I've designed an evaluation form for work with numerous categories, each of which has an associated radio-button group to rate the individual in that category. The radio buttons are "N/A 1 2 3 4 5" As they're set up as exclusion groups, checking a value will clear other values for that particular item that may have been previously checked - this is working just fine.
However, the boss just asked me today if there's a way to reset *all* the values for a particular item to a blank state. An example would be say "Leadership" for which you've given someone a rating, only to find out that individual doesn't *have* any subordinates. I would say "then check N/A instead" but he wants to totally clear that item, so it's as if nothing were ever checked.
I'm doing this in LiveCycle Designer 8.0.
Any help would be GREATLY appreciated!
**Moderator: please feel free to move this to whatever other forum is applicable**
And I do that how exactly?
Points to blinking "CLUELESS" sign overhead
Assuming I know next to nothing in this regard would probably be a safe bet!
I think what I'd need would be a button at the beginning or end of each
exclusion group labelled "reset" that'd do this.
Albeit, it's going to be tedious, as there's dozens of items in this eval
form!
I have attached a sample form. In Designer, slect the button on the form and then look at the
Click event in the script window.
Also, you might try posting at http://forums.adobe.com/community/livecycle . this current forum you are posting to is really geared towards LiveCycle Trainers. The link I provided is more for the developer community and you will find more resources there.
Good luck
