air_flash
TFL flashvars bug
May 21, 2010 2:53 PM
Hi everyone!
During the project migration to Flash CS5 I discovered an unexpected problem. If the scene  contains at least one component of the TFL, then the all flashvars variables are "undefined". Delete  a component from the scene, compile - all works fine. Adds - again  undefined.
FlashPlayer 10,0,45,2
Sorry from  my English
    Community Member
    May 28, 2010 11:29 AM
    Found the same issue.
    Adobe Employee
    May 28, 2010 1:34 PM
    I can reproduce the issue. I've started the wheels turning to figure out what's going on.
    Adobe Employee
    Jun 1, 2010 2:22 PM
    OK - it looks like this is an issue with the Flash Pro CS5 preloader code. I'm told there will be a technote published for this problem.
    Here's a workaround I got from the engineer who looked into this:
    Typically you could access the flashvars parameters in AS3 by doing something like this:
    var params:Object = loaderInfo.parameters;
    But to work around the issue we are having with the TLF RSL preloading, you need a little bit of extra code:
    if (parent != null && parent.parent != null) {
                    params = parent.parent.loaderInfo.parameters;
    For the work around to work correctly THIS CODE NEEDS TO BE ON FRAME ONE. It cannot be in a user defined constructor (too early) and it cannot be in frame two (too late). We need to be clear about that.
    While there is not a schedule for releasing a fix to this issue, we definitely would want users to first grab the flashvars the normal way and then check parent != null && parent.parent != null, because I hope that in the future we will be able to fix this issue, and we do not want users creating content that would be incorrectly applying a work around when one is no longer necessary. So definitely those checks are important.
    Alan
    Community Member
    Sep 5, 2010 10:38 AM
    Just for the record, if you are having a problem accessing your  FlashVars (and you are using a TLFTextField in Flash CS5) and you are  using external classes (i.e. you have a document class and not timeline  code) you need to listen for the ADDED_TO_STAGE event before trying to  access them.
    For example ...
    package
        import flash.display.Sprite;
        import flash.events.Event;
        import flash.display.LoaderInfo;
        public class Main extends Sprite
            public function Main():void
                if (stage) init();
                else addEventListener(Event.ADDED_TO_STAGE, init);
            private function init(evt:Event = null):void
                removeEventListener(Event.ADDED_TO_STAGE, init);
                // You can now loop through the params to access your FlashVars
    Community Member
    Nov 7, 2010 11:03 PM
    Going up 2 levels was too far for my case.
    This worked for me:
    * CS5 completely broke flashVars.
    * See http://forums.adobe.com/thread/644057 for details.
    * Basically, ADOBE == STUPID.  Thanks guys!
    private function getFlashVar( varName:String ) :String {
      var paramObj:Object = LoaderInfo(this.root.loaderInfo).parameters;
      if( parent != null )
        paramObj = parent.loaderInfo.parameters;
      }// end if()
      try {
        for( var el:String in paramObj )
          if( el == varName )
            return paramObj[el].toString();
      catch(e) {
        return "";
      return "";
    Just another example of the folks at Adobe screwing up a good thing.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
