Home/Support/
Forums
582 Views 3 Replies Latest reply: Sep 2, 2010 12:26 AM by Chris_Cap RSS
riggsdar1 Calculating status... 32 posts since
Feb 28, 2007
Mar 19, 2010 12:05 PM
Tabbing between text fields
I've searched through this forum and others for a solution and nothing I've tried helps, including adding the seamless tabbing parameter of false to my HTML file. I'm using Captivate 4.
I have a series of TEBs in a column, each one set to validate when the TAB key is pressed. That part works but I cannot get the cursor to move to the next TEB, instead it moves to the last field or simply "disappears."
Here is what happens when the slide loads:
Cursor in TEB1
Cursor moves to TEB2
Cursor moves to TEB3
Cursor moves to TEB4
Cursor moves ot TEB5
User has to click in TEB1
User enters text and presses TAB key, cursor moves to TEB5
User clicks in TEB2
User enters text and presses TAB key, cursor "disappears"
User clicks in TEB3
User clicks in TEB4
User clicks in TEB5
User enters text and presses ENTER  key, next slide loaded
What I need it to do when the slide loads:
Cursor in TEB1
User enters text and presses TAB, cursor moves to TEB2
User enters text and presses TAB, cursor moves to TEB3
User enters text and presses TAB, cursor moves to TEB4
User enters text and presses TAB, cursor moves to TEB5
User enters text and presses ENTER, next slide loaded
I've tried staggering the TEBs in the timeline, pausing until each field is verified, using No Action instead of Continue, and messing around with the fields in various ways, all to no avail.
Any recommendations? I really do not want to have to add more slides just because tabbing won't work correctly.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
