I am not able to scroll in Bridge CS5
Sep 11, 2010 5:57 AM
Hello Everyone,
With my version of Adobe Bridge CS5, there is no scroll bar on the right-hand side of the window. Therefore I can not see the icons which are on the far right of the screen unless I make everything so small that it is hard to differentiate between the icons and their captions are unreadable.
Can anyone help?
Thank you very very much in advance.
Betsy
    Sep 11, 2010 4:24 PM   in reply to BetsyW.
    I'm a long way from a Bridge expert, but if I understand your problem correctly, you might want to try shifting between some of the optional "workspaces" and see if you'll get the scroll bars you want.
    Under the Window menu, choose Workspace, and then slide over and choose a workspace...such as Preview.
    Each of the workspaces rearranges the various panels in Bridge...maybe you just need to find a workspace that works the way you want...and of course you can create your own workspace without too much trouble.
    Also...if the icons and other things that appear in a particular panel don't take up enough space, there will be no need for scroll bars, and then the scroll bars will not appear.
  • Omke Oudeman
    Nov 27, 2004
    Sep 13, 2010 3:02 AM   in reply to BetsyW.
    I was in the preview panel whatever that is supposed to do I don't know.. it
    is the panel below it that has the scroll bar...
    NotAlwaysSuite meant you should try an other workspace using the names at
    the top of the bridge Window right centre. You can explore those for
    different workflows but you can also create a workspace for your own purpose
    and save this.
    However I think you are talking about the thumbnails in the content window
    that are not complete visible and show a horizontal scroll bar.
    For some reason you have (accidently) changed the layout from auto to
    horizontal. The easiest way to get it back to normal is to go to the
    triangle right next to the workspace names and click on this icon. The fly
    out menu gives you first of the row the reset workspace option. Click on
    this and you should be OK.
    Second option is to go the little menu icon top right of the content window
    and from this small menu choose auto lay out.
