I'm just casually trying the 'HQ Broadcast' on blogTV.
I've tried to mess with the settings as far as I can understand, also tried with a fresh XML file without any changes.
In the log it just complains:
"Unexpected error encountered in encoding process."
So, the softwares expect errors these days?
And the complete error message keeps looping as far as I like.
The stream still gets updated, like, every 5 seconds.
Well, I changed to another sound source and everything seems fine. But no video or sound is going through even though it seems to be loading the stream at the viewer's end.
The error "Unexpected error encountered in encoding process." generally comes when one of your audio or video devices is not working properly. In such a case, FMLE tries to re-start encoding after giving the above error. This will go on, until the user presses the stop button.
You say that on changing the sound source, everything seems fine. Do you see the video in the input and output video preview windows ?
Could you please tell the your audio and video device you are using in both cases as well.
I could see everything in realtime of the right video box, the left one is a bit smaller and no video. Not sure which one is which.
I used my G35 headset's microphone at first. Then changed to line-in. I have a cable from my audio out to line-in, so I can eg. record my computer's sounds, and useful in this case too, when I don't mean to speak.
