I got above error when I tried to export a release build, the problem is the ***-app.xml, there is a line in the file:
<supportedProfiles>extendedDesktop</supportedProfiles>
which the air doesn't support extendedDesktop, I am using the Flex SDK 4.1.0 and Air SDK 2.0.2 and I have to use the extendedDesktop because I need access native process. any one has some ideas to fix this problem?
you need to add the desktop profile after the extendedDesktop:
<supportedProfiles>extendedDesktop desktop</supportedProfiles>
Thanks! This solution also works for me.
if i add 'desktop', it get error 306. Because i need to use a native extension.
is there any other way to solve this? and why it not support when only 'extendedDestop'
After editing my app.xml with <supportedProfiles>extendedDesktop desktop</supportedProfiles>, it throws this error.
Unknown error geenrating output application.xml files. Check the Eclipse error log for more details.
Where is the error log file ?
Sorry, the problem is local on my PC. Your solution works.
CT
Thanks. This solution also works for me.
