we have a HTTPService call to server url which returns data in xml format in response. The server call normally takes more than 2 mins to process..
The service call returns with a fault (Error #2032: Stream Error).
It worked fine in 1.5 but with release of 2.0 it started giving steram error even for HTTP calls. We changed our code to Air 2.0 and used
URLRequestDefaults.idleTimeout = 1200000;
to set all requests a default IdleTime out.
But still this doesn't seem to work correctly. It returns fine some times but goes to Fault most of the times.
This issue is kind of critical as it has made our app unusable.
Any thoughts or ideas ?
Brijesh
Hi Chris,
I did sme time monitring when it times out.. if the request takes more then 3 mins it gives the stream error.
I more thing you would like to look at. With AIR 2.0, we have to use idleTimeout parameter mandatory else all requests taking beyond 30 secs are returning stream error.
So if I am keeping my app on 1.5.x and running with 2.0 run time. its failing with all the requests above 30 secs.
I have IE 7.
Brijesh
Hi Brijesh,
Is it possible for you to send me your project (or sample code that displays this behavior)? I've asked around and our timeout behavior did change for 2.0. In 1.5 it was 60 minutes (for some platforms) and in 2.0 we set it to a consistent 30 seconds across all platforms with the idleTimeout allowing you to extend beyond that. We're concerned that you are receiving a stream error, we were expecting a timeout message instead. We did not run across this problem in testing so getting sample code would be very helpful.
Chris
Hi Chris,
I can't share the project as its a secured application. Here's the code which I am using .. (I have replaced actual url with dummy)
var myService:HTTPService = new HTTPService();
myService.url = "https://myserver.com/somerequest.framework?"
myService.resultFormat = "e4x";
myService.requestTimeout =1000000;
myService.method = "get";
var parameters:Object = new Object();
parameters["someparams"]="test";
myService.addEventListener(ResultEvent.RESULT,onMyServiceSucess);
myService.addEventListener(IOErrorEvent.IO_ERROR ,onMyServiceFailure)
myService.addEventListener(FaultEvent.FAULT, onMyServiceFailure);
URLRequestDefaults.idleTimeout = 3600*1000;
myService.send(parameters);
The url requested does some processing on the webserver, and that processing at times takes beyond 3 mins. around 4-5 mins at times.
Without the idleTimeout parameter it times out at 30 seconds. There's no issue with server's ssl certificate as well. Coz it works for requests that are very small and are on https.
below is the error messgae from the fault event:
body = ""
clientId = "DirectHTTPChannel0"
correlationId = "7372C281-545C-9757-9E01-6052BD5EF8F1"
destination = ""
extendedData = (null)
faultCode = "Server.Error.Request"
faultDetail = "Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032" errorID=2032]. URL:
faultString = "HTTP request error"
headers = (Object)#1
DSStatusCode = 0
messageId = "E872BCD0-6607-D721-ABCE-6055CAC7A283"
rootCause = (flash.events::IOErrorEvent)#2
bubbles = false
cancelable = false
currentTarget = (flash.net::URLLoader)#3
bytesLoaded = 0
bytesTotal = 0
data = ""
dataFormat = "text"
errorID = 2032
eventPhase = 2
target = (flash.net::URLLoader)#3
text = "Error #2032"
type = "ioError"
timestamp = 0
timeToLive = 0
Note:
I have tried both with http and https. , same error
I have tried with and without the requestTimeout parameter of the httpService, same error
I have also tried by adding a sleep in the java on server to simulate the longer processing time on server., same error
I have tried with both "GET" and "POST" , same error
I have tried same calls using URLLoader (URLRequest) as well.. same error.
I have tried playing with timeout and keepalive of IE's internal settings in registry, still same error.
It might be something to do with IE ?
I have one concern though.. AIR 2.0 mandates timeouts to 30 secs.. which is a great risk for existing 1.5 apps to break, if the users upgrade to 2.0.
It should not have been mandatory timeout at 30 secs.. It now forces all such apps to migrate to 2.0 namespace
let me know if you need anything else, I am ready to help on this.
Brijesh
Message was edited by: patelbrijeshn
Hi Brijesh,
I did a few tests this afternoon and wanted to report back with my findings. I tried these tests on OS X 10.6, Win 7, and Win XP with IE 7. I focused mainly on IE 7 since that was the browser you reported you were using. All OS's had the AIR 2.0.2 runtime installed.
I used your sample code and had a simple server side script that I could pass a delay parameter too. I set the server's delay to 5 minutes. Here's the php code:
<?php
$delay = 0;
if ( isset($_GET["delay"]) )
$delay = intval($_GET["delay"]);
if ( $delay > 0 )
sleep($delay);
echo "Delayed " . $delay . " sec";
else
echo "Usage: " . $_SERVER['PHP_SELF'] . "?delay=n in sec<br>";
My first test was to build the AIR app with the namespace set to 1.5, comment out the idleTimeout line, and use Flex SDK 4.0 with the AIR 1.5.3 SDK. Once built, I tested the app with XP (again, using the AIR 2.0.2 runtime) and the app did not timeout at 30 seconds. Instead it completed successfully after 5 minutes.
Next I changed the app's namespace to 2.0, left the idleTimeout line commented out, and built using Flex SDK 4.0 with AIR 2.0.2 SDK. My test on XP did timeout after 30 seconds (which is expected behavior. See the note below.)
Finally, I modified the code one last time by uncommenting the idleTimeout line and rebuilt. The app ran and successfully completed at the 5 minute mark. I tried this a few times with the same results.
While I have been unsuccessful reproducing your error at the 3 - 5 minute mark, I do think we can safely say that building an app with AIR 1.5 and running it on a 2.0 runtime should not break any older behavior (30 minute timeout).
I found a great post by Chris Thilgen on the now defunk AIR 2 Beta forum that gives background on the history of the idleTimeout parameter for others interested:
Believe it or not...yes...the version of IE can affect how AIR works. AIR takes advantage of the Windows networking/HTTP stack to accomplish many of its internal functions. And every version of IE updates/modifies the Windows internal networking/HTTP stack in (sometimes subtley) different ways.
The issue that you are seeing is a change that was made between IE 6 and IE7-8. In IE6 the timeouts for many operations were either unbounded - or so long that it would normally not matter. In IE7-8 things got a little more strict and the timeouts can start kicking in.
Your best option here is to make use of the new URLRequest.idleTimeout property introduced in AIR 2 to ensure that your requests are given enough time to complete.
The following is some information I prepared to a similar response earlier in the beta program.
Please let me know if it gets you rolling again.
Chris Thilgen
AIR Engineering
We have made a change in the AIR 2 Runtime which affects the network timeout value - and this behavior varies depending on the value of your application's namespace and the platform on which you are running your application.
Windows
1.5.1 content 60 mins (legacy)
1.5.2 content 60 mins (legacy)
1.5.3 content 60 mins (legacy)
2.0 content PLATFORM_DEFAULT or value specified by URLRequest.idleTimeout
PLATFORM_DEFAULT = 30 SECS on Windows XP with IE 6.x
varies based on what version of IE
is installed---------------------------------------------------------------------- ---------
Mac
1.5.1 content PLATFORM_DEFAULT (legacy)
PLATFORM_DEFAULT = 60 SECS on Mac OS Leopard---------------------------------------------------------------------- ---------
Linux
1.5.1 content 30 secs (legacy)
1.5.2 content 30 secs (legacy)
1.5.3 content 30 secs (legacy)
PLATFORM_DEFAULT = 30 SECS---------------------------------------------------------------------- ---------
So if you are going to bump your application up to the 2.0 namespace, you should also begin explicitly setting the idleTimeout property on your requests to ensure that they remain open long enough to service your application's needs.
NOTE 1: Instead of setting the idleTimeout property on every URLRequest, you can modify the URLRequestDefaults.idleTimeout property which will modify the default idleTimeout value for URLRequests created after this property is modified.
NOTE 2: The requestTimeout attribute in the mx:HTTPService tag is a little misleading as it does not actually affect the low-level networking stack. The requestTimeout attribute value only affects the Flex classes which are waaaaay above the networking protocols in the Flash Runtime.
NOTE 3: You should be able to modify the idleTimeout behavior of the mx:HTTPService object by modifying URLRequestDefaults.idleTimeout property. We have logged a bug with the Flex SDK team to address hooking up the mx:HTTPService requestTimeout attribute with the underlying URLRequest.idleTimeout in a future release (https://bugs.adobe.com/jira/browse/SDK-22016).
Chris
Hi everybody,
We have a similar problem, but on RemoteObject. I've posted this into bugs forum, but still get no answer. Someone has a clue ?
After tests under AIR 2.0beta2, it doesn't change anything, still 30 seconds limit that cannot be extend on timeouts.
Two questions : Do we need to switch to AIR2 Candidate Release ? (we were unable to rebuild our project correctly on Air2 RC, other bug maybe).
Is following code is correct ?
var service:RemoteObject = new RemoteObject("myDestination");
var operation:Operation = new Operation();
operation.name = "myRemoteFunction";
service.operations = new Object();
service.operations[operation.name] = operation; // this fixes operation.service
operation.service.requestTimeout = -1;
URLRequestDefaults.idleTimeout=REQUESTS_TIME_OUT_IN_SECONDS*1000;
var token:AsyncToken = operation.send();
With this we still have 30seconds time out, event if REQUESTS_TIME_OUT_IN_SECONDS is set to higher values.
setting positive value higher than 30 seconds in operation.service.requestTimeout has no effect.
Thanks for help.
We have upgraded to air 2 runtime and framework.
Air Service call (Remote Object) most of the time takes more than 45 seconds to return from service call and we are getting error:
[RPC Fault faultString="error" faultCode="Channel.Call.Failed" faultDetail="NetConnection.Call.Failed: HTTP: Failed"]
We are setting requestTimeOut for service tag to high number, but it seems not affecting it.
We tried to set UrlRequestDefaults.idleTimeOut property to high number as well as this posting suggests, but it seems not helping.
We did verified that service sides completes work succesfully, but we still getting that error.
Is there a workaround for the problem?
Please advice.
I'm going to look into the RemoteObject timeout issue. Do you have a sample application (and server) that I can verify this with? Please feel free to PM or email me at ccampbel@adobe.com.
Chris
I did more research on the RemoteObject issue and we suspect that this is a Flex SDK issue. It might present itself in AIR because Flex is using a networking class on the inside of the RemoteObject that they are managing the timeout for. I would like to suggest that you either add a new bug in Jira or add on on to the bug "Ensure that requestTimeout properties on any relavent messaging classes set URLRequest.idleTimeout (AIR only)" previously reported.
Chris
Hi Chris,
Thanks for testing it out.. sorry for late reply was stuck with some stuffs..
for 1.5 based app we were using Flex 3.2 sdk and AIR 1.5.0 (not 1.5.3).
we then migrated to using AIR 2.0 sdk with Flex 3.2.0
that might be causing some issues ?
Also, one question, did you try your script ....over the internet or within intranet ?
Brijesh
Hi Chris,
thanks looking at this quite blocking issue for all RemoteObject & AIR developers. You suggest to post me another bug, or to file it in SDK-22016. But we have already posted it in https://bugs.adobe.com/jira/browse/SDK-15403, which in fact seems more appropriate reading bug title description.
Regarding posting you a sample, I did it in that thread with the client side, but our server side is Java EJB 3 + Granite DS environment and would be not useful to post you a piece of code. To reproduce it is fairly simple, just have a server - side service that takes more than 30 seconds, and call it with my piece of code above, from an AIR Native application (debug or release mode). This will timeout after 30 seconds, and return the [RPC Fault faultString="error" faultCode="Channel.Call.Failed" faultDetail="NetConnection.Call.Failed: HTTP: Failed"]
Cédric,
I have added a bug at http://bugs.adobe.com/jira/browse/FP-4934. It is listed as a Flash Player bug because it is actually an AIR player bug but there is no category specifically for AIR.
Brijesh
As you noted, my tests were done with Flex 4.0 but our automation builds that test this feature out use Flex 3.2 and they also pass.
I initially tested this with our intranet, but I just did another test using a server outside our firewall.
Have you been able to reproduce the problem using the simple delay.php?
Chris
patelbrijeshn wrote:
Hi Chris,
Brijesh
Hi Cédric
Thanks for commenting on SDK-15403. Since that bug has been marked Closed/Fixed it might be best to vote/comment on SDK-22016 and FP-4934.
Chris
VilleFluide wrote:
Hi Chris,
Cédric,
Hi Joe
Thanks for opening up a new bug. I made a comment also referring to SDK-22016 and voted.
There was a change introduced to the networking sub-system in AIR 2 which will cause RemoteObjects (which make use of NetConnection for their communication) to have a shorter idleTimeout on Windows when using the AIR 2.0 namespace (usually around 30 seconds but varies depending on which version of msinet.dll is installed).
We are working on a resolution for this issue to be included in the next release of the AIR Runtime.
Please refer to the following item in the Flex public bugbase for additional information:
At this time, the only known workaround for RemoteObjects is to publish your AIR application with a namespace less than 2.0.
Chris Thilgen
AIR Engineering
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
