Learn about Edge Delivery Services in upcoming GEM session
SOLVED
how to get total page count
Avatar
Level 2
Is there anyone know how to get the total page after we generate the pdf file. I'm using the rest method and create a out process.?
1 Accepted Solution
Avatar
Correct answer by
Level 2
In workbench I use a SetValue
Before you assemble the document you need to build the DDX string and specify you want the xml info.
concat(/process_data/@ddxHeadStr, ' <DocumentInformation source="mergedPDF" result="doc_info.xml" />')
AFTER Assembly
Use SetValue set your xmlinfo variable (type xml) to this
/process_data/xmlInfo Set TO
/process_data/assemblerResult/object/documents[@id
="doc_info.xml"]
Then get your pages from the XMLinfo
/process_data/@numPages
/process_data/xmlInfo/DocInfo/NumPages
Hope this helps.  Email if not clear.  I had to fight through this recently and feel the documentation is really lacking.
Avatar
Level 8
Page count is one of the data points returned when you use the docInfo tag in a DDX.
Avatar
Level 2
do you have any specific information, more details, sample? thanks for quick response
Avatar
Level 8
DocInfo is a tag set that is part of the DDX command file.  LiveCycle Assembler uses a DDX file to determine what it is supposed to do to a file.  Have a look at the DDX reference guide: http://livedocs.adobe.com/livecycle/8.2/ddxRef/001000.html
and specifically at the Doc Info part:
  http://livedocs.adobe.com/livecycle/8.2/ddxRef/001170.html
(You can see the table of contents from the above links by clicking on the "Show Navigation" icon in the upper left)
Avatar
Correct answer by
Level 2
AFTER Assembly
="doc_info.xml"]
Avatar
Level 2
Finally, I got it works. A Big thanks for all helping me.
Avatar
Former Community Member
Using DDX how to get the total number pages for given PDF/binaryData, please give the sample code
Avatar
Hi tried to modify DDX with
But how can get the doc_info.xml and how to get the number of pages ??
Avatar
Level 1
I am attempting to split a PDF that is input into a process via a watched folder. I have a sample DDX process that works to split it apart into individual files, but the default page number is hard coded in this sample. I tried using the method above to get the number of pages from the input PDF instead of the merged PDF, but I am getting errors. Should this work to get the total pages if the PDF is not the result of a DDX assembler process?
