Can someone please help me resolve this problem? I had no problem using Adobe Reader 8 but since removing Adobe Reader 8 and download the updated Adobe Reader 9, I cannot open any pdf files or the Adobe Reader 9 (on desktop) without receiving the following error message:
"Adobe Reader 9.3 has encountered a problem and needs to close". I tried several times to download and reinstall Adobe Reader 9 without any success. Any help will be appreciated. Thanks.
Choichai
We are having a similar issue. We are using Windows XP Pro SP3, IE 6 and some PC's 8. We had no issues viewing PDF's from the Browser on Adobe Reader 8. As soon as we installed the latest version of Adobe Reader 9.3, we can not view PDF's on the web from some websites. We get a red X. We have tried some of the other troubleshooting articles, and have had no luck finding a resolution. Can someone help?
No I am sorry I cannot share the PDF's, they are not public websites. One website is with a contracted ASP(Application Service Provider), and the other pdf's are internal on our intranet. The ASP tells us the Adobe Reader is required to open the PDF from their website, but they do not support Adobe if we have issues.
I can download the PDF from a PC that has Adobe Reader version 8 and open the PDF from the PC with Adobe Reader 9. However, I can not pull up the same docuemnt from within the Internet Browser.
I am now having problems removing the Adobe Reader 9.3.4. When I tried to remove it from the Control Panel, I get the following error message:
Error 1327. Invalid Drive: E:\
Select "OK" and received "Fatal error during installation"
Can someone please tell me how I can remove the Adobe Reader 9.3.4? Thanks
Choichai
Hello -
We found the cause of our Adobe Reader 9 issues. Adobe released Security Advisory APSA09-01 regarding Adobe Reader 9. As a result, our company initiated a Group Policy (global setting change) in our system for users with Adobe Reader 9 installed on their PC's that disabled JavaScript in Adobe Reader. As an End User, we could not see this global setting in the Adobe Reader preferences. Our System Administrator had to remove the setting. Once the Global Policy was removed, our users could view PDF's through the Internet web browser with JavaScript with no issues.
@Choichai,
Search the Adobe Knowledgebase for how to manually remove Reader. It will require manually editing the Registry. Be careful when doing so since it is possible to make errors that will require you to re-install Windows from scratch.
Hi Michael,
Thanks for coming back to me. Remember when I've received the error message previously "Error 1327. Invalid Drive: E:\", I've decided to try inserting my flash drive into the E drive (since I've downloaded the Adobe file previously from my flash drive to my desktop pc) and then try removing the Adobe Reader 9.3.4 and it works!!!! I am now working with the earlier version ie. Adobe Reader 8 which works fine. I would like to try again to download the Adobe 9.3.4 but have previously tried 3 times and failed. What else can I try to do to download, install and run this latest version without experiencing the same problem over again? Thanks.
Choichai
where can I download Adobe Reader 8 (Mac)?
Jan
Op 20 sep 2010, om 09:26 heeft Choichai het volgende geschreven:
Hi Michael,
Choichai
I'm also having a problem opening PDF files. I am unable to open any PDF in reader X or Acrobat 9. I get no error message the programs just do not launch. This has been going on for the past week. I'm running Windows 7.
I've posted the same comment here http://forums.adobe.com/message/4297090#4297090
