Programmatically Select Items in a List using service results?
Aug 19, 2010 10:05 AM
Hello Adobe Forums, I hope this post finds you well.
Flex n00ber here and I sure could use some help understanding this process.  It's killin' me!
I have a ComboBox being populated by a system service array of values. (getSystems())
I also have a multi-select enabled spark List being populated by a different service. (getIterations())
The label values for the spark list are just numbers 1 through 15.
What I'm trying to achieve:
When I select a system in the cbo box, I need to call a service that returns an array of the values associated with that selected system and then programmatically select those values in the spark list.
I do have a service that returns an array of that data based on the value of the cboBox.selectedItem.sysID. (getIterationsBySysID())
What does it take to make this happen?
I hope I explained this in a meaningful way.
ciao,
-aaron
    Aug 19, 2010 10:03 PM   in reply to Aar0nm
    Hi
    Just set the selected items property of the list control with the array thet u are getting from the service or
    match the service results with the complete data in list and find the index of each and every item that has been returned from the service and
    push the index values to an array and assign the array to the selected indices property of list .
    This will show all the  index values as selected.
    May 1, 2012 4:48 AM   in reply to Aar0nm
    spark.components.List has spark.components.SkinnableDataContainer in its class hierarchy which dispatches a dataProviderChanged event whenever the dataProvider changes. Unfortunatly there is no [Event] metadata in SkinnableDataContainer that allows using this event in MXML. So, you'll need to create your own custom component that extends List.
    package
    import spark.components.List;
    [Event(name="dataProviderChanged", type="flash.events.Event")]
    public class MyList extends List
    public function MyList()
    super();
    This works with other List-based components (like DropDownList) too.
