      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Brush cursor problem with photoshop CS5 MAC painting
Aug 26, 2010 Aug 26, 2010
Hi all,
i got a serious and annoying problem when i paint,and i'm going crazy because with CS4 photoshop i never got this problem
example:
when i paint and press with my tablet WACOM INTUOS 4 and release pen my brush cursor change aspect from circle to cursor  to OS X Mouse Cursor for a little bit second and then return to classic brush round circle repeatedly in any brush press-release -press-relase (painting)
if i rotate my grip-pen to erase something, this "change" move cursor about 5/10 pixel and then return in start position and any work become impossible and hard.
I tried to install the new driver wacom for a night trying to solve this problem.
but ....at the end i give up and turn off my wacom, and i discovered that my problem isn't the tablet but Photoshop CS 5!
why???
if i  draw/paint with the mouse the "blink cursor joke" is the same!!!
i'm very frustrated for this problem!
i read a lot of forums,
try to turn off open-gl
try to re-install
try this.. try that..
nothing!
please help me!!
thank you and sorry for bad English
PS: here is a gif example for the problem
30.0K
Adobe
sorry, the gif uploaded doesn't move try to download it
try to re-install
Just to make sure: Did you restart Photoshop after changing OpenGL-settings?
yes, i did it
Sorry, then I can only point out other obvious candidates which youā€™ve probably read about anyway:
Is Photoshop updated to 12.0.1?
Whatā€™s your OS-version?
Have you performed routine trouble-shooting tasks (trashing prefs, system maintenance, weeding out bad fonts, ā€¦)?
Guest
well, i got Leopard 10.6.4
now i downloaded last 12.0.1 update for PS CS5 mac ....but nothing seems to change.
same problem, when i draw/paint and release for a moment cursor os x appear and then dissapear...
i had no problem with PS CS4 with same configuration, same MAC same all!
:Ā°(
i'm very tired
Do you have a wacom tablet attached to your system?
There was a bug like that in an older Wacom driver (updating should fix it).
Guest
Aug 27, 2010 Aug 27, 2010
hi chris, attached or not is the same cursor problem.
I never got problem with wacom and CS4, the problem persist only with PS CS5
i downloaded last wacom driver and the cursor pointer appear again(always for a moment) when i release
In another forum one user says that it's a bug of photoshop cs5 that adobe know and will fix..
when will fix we don't know.
If anyone know a solution please tell me something
The issue would be that the driver is installed, not that the tablet is currently connected.
As far as I know (I have yet to see any internal bug on this), this is an external driver issue.
Guest
Chris, i downloaded and installed last wacom driver.  Are you saying i can't paint with my wacom and cs5?  I did this experiment today:  Cs4 and cs5 opened, cs4 all perfect Cs5 did the cursor pointer problem on release Mouse and wacom tested  Do you think if i uninstall wacom driver, problem will be solved? And then, how can i paint without wacom's driver Thank for your patient
No, read what I said.
I said that some wacom driver versions have been known to cause brush cursor problems like what you are describing.
(also bad installs of drivers, where someone didn't follow the directions to update the driver)
Photoshop CS5 uses Cocoa APIs, while Photoshop CS4 used Carbon APIs -- there are going to be differences, they are going to hit different code paths in the OS and drivers.  When there is a driver bug, the driver maker normally updates their drivers to address the bug pretty quickly.
If you are continuing to have problems after updating the driver, then uninstalling would be the next logical thing to test.
But it is possible that some other application or driver on you system is the cause, and it isn't the Wacom driver.
Guest
Aug 28, 2010 Aug 28, 2010
Chris, i follow your instruction
uninstall full wacom driver, then restart,
photoshop without any driver do the same cursor pointer problem when i release "click".
so i re-install the last wacom driver.
i can't understand what driver or application causes this problem.
any idea?
OSx: 10.6.4
Sep 02, 2010 Sep 02, 2010
I encountered the same problem using Photoshop CS5. When I paint with my wacom tablet the cursor blink into a windows arrow cursor for a very short moment every now and then. It's driving me crazy.
Both of my two PCs has the problem --one with Intuos 4 + Windows XP 32bit + Nvidia Geforce and another with Intuos 3 + Windows 7 64bit + ATI Radeon--even after I updated all the latest graphic card and tablet drivers. And I never had that problem with CS4 neither.
Guest
hi shishak44, thanks for your post.
As you know i can't update my graphic driver in Macintosh.
I got an iMac 24" 2.8 Core2Extreme Ati HD1600  and  Leopard OSX 10.6.4.
Someone can help me?
Someone got this problem with MAC OSX ??
šŸ˜•
Sep 04, 2010 Sep 04, 2010
I finally came up with this solution, in Preferences>Performance, open Advanced Settings of OpenGL, then switch "Mode" to "Advanced" (defaultly 'Normal'). I've tried this out for several hours and it's ok up to now. It almost never happened again, except I think I saw it blinked undetectably several times.
Right after I posted this the damned cursor started blinking again, as if it's mocking me...
Guest
hi friend... i have already done this change... in three different mode time ago...
but, as u see ... NOTHING!!
damn it! no one can help us... no ONE???? ho can it possible?
Hey ADOBE ... Help US!
i'm very afraid!!!!
now, i got CS5 and CS4 installed and i'm painting with CS4 untill someone help us to solve this problem.!!
thanks
Guest
Sep 11, 2010 Sep 11, 2010
Heyyyyy........ none have some news?????
please help us
Engaged ,
Sep 14, 2010 Sep 14, 2010
I have noticed this effect. For me, it happens briefly, usually when hovering with the pen.
Now using Affinity Photo
Adobe Employee ,
I have reproduced this problem and have logged the appropiate bug internally.  I know that does not help you with your immediate problem but,  I wanted to at least let you know that we have seen this and are working on it.
Sep 21, 2010 Sep 21, 2010
David-
I'm wondering if this bug you've found is the same or related to the really slow painting I've found in CS5?
I've been talking with an Adobe engineer and he doesn't see this issue, but I see it on 3 different Mac Pros and CS5.
The Mac Pro's have Nvidia cards and painting is very slow and my old Macbook Pro has an ATI card and it does everything fine in CS5.
Here is my previous thread:
http://forums.adobe.com/thread/699655?tstart=0
Are you using MacOS 10.6?  Did you install the Graphics Update from Apple (that fixes a LOT of NVidia driver bugs)?
Hi Chris,
Yes I've doe all of that - I think you responded to my original post and referred me to Mike Shaw and Jeff Tranberry. They haven't been able to fix it. I think its definitely a video card issue - strange that 3 1-2 year old Mac Pros - not identical hardware/software setups - are terribly slow at painting and curves window whereas my 4 year old laptop is fine with an ATI Raedon card. Cant use CS5 for real work right now, the studio's been on CS3 as it has no issues. But we would like to figure it out before we cancel out considering upgrading.
Sep 26, 2010 Sep 26, 2010
Oh, finally some affirmative response. It's comforting, thanks. As a temporary solution, I've replaced the windows cursor with a crosshair cursor I made the same with the Photoshop brush.  I expect your good news.
Guest
Sep 28, 2010 Sep 28, 2010
i can't understand yout post... have you read that this is a MAC problem?
how can help me this cursor replace??!!! -_-
@David Dobish   thank you, this is the only professional and useful answer!
PLEASE, David... tell me more if you find a solution!
i'm very very tired about this problem!
i can't understand Adobe!!!!
bye
Adobe Employee ,
Once I know more and I can share the information I will let you all know the status.
