.dll and .tgz files appear seemingly at random...
Nov 6, 2007 7:08 PM
Does anyone out there know what the purpose of these files are?
lsprst7.dll
sysprs7.tgz
They seem to appear sporadically in premier pro project folders every now and then. (I often use Photoshop in conjunction with PrPro. Just thought I'd throw that in).
    Jun 10, 2010 7:49 AM
    same here, windows 7 64-bit.
    Community Professional
    Jun 10, 2010 9:15 AM
    Community Member
    Jun 10, 2010 9:33 AM
    I've nothing related to SafeNet on my system.  I believe that path is a dead end, and this issue still remains unresolved.
    Jun 10, 2010 10:31 AM
    Well, it's still a case of you having software or drivers in use on your system that aren't in use on mine.  It's just the difficult matter of finding which software package creates those files.  Since they end up in your Pr project folder and I don't think Pr is creating them, then it's probably a system-wide app that targets disk drives in some way: searches, repairs, boot configurations, VMs, etc.
    Again, I don't have either of these files anywhere on my Windows 7 64-bit system.  I'm using the Professional version; anyone with these files using Ultimate?  Like maybe BitLocker?  Or maybe a VM so that XP compatibility mode can be run (which I don't)?
    -Jeff
    Jun 10, 2010 10:59 AM
    Never seen these files before.
    A google search revealed its malware.
    Sep 9, 2010 10:05 AM
    These files just appeared for me today in a Premiere Pro CS4 project folder.  My first google searches seemed to indicate malware, but I think the sites saying that were actually trying to install malware.  More searching seems to indicate the files are created by a statistical analysis program, SPSS, specifically as a part of their licensing scheme.
    See here:
    http://spssx-discussion.1045642.n5.nabble.com/sysprs-and-lsprst-files- from-SPSS-14-and-15-td1075378.html
    http://en.wikipedia.org/wiki/SPSS
    I've never heard of SPSS before and certainly haven't installed the program myself.  One guess is that Premiere Pro uses SPSS internally, but I seriously doubt that.  More likely it's that Adobe's license manager uses the same system that SPSS uses for licensing.  This would appear to be SafeNet Sentinel:
    http://forums.majorgeeks.com/showthread.php?t=171435
    So the appearance of these files certainly woke me up this morning.  (Apparent malware infections get my heart pounding.)  But it looks like they're nothing to worry about after all.
    It would be nice if someone from Adobe would confirm this -- possibly in a KB article.
    Adobe Employee
    Sep 9, 2010 12:22 PM
    Confirm what?
    Your guess about our licensing software was mistaken.
    Community Member
    Sep 9, 2010 12:59 PM
    I should have said confirm or deny.
    Thank you.  That's good information.  Can you explain the presence of these files then?
    Community Member
    Sep 9, 2010 1:14 PM
    I also have these files everytime I open a premiere project files. I have no idea why they are there, it would be nice to avoid it.
    Community Member
    Sep 10, 2010 1:31 PM
    These files appeared again today in a new PP CS4 project folder.  They have now appeared in my last two project folders.  This is a new development.  I have a project that I last modified on August 15, and these files did not appear then, or in any projects before (that I know of).  And I don't think any of my CS4 apps have been updated in the last month, except maybe Flash Player.  I am running Vista Business 64-bit, as an administrator with UAC turned on, and this has never changed.
    So why are they appearing now?  What is creating them?  What purpose do they serve?
    Todd_Kopriva, if you or any other Adobe employees could shed some light on this, it would be greatly appreciated.
    Community Member
    Sep 10, 2010 1:42 PM
    Did you Google?
    I did, and it looks to me like these files are malware
    Sep 10, 2010 1:46 PM
    Attempting to shed some light:
    I found that files named  lsprst7.dll, tmpprst.dll and lsprst7.tgz are created in various places  on my hard drive. What's the matter with them?
    These files are part of the persistence layer of the licensing  component used by SparkMaker. Usually these files are created once in  the
    %WINDIR%\system32 folder, if the user has local administrative  privileges. If the user does not have local administrative privileges,  these files might be created in the directory containing the Office  document you have opened. In order to change this behaviour make sure  SparkMaker is executed once from a user having administrative  privileges. This user should have write access to the %WINDIR%\system32  folder.
    You can extrapolate that information to apply to your system(s).  I suspect there is a piece of software on your system that uses the same licensing component as this SparkMaker (or as SafeNet) and that is what is generating the files.  These files have been discussed here before, and SafeNet was one likely source of the files.  Regardless, it's not Pr or any CS5 suite app.
    -Jeff
    Community Member
    Sep 10, 2010 1:49 PM
    John T Smith wrote:
    Did you Google?
    I did.  Please read my original post:
    http://forums.adobe.com/message/3121370#3121370
    Community Member
    Sep 10, 2010 1:53 PM
    -Jeff
    That's what it was looking like to me too.  But Todd_Kopriva seemed to shoot that theory down (reply #8).  Hopefully he will elaborate on what their actual purpose is, what is creating them and why.
    Sep 10, 2010 2:54 PM
    Why do you think he would know?  As I mentioned in the last sentence of my previous post, they're not being generated by any Adobe software component.  Only you can determine which piece of software on your system is generating the files.
    -Jeff
    Community Member
    Sep 10, 2010 3:16 PM
    -Jeff
    I'm hoping he knows more since he responded fairly quickly with a pretty definitive (albeit brief) answer.  So it appears that he is knowledgeable about this topic.
    And I have to think they are being generated by Premiere Pro, or some other Adobe component, because the files are created at the same time as the folders "Adobe Premiere Pro Preview Files" and "Encoded Files" in the project folder.  This is when I am opening an existing prproj file (a copy of an older project file) in a new (empty) folder.
    Btw, I never mentioned that I scanned the files and the folder with Security Essentials and it declared them clean.  That certainly doesn't mean they're not actually malware of some kind, but I thought I should mention it.
    Adobe Employee
    Sep 10, 2010 3:21 PM
    I'm knowledgeable about what licensing software we use. The licensing software named on this thread is not it. I have no idea what is putting those files on your computer.
    Community Member
    Sep 10, 2010 3:28 PM
    Thank you for elaborating.  I will continue to search for the answer on my own.  (I'm thinking of some traces using some Sysinternals tools.)  I'll post back here if I find out anything.
    Community Member
    Sep 10, 2010 9:21 PM
    It is curious, though, how they only appear in folders with Adobe files in them, specifically Premiere Pro projects.
    I myself have neither of the suspect programs mentioned installed.
    Community Member
    Sep 10, 2010 9:23 PM
    Well I definitely need to do some more digging, but here's what Sysinternals Process Monitor is showing:
    - If I start PP by opening a project file from Windows Explorer, "Adobe Premiere Pro.exe" looks for sysprs7.dll, sysprs7.tgz, etc in the project directory, then creates them, then accesses them.
    - If I start PP by running it from the Start Menu (with no project file), "Adobe Premiere Pro.exe" looks for those files in both C:\Windows\SysWOW64 and in C:\Program Files (x86)\Adobe\Adobe Premiere Pro CS4.  (They are present in SysWOW64 -- but not in Adobe Premiere Pro CS4.)
    So Premiere Pro is definitely involved, but I realize it accesses lots of components, some of which are third-party, like QuickTime, Matrox, etc.  So I guess it could be some other component that "Adobe Premiere Pro.exe" is loading that is creating and accessing these files.
    I did update QuickTime on 8/31 (to 7.6.7).  I wonder if that's related.
    I'll dig deeper next week.
    Community Member
    Sep 10, 2010 9:27 PM
    I don't have Quicktime installed either.  That is not the likely culprit.
    Community Member
    Sep 13, 2010 8:12 AM
    That's good to know.  I think that's the only thing that's changed on my system since these files started appearing for me -- other than Microsoft updates.  Hmm...
