I have the same issue, after "Forced" upgrade of Adobe, I am unable to read my ebooks. I get message "document is licensed for different user account". I opened a support case with Adobe and this is what I got back.
#180890498
We regret to inform you that our support for Adobe Digital Edition
version is only for download and installation issue. If the problem is
already pass the point of downloading and installation, I'm afraid we
can only refer you to visit the Adobe Digital Edition Support Website to
find information about this free program. You may reach this webpage
using this URL: http://www.adobe.com/support/digitaleditions/
Another avenue where we can lead you to, to find additional information
about Digital Edition is through the Adobe User-to-User Forums.
(http://www.adobe.com/support/forums/).
Once again, we apologize for the inconvenience.
S oessentially, I am forced to upgrade, but they will not fix their faulty software.
Hope someone can help me.
No, they are not. I had a response back to my case basically saying
it's not their problem I have to go to the ebook supplier - QUITE
FRANKLY ADOBE HAVE BEEN UTTERLY USELESS.
Anyway, I'm lucky. I only had two suppliers of ebooks, I contacted
their online helplines (VERY MUCH MORE HELPFUL THAN ADOBE I MUST SAY,
and agreed with them in writing that to solve the problem I could
redownload my books if I deleted them off my computer CHECK WITH YOUR
EBOOK SUPPLIERS BEFORE YOU DELETE ANYTHING JUST TO BE ON THE SAFE
SIDE. So I've deleted the whole Adobe Digital Editions stuff and my
entire library, reluctantly reinstalled it and redownloaded the ebooks
from my suppliers - sorry, I know that doesn't solve the problem for
many people, I'm obviously one of the lucky ones but maybe you can
salvage something.
Needless to say I'm looking around for a different eReader now, with
reasonable support. Check out this site, they supply independent info
on a lot of the eReaders about.
www.whichebook.com
Good luck.
2009/5/7 sumaylee <forums@adobe.com>:
I'm having this same problem too. And it looks like Adobe is not even bothered to resolve this problem.
Hey Adobe -
Next time I need to purchase books for school, can I just send you a check instead. Or maybe I will just flush the money down the toilet. That will save the time of installing useless software. Who has time to chase down Adobe Support for this Digital Editions scam??
Thanks for nothing.
- BooklessStudent
Wow, Guess what problem I'm having. So basically, the pdf book that I have is useless then?
Is there a fix to this stupidity, because I can't call adobe. I waited for 1 hour on the phone and it was lovely elevator music.
Why don't you guys just keep it in the standard pdf format. I've installed/uninstalled authorized/unauthorized like 20 times. No luck
1) If you created an Adobe ID after the installation was completed (and after downloading books) the documents that existed before are tied to the"Unauthorized" computer activation - or if you changed your Adobe ID mid-way through - thus when you active the Adobe ID the following error will occur:
Error - Document is licensed for a Different User Account (Un-license your machine by removing the Adobe ID via: ctrl+shift+D)
** This fix was provided by another user who also was on this forum previously (Thank you)
Also be aware that Adobe Digital Editions does clearly tell the user "when they Activate" the Adobe ID - Confirmation request appears and "Warns" that if any documents are associated to the Ditital Editions Library on the Computer - they will no longer be readable. - It prompts for "replacement" - once you do this - your documents are no longer usable.
2) For the User who has uninstalled and re-installed and continues to receive errors - there is a reason behind it - the software does not cleanly remove all pieces from the machine - thus just "uninstalling" the software is not enough - the following procedure was written for Windows machines.
If your trying to matain previous downloads of EPUB / EBOOKS - complete a back-up of your files
- Back up your documents that are located in the c:\data\My Digital Editions or c:\my documents\My Digital Editions (in some cases you may have to search for the My Digital Editions directory -
1) Uninstall Adobe Digital Editions using one of these two methods:
Start > Programs > Adobe > Adobe Digital Editions >Uninstall
OR
Start > Settings > Control Panel > Add Remove Programs
2) Initiate Uninstall
In order to remove all remenants of Adobe Digital Editions / Adobe Adept from the machine a "Registry Edit" will need to be
performed:
Start > Run > Regedit
Search for HKEY_CURRENT_USER > Software > Adobe> Adept and Delete the full "Adept" folder
Remove only the structures that are under the "SOFTWARE" extensions. This will remove the Adobe ID / License
and Activation Keys
4) Delete all items in the Recycle Bin on the computer - and Reboot the machine
3) Clear any outstanding tasks that may be associated to Adobe Digital Editions downloads
C:\data\my digital editions
C:\my documents\my digital editions
Delete any documents within these folders:
Restore > Tasks
Restore > Failed
5) Re-install Adobe Digital Editions by obtaining the Download Adobe Digital Editions 1.7.1 Installer
for Windows from documents - kb403051 (which is the digitaleditions1x7x1.exe installer) - After locating the fix document - download the *exe file to your local computer
6) Install from the location machine - running the *exe - Take all the defaults (do not change any of the installation settings). Once digital editions installation is completed - Open Digital editions and the Setup Assistant will pop-up - This time utilize the "Do Not Authorize" option on the Setup Assistant
7) After the installation has completed on the machine - take the EBooks / PDF's and place them back into the My Digital Editions directory
Open Digital Editions and click on the "Library" > Add Item to Library - This will default to the My Digital Editions directory - Select a book to add to the library - Validate that the file will open.
I followed the user-posted resolution to the letter, but am still unable to access my textbook (which is divided into two parts, but neither is accessible). I just got a new computer, and didn't realize that when I transferred my digital book I would no longer be able to open it. I agree with all the other posters--the lack of support on this obviously widespread issue is inexcusable. If you are going to put out a proprietary program that many students are having to use for their digital textbooks, then for goodness sake, make it work! How can you implement a program like this, and not offer any post-installation support for it?? That's unheard of! I believe all us students and other consumers who have this issue need to band together for a civil suit against Adobe, and demand our money back--plus compensation for all the time and energy wasted, as well as the aggravation we've suffered.
There are a couple of things that you have to remember here
1) Adobe's software is just that - software. We've all dealt with Good and Bad software
2) The company your downloading your documents from should be able to supply some level of support - espically since they are selling you the documents
3) Adobe's support may not be great or even still "there" - but there are plenty of things that users should do when they work with the software to install it
a) Read the information provided on the screen
b) Note that after you installed Adobe Digital Editions - and you decide to "Register" with an Adobe ID / Password - post document download - that a warning screen is provided to the user - asking you if you really want to continue.
c) Make sure that you have information or at least additional assistance provided by the Company your downloading your Documents from - Adobe isn't forcing these companies to DRM wrap their documents - but Adobe does supply the "Reader" required to read them. So the company selling the documents should be able to assist you in getting your documents downloaded.
4) Just because one thing works for one or two users - it doesn't mean that it will work in all circumstances for everyone else.
In your case you "Changed" computers - dependant on the "DRM stamp" associated to the Document you downloaded - it could be set to only be opened on the specific computer that you downloaded the "original" document to - This is not Adobe's problem - This is a "Digital" encrypted / signed document that was "tied" to the computer you had it on - Meaning that you should probably address this issue with the Company you brought the document from and let them know the circumstances and see if they can assist you on obtaining your documents.
If the Company that sold the document to you "locked" it and it was working just fine before on the other Computer - technically Adobe can't be blamed for the Rights the company tied to the document.
Sorry, as much as the Software can be a pain, you have to take the time to "Inform" yourself.
Ok. So I know this is late, but I have the same problem. I ended up buying the same book twice, and it still never worked for adobe digital edition. HOWEVER, I DID go on the Barnes and Noble website and they have a program that can be downloaded (I am sure you can find it somewhere else too) called eReader. This works for epub files. It isn't the best, but it isn't bad either. eReader can be for ipad, ipod, pc, laptop, whatever....
Several years later, here are the case n
umbers - same situation: 01
81618851, CH281068
10, ch21131133, 02
03526092 -
all the same problem, and all "resolved" by some
non-speaking English speaker who can't und
erstand a simple problem. I try to download a book from
a local library and get the above message. Erase, delete and
reinstall with the same result. I would be willing to pay, who
asked for free, but I would like something that allows me to
read, free, books forom my local library.
Well, for all the people who have posted here pointing out that you had to click on an understanding that your books might not work after you
activated your Adobe account, this is not the case in my situation. I activated my account before I downloaded any books, I have since added 70 or 80 books, I have not changed anything on my computer. I have one account, one copy of Adobe, and a Nook. Each time I open the DE software it gives me this warning message, usually for some files I haven't looked at or activated. It seems to be creating new files that are associated with ,pdf books I have downloaded to my Nook and naming them something similar, then telling me there is an error associated with the file. I have tried deleting the files but they reappear next time I open the program.
I also had a long list of files with numbers instead of names. Each of them said either error or missing next to the information. I deleted them all and then discovered that this removed the downloaded books (through Barnes and Noble) from the Nook.
Adobe DE is also hard to use due to everything being flash based instead of menu based. There aren't many options to do things the way you want to do them.
In my opinion this program is not worth much and I will be looking for an alternative. It is too bad that B&N recommended this program when I bought my Nook. I hope switching programs will not cause me to lose anything on the Nook.
Thank you for your response.
I finally found download remnants ? or whatever from my attempts to download books from my local library. These, hidden as they were, interferred with
my attempts to download my purchases from BN and from other purchase sites. Appeals to Adobe were akin to my requests for Divine Guidance. I agree that technology should be available forproblems like this, even if one had to pay a reasonable one-time fee.
I have the same problem, I purchased a Bebook Neo, 1 week ago and installed ADE authorized computer, did everything right. Downloaded lots of free books, had no problems transfering them onto ADE. Then I bought 2 books from Ebook.com, downloaded and transfered to ADE still no problem. Then I bought books from Barnes&Noble, downloaded just fine, but when I tried to transfer to ADE, I got this message:Document is licensed for different user".Have followed suggestions of uninstall and reinstall, did not work. deauthorized, did not work. Have talked to tech support, not sure if their english is up to the task.Have opened web case, but still no solutions. Does anybody know what to do, please help.
I am having this same problem with books I have download, for free, from Barnes & Noble. I submitted a help
ticket with Adobe and they sent me the following directions. I hope this helps some of you having this same problem.
I would like to inform you that this error comes when the books you are
trying to open were originally purchased with some different ID and nowyou are trying to use some different ID
or in case if the download link for the books is no longer valid.
Hence, I request you to please follow the steps as given below in order
to fix the error.
Solution 1)
1) Open Adobe Digital Editions.
2) Move your e-books to some different Location.
3) Press the keys Ctrl + Shift + D on your keyboard.
4) Now a Deauthorize screen will come up asking you to deauthorize your
Computer.5) Follow the screen instructions and unauthorize the computer.
3) Uninstall Adobe Digital Editions from your computer.
Click start>>Control Panel>>Add or remove Program
Select Adobe Digital Editions from the list and Delete.
5) Also delete following files.
Click Start>>Run
Type "regedit" in the box and hit enter.
Locate the following key "HKEY_CURRENT_USER>Software>Adobe>Digital
Editions" delete the full folder (Right click on it and click delete).
Also locate HKEY_CURRENT_USER>Software>Adobe>Adept
Delete the full folder.
6) Now download and install Adobe Digital Editions from the link given
below. http://www.adobe.com/products/digitaleditions/
7) When asked to authorize computer then please enter same Adobe ID and
password which you were using earlier.
Solution 2) If the above solution does not works then I request you to
please Contact the vendor of books and ask them to reset the links ofthe books.
Hi, unfortunately I dont know what to do, this only happened when I tried to load books from Barnes&noble unto my Bee-book, so I think this is related to Adobe Digital user rights.Adobe was not able to resolve this problem. now I use Diesel e-books to put on my bee-book and i dont have any problems.
have a good day
uli
I have opened a webcase and no one responds. I'm having all types of issues with ADE. First the downloaded books would show up on Digital Editions and my nook as long as it was hooked up to the computer. Once I eject, the books disappear. I followed the instructions for re-registering that I found on this forum. I did this over and over again to no avail. I guess I did it too many times because then I received an activation error. So I called Adobe and they couldn't help. Now I'm getting a "document is licensed for a different user account" error message. Can you pleeeeaaaase help me? My case number is 0182023328.
WOW! Thanks for that last post on deactivating your computer ~ I started a topic about 2 months ago without any response on how to change the authorization of a computer with no replies and now I have this issue happening with the "Document licensed for a different user account" so I was looking here and found at least 1 answer to 1 of my problems!
Thank you, thank you, thank you!!
Now to find the answer to this problem....
So I purchased 3 EPUB books (ALL FROM THE SAME AUTHOR) from Barnes and Noble at the same time. I was able to
add only 1 ONE of these books to ADE, the other 2 gave me this same message.....now that makes no sense at all. I followed the advice from those on this forum; deactivate, uninstall, move files ect ect......nothing has worked. Also I have only had just one account with ADE and I noticed that I am not able to open a case file for free software but would sure like to know how to correct this.... Is Adobe just wanting us to spend $39 to get the answer? Seems so.....anyone call and get help?
That was the issue I was having. I purchased books from B&N and I was told by B&N that you NEED to use the "NOOK" products to open their books - either the NOOK 'ereader' or the NOOK app for PC. Back around Christmas when I received my Kobo Lookbook ereader I had purchased an inexpensive ebook from B&N and had no problems at that time using ADE then putting it onto my ereader. It seems now that B&N - from my conversation with them - has ebooks ONLY supported by the NOOK applications. I did notice that the books I recently purchased were DRM (Digital Rights Management to prevent others from using books on more than 1 app which in their sense is "stealing" books) which means that it was registered to only work with the B&N applications. I am not sure if this is the ONLY reason why we seem to be receiving this message as I have not tried other books. I even used Calibre for my ebook management and that program told me that the books from B&N were DRM and it was unable to open it.
I think if it ends up being an issue with DRM that the books are NOT being able to open on the different ereaders EVEN if they were purchased, the places where we are purchasing the ebooks from NEED to be clearer on whether or not it is going to work on ALL ereaders or just specific ones.
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
