AKB300Media
Trouble Syncing Offline with Online
Sep 14, 2010 4:55 PM
My desktop has been...how can I say this? Under the weather for a few weeks, and since that is the case, all of my offline story project on it are out-of-date with my online projects (which I have been working on using my laptop).
This past week though, I got my desktop back, and now I've got another problem. I can't get the offline desktop application to sync with the online app. Basically I sat there for fifteen minutes with "Going online, Please Wait..." sitting on my screen, but nothing happened. So I uninstalled Story, and then installed it again, but to my surprise all of my offline documents were still there for some reason, and it still won't go online.
Basically, I'm wanting to know how to get this thing to sync up. Any help is welcome.
    Sep 14, 2010 9:47 PM   in reply to AKB300Media
    From your post it seems that you just want your online data synced to offline database.You don't want it otherr way right ?
    If that's the case
    Can you try following:
    1)  You don't need to uninstall adobe story. just close the adobe story application if it's already running.
    2) after that on
         Windows
              Delete "%appdata%\Adobe\AIR\ELS\com.adobe.AdobeStory*" (i.e. delete all the folders starting with
              com.adobe.AdobeStory)
         Mac
              Delete the application stored data: User > Library > Application Support > AIR > ELS > com.adobe.AdobeStory*
      3) Now try logging in and you will see that you logged-in  in online mode, your online data will start syncing to offline database automatically.
    thanks
    ratnesh
    Sep 14, 2010 10:45 PM   in reply to Ratnesh-Kumar
    Note: By doing this you will lose all the data present in offline database (online database will not be touched).
             i.e. if there were some changes done in offline mode and were not synced to online database, will be gone.
    --ratnesh
    Sep 15, 2010 7:35 AM   in reply to AKB300Media
    As mentioned by Ratnesh above, deleting the appdata folder should fix the problem. Have you tried it? What OS are you on?
    Sep 15, 2010 8:26 AM   in reply to AKB300Media
    Can you also try deleting the following folder?
    %appdata%\com.adobe.AdobeStory.4875E02D9FB21EE389F73B8D1702B320485DF8C E.1
    Sep 15, 2010 8:34 AM   in reply to AKB300Media
    ok, then try this:
    1. Go to run prompt:
         Press windows + r to get this prompt
    2. Type %appdata% on the prompt and press enter
    3. This should open the appdata folder
    4. Find the folder named com.adobe.AdobeStory.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1 here and delete it.
    Sep 15, 2010 8:38 AM   in reply to AKB300Media
    Glad I could help
    Jan 20, 2011 3:37 PM   in reply to Pankaj-Adobe Story Team
    how do you fix this on a mac?
    Jul 18, 2012 7:50 AM   in reply to Pankaj-Adobe Story Team
    This worked perfectly.  I was concerned about losing my data, so from within Story, I used the "Save File to Disk" option on my screenplays that weren't synced.  Then from within the web version of Story, I imported the ones that hadn't been synced.  Fortunately, that was only one script for me, but depending on when Story stopped going online for you, that may be a bunch.  But by using the web version as my base, I only had to worry about the ones that hadn't been synced since my last changes, rather than having to export and import the entire database.
