hdkhiem
how to get total page count
Aug 26, 2010 1:18 PM
Is there anyone know how to get the total page after we generate the pdf file. I'm using the rest method and create a out process.?
    Aug 26, 2010 1:23 PM   in reply to hdkhiem
    Page count is one of the data points returned when you use the docInfo tag in a DDX.
    Aug 27, 2010 6:07 AM   in reply to hdkhiem
    DocInfo is a tag set that is part of the DDX command file.  LiveCycle Assembler uses a DDX file to determine what it is supposed to do to a file.  Have a look at the DDX reference guide: http://livedocs.adobe.com/livecycle/8.2/ddxRef/001000.html
    and specifically at the Doc Info part:
      http://livedocs.adobe.com/livecycle/8.2/ddxRef/001170.html
    (You can see the table of contents from the above links by clicking on the "Show Navigation" icon in the upper left)
    Aug 27, 2010 10:29 AM   in reply to hdkhiem
    In workbench I use a SetValue
    Before you assemble the document you need to build the DDX string and specify you want the xml info.
    concat(/process_data/@ddxHeadStr, ' <DocumentInformation source="mergedPDF" result="doc_info.xml" />')
    AFTER Assembly
    Use SetValue set your xmlinfo variable (type xml) to this
    /process_data/xmlInfo Set TO
    /process_data/assemblerResult/object/documents[@id
    ="doc_info.xml"]
    Then get your pages from the XMLinfo
    /process_data/@numPages
    /process_data/xmlInfo/DocInfo/NumPages
    Hope this helps.  Email if not clear.  I had to fight through this recently and feel the documentation is really lacking.
