 PM   in reply to NTC Ann
    Ann - yes you've been misadvised a little in this thread. Printer Rick has your correct answer. Whether paths include, exclude or intersect is controlled with these buttons …
    Mar 15, 2010 4:14 PM   in reply to Reynolds (Mark)
    And you can avoid having to switch the mode of the path, by setting the options for the path/pen tool BEFORE you draw the path. Icons are the same, on the right end of the options bar. Also make sure you are in Path mode, not Shape Layer.
    Mar 16, 2010 6:20 AM   in reply to NTC Ann
    Window: Options.
    Then select the Path Selection tool (solid black arrow)
    You should see 4 path options near the left.
    If you have sub paths, sometimes combinations of the options produces the correct result.
    Something else to consider: you can choose to use shape layers instead of paths. But to get vector output using shape layers, you have to save the image as a PDF. The advantage with shape layers is that you can see the clipped result in Photoshop, and everything outside the path is transparent.
    Mar 16, 2010 8:07 AM   in reply to NTC Ann
    Refer to screenshot:
    If you want to attach a screen shot use the little camera icon when posting.
    As far as the shape layers, the path options work the same way for those. The advantage is you can see the clipped result right away in Photoshop, like in my screen shot. I was just offering another option to produce a clipped image and output, but you don't have to use shape layers if you don't want to.
    Mar 16, 2010 9:12 AM   in reply to NTC Ann
    The 2nd icon (subtract) would be an inverse of the first (add).
    Normally to create a compound path (like a donut), you can select the entire path, then the 4th icon (exclude) so that the inner sub paths are knocked out of the outside path.
    May 20, 2010 1:55 AM   in reply to NTC Ann
    Hi RTC Ann
    I don't know if you ever solved this problem but I just came across it myself and found a (clumsy?) solution:
    1.     Make sure the 'Add to shape area (+)' button is selected in the options bar.
    2.     Draw a small, closed path, i.e. a triangle, inside your original path.
    3.     Select both paths.
    4.     Click the 'Combine' button in the options bar.
    5.     The path will now switch to masking the background instead of the contents.
    Aug 18, 2010 6:39 AM   in reply to NTC Ann
    I've found that if you copy the inverted path (including all the subpaths if it is a compound) and paste it into a new path layer, it will also reverse the path and mask the background, instead of the object. In my experience, it pastes the path into the correct position with the same registration. You may need to re-establish the compound.
    However, if the outline of the canvas is included in the path, do not include it in the copy/paste action. Delete it.
