Hi everyone.
I'm having troubles with this functionality in the detailed view of a space.
I always get:
'Failed to retrieve form design fields from the document.'
I´ve tried saving the form design on LiveCycle Designer in every possible way (Static PDF, Dynamic PDF, XDP, etc)
The worse thing is that I haven´t been able to find good documentation on this item.
Thanks a lot in advance for your help.
Best regards,
Hector Castro M.
Solved! Go to Solution.
Total Likes
The form can be either an XDP or a PDF but the form must have a schema associated with it for this feature to work. You must also choose the embed the schema option in the Form Properties for the fields to be extracted. I have included a sample form that has the schema embedded in it in boith XDP and PDF formats.
Paul
Total Likes
Paul
Total Likes
Thanks Paul,
It worked fine.
Hector.
Total Likes
