I am using text layout framework and getting an error type was not found or was not a compile-time constant: ImportExportConfiguration. I am using Flex Builder 3 , Flex SDK version flex_sdk_4.0.0.10485 and flash player 10.0.12 , Surprisingly this error not located in my project workspace.
In my code i uses
import flashx.textLayout.container.DisplayObjectContainerController;
Help
Gaurav kumar Pandey
You are using an older version of our code. I suggest you update to the latest code, see: http://opensource.adobe.com/wiki/display/flexsdk/Flex+SDK.
You don't need to use the Flex Framework, but it comes with the latest textLayout libraries and source code.
Hope this helps,
- robin
Thanks Robin,
I have solved the problem but fall under the new problem what i did used the sdk version flex_sdk_4.0.0.6175 and it shows a new prblem Severity and Description Path Resource Location Creation Time Id
1046: Type was not found or was not a compile-time constant: [flashx.textLayout.elements]::ITextLineCreator.
plese help me
Thanks and regards ,
Gaurav kumar pandey
Can you tell me what is the code you are trying to run? You have TLF, and you are trying to run it with some code. Can you tell me what that code is? Does it work with a very simple example? ITextLineCreator is an old API, that is not present in the new code. But if you are trying to run TLF with some old example code, that could explain your difficulty.
- robin
You can also get the documentation for a particular Flex SDK 4 build under the "Language Reference" links here:
http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+4
This will include the docs for the TLF build that SDK uses.
Hi Nikita,
Sry for the delayed response, there is two possibility for that:
1. If you using Flex Builder
path of your flex bulder exe //pro file/adobe... put a space and write -cleane option
After error removed put back your removed sdk 3.5 to it's original location
2. If you using flash builder 4 then no need to do all the above exercise just change the Flex sdk version(if point flex sdk 3.5 ) to sdk 4.0.
Hope above solve your problem.
FAny further query or suggestion is most welcome
Gaurav Kumar Pandey
I have same problem with can't use TextConverter.importToFlow(...) , it show "type was not found or was not a compile-time constant: ImportExportConfiguration".My lib have a textLayout.swc component and I use it,my code as flow :
import .... ;
public class SimpleEditor extends MovieClip
private var _textFlow:TextFlow;
public function SimpleEditor ()
var loader:URLLoader = new URLLoader();
loader.load (new URLRequest("SimpleText.xml"));
loader.addEventListener (Event.COMPLETE, loadCompleteHandler);
private function loadCompleteHandler (e:Event):void
_textFlow = TextConverter.importToFlow( e.target.data,TextConverter.TEXT_FIELD_HTML_FORMAT);
why ? if I delete textLayout.swc from my lib, it can work !
hi,
What I am guseeyou uses Flex4 sdk with your application and your lib folder contain older version of textlayout.swc. Once you removed this swc from lib folder your code will point textlayout.swc from Flex 4 sdk folder, and when you have older version of textlayout.swc in your lib folder your code will target to that swc .
Hope you get the answer .Happy programming with TextLayoutFramework.
Gaurav Pandey
It still can't work ! I use Flash CS5 and sdk is 4.0.In publish setting it have textLayout.swc and flex.swc form path of lib.When I add TextConverter.export(..),it show Error 1046: Type was not found or was not a compile-time constant: importExportConfiguration.My code as flow :
package
import flashx.textLayout.elements.TextFlow;
import flashx.textLayout.formats.IParagraphFormat;
import flashx.textLayout.formats.ParagraphFormat;
import flashx.textLayout.formats.ICharacterFormat;
import flashx.textLayout.formats.CharacterFormat;
import flashx.textLayout.formats.IContainerFormat;
import flashx.textLayout.formats.ContainerFormat;
import flashx.textLayout.formats.TextAlign;
import flashx.textLayout.edit.EditManager;
import flashx.textLayout.edit.UndoManager;
import flashx.textLayout.edit.ElementRange;
import flashx.textLayout.edit.IEditManager;
import flashx.textLayout.events.StatusChangeEvent;
import flashx.textLayout.events.SelectionEvent;
import flash.events.Event;
import flash.events.KeyboardEvent;
import flash.events.IOErrorEvent;
import flash.net.URLLoader;
import flash.net.URLRequest;
import flash.display.MovieClip;
import flash.display.Stage;
import flash.display.StageScaleMode;
import flash.display.StageAlign;
import flash.ui.Keyboard;
import flash.text.Font;
import flash.geom.Rectangle;
import flashx.textLayout.conversion.ConversionType;
import flash.events.MouseEvent;
import flashx.textLayout.conversion.TextConverter;
import flashx.textLayout.container.ContainerController;
import fl.events.ColorPickerEvent;
import fl.motion.Color;
import flash.geom.ColorTransform;
private var testFlow:TextFlow;
TextFlow.defaultConfiguration.noFocusSelectionFormat = TextFlow.defaultConfiguration.focusSelectionFormat;
//initWidgets ();
//initStage ();
myTextLayout.xmlText = e.target.data;
initTextFlow ();
private function initTextFlow ():void
_textFlow = myTextLayout.textFlow;
_textFlow.addEventListener (StatusChangeEvent.INLINE_GRAPHIC_STATUS_CHANGED, graphicChanged);
_textFlow.addEventListener (SelectionEvent.SELECTION_CHANGE,selectionChangeListener,false,0,true );
_textFlow.flowComposer.updateAllContainers ();
_textFlow.interactionManager.setSelection (0,0);
_textFlow.interactionManager.setFocus ();
var xmlOut:XML = TextConverter.export(_textFlow,TextConverter.TEXT_LAYOUT_FORMAT,Conve rsionType.XML_TYPE) as XML;
private function initWidgets ():void
populateFontFamily ();
direction.addEventListener (Event.CHANGE, changeDirection);
blockprogression.addEventListener (Event.CHANGE, changeBlockProgression);
verticalalign.addEventListener (Event.CHANGE, changeVerticalAlign);
columngap.addEventListener (KeyboardEvent.KEY_UP, changeColumnGap);
columncount.addEventListener (KeyboardEvent.KEY_UP, changeColumnCount);
textindent.addEventListener (KeyboardEvent.KEY_UP, changeTextIndent);
textalign.addEventListener (Event.CHANGE, changeTextAlign);
lineheight.addEventListener (KeyboardEvent.KEY_UP, changeLineHeight);
fontsize.addEventListener (KeyboardEvent.KEY_UP, changeFontSize);
fontfamily.addEventListener (Event.CHANGE, changeFontFamily);
btnItalic.addEventListener (MouseEvent.CLICK, changeFontItalic);
btnBold.addEventListener (MouseEvent.CLICK, changeFontBold);
fromPicker.addEventListener (ColorPickerEvent.CHANGE, changeColor);
private function initStage ():void
stage.scaleMode = StageScaleMode.NO_SCALE;
stage.align = StageAlign.TOP_LEFT;
stage.addEventListener (Event.RESIZE, resizeHandler);
private function populateFontFamily ():void
// try to add fonts to the drop down
var fonts:Array = Font.enumerateFonts(true);
fonts.sortOn ("fontName", Array.CASEINSENSITIVE);
for (var i:int = 0; i< fonts.length; i++)
fontfamily.dataProvider.addItem ({label: fonts[i].fontName, data: fonts[i].fontName});
//trace( fonts[i].fontName);
private function graphicChanged (sce:StatusChangeEvent):void
_textFlow.flowComposer.updateAllContainers();
private function selectionChangeListener (e:SelectionEvent):void
// set display according to the values at the beginning of the selection range
var paragraphFormat:IParagraphFormat = e.selectedElementRange.paragraphFormat;
var characterFormat:ICharacterFormat = e.selectedElementRange.characterFormat;
var containerFormat:IContainerFormat = e.selectedElementRange.containerFormat;
// update the different comboboxes so their selectedItem matches the current selection
updateComboBox (fontfamily, characterFormat.fontFamily);// font family
updateComboBox (textalign, paragraphFormat.textAlign);// text alignment
updateComboBox (verticalalign,containerFormat.verticalAlign);// vertical alignment
updateComboBox (blockprogression,_textFlow.computedContainerFormat.blockProgression) ;// block progressions
updateComboBox (direction,_textFlow.getComputedColumnDirection());// direction
// update the different text input entries
fontsize.text = characterFormat.fontSize.toString();// font size
lineheight.text = characterFormat.lineHeight.toString();// line height
textindent.text = paragraphFormat.textIndent.toString();// indentation
columncount.text = containerFormat.columnCount.toString();// number of columns
columngap.text = containerFormat.columnGap.toString();// gaps/gutter width
//TextConverter.export(_textFlow,TextConverter.TEXT_LAYOUT_FORMAT,Con versionType.XML_TYPE);
private function updateComboBox (box:ComboBox,val:String):void
for (var i:int = 0; i < box.dataProvider.length; i++)
if (box.dataProvider.getItemAt(i).data == val)
box.selectedIndex = i;
return;
box.text = val;
private function changeFontFamily (e:Event):void
if (_textFlow && _textFlow.interactionManager is IEditManager)
var cf:CharacterFormat = new CharacterFormat();
cf.fontFamily = ComboBox(e.currentTarget).selectedItem.data;
IEditManager(_textFlow.interactionManager).applyCharacterFormat (cf);
private function changeFontSize (ke:KeyboardEvent):void
if (_textFlow && _textFlow.interactionManager is IEditManager && ke.keyCode == Keyboard.ENTER)
cf.fontSize = TextInput(ke.currentTarget).text;
private function changeFontItalic (e:MouseEvent):void
cf.fontStyle="italic";
private function changeFontBold (e:MouseEvent):void
cf.fontWeight="bold";
private function changeColor (e:ColorPickerEvent):void
var clipTransform:ColorTransform=new ColorTransform();
clipTransform.color=fromPicker.selectedColor;
cf.color=clipTransform.color;
private function changeLineHeight (ke:KeyboardEvent):void
cf.lineHeight = TextInput(ke.currentTarget).text;
private function changeTextAlign (e:Event):void
var pf:ParagraphFormat = new ParagraphFormat();
pf.textAlign = ComboBox(e.currentTarget).selectedItem.data;
IEditManager(_textFlow.interactionManager).applyParagraphFormat (pf);
private function changeTextIndent (ke:KeyboardEvent):void
pf.textIndent = TextInput(ke.currentTarget).text;
private function changeColumnCount (ke:KeyboardEvent):void
var cf:ContainerFormat = new ContainerFormat();
cf.columnCount = TextInput(ke.currentTarget).text;
IEditManager(_textFlow.interactionManager).applyContainerFormat (cf);
private function changeColumnGap (ke:KeyboardEvent):void
cf.columnGap = TextInput(ke.currentTarget).text;
private function changeVerticalAlign (e:Event):void
cf.verticalAlign = ComboBox(e.currentTarget).selectedItem.data;
private function changeBlockProgression (e:Event):void
cf.blockProgression = ComboBox(e.currentTarget).selectedItem.data;
IEditManager(_textFlow.interactionManager).applyFormatToElement (_textFlow,null,null,cf);
private function changeDirection (e:Event):void
pf.direction = ComboBox(e.currentTarget).selectedItem.data;
IEditManager(_textFlow.interactionManager).applyFormatToElement (_textFlow,null,pf,null);
private function resizeHandler (e:Event):void
myTextLayout.width = stage.stageWidth - myTextLayout.x;
myTextLayout.height = stage.stageHeight - myTextLayout.y;
_textFlow.flowComposer.getControllerAt(0).container.parent.scrollRect = new Rectangle(0,0,myTextLayout.width,myTextLayout.height);
Did the problem had old version of flex sdk or not import lib or textLayout component not suppose TextConverter.export() class ? please help me, I have source code to download test.My e-mail : hsu.shan.chuang@gmail.com ,tks !
