kaizer1981
AVI import trouble from camtasia file
Sep 18, 2010 5:03 AM
i have recorded a video off my computer using camtasia, and want to edit it in premier cs5. In camtasia i saved the file as an .AVI. This file plays fine using VLC player, but when i import it into my premier project it only shows up as an audio file, no video is present. thanks in advance for any help given.
    Sep 18, 2010 5:20 AM   in reply to kaizer1981
    Welcome to the forum.
    Pr CS5 is 64-bit.  To see AVI files made with the TechSmith codec, you need a 64-bit version of the codec.  I don't know if TechSmith has released one yet.
    -Jeff
    Sep 18, 2010 7:51 AM   in reply to kaizer1981
    Instead of using the Techsmith codec you can save your avi with e.g. Lagarith 64 bits, which can be edited in Pro without a problem.
    Sep 18, 2010 9:26 AM   in reply to kaizer1981
    Well i am still on version 3 so assume this is also possible in higher versions.
    When saving the file to avi one can choose the codec.
    My version says in Post Save options: Produce my video in a shareable format.
    Save as avi with avi encoding options.
    On has to install the Lagarith 64 codec in advance.
    http://lags.leetcode.net/codec.html
    Sep 18, 2010 8:42 AM   in reply to kaizer1981
    This ARTICLE might prove useful, when using Camtasia files. However, I think that much of that info came from Jeff Bellune, or Ann Bens to begin with, so you already have two valued contributors working with you on this thread.
    Good luck,
    Hunt
    Sep 18, 2010 10:50 AM   in reply to kaizer1981
    Lagarith is lossless.
    Clic on the the link on the site a gave you before, the Lagarith 64 bits with installer.
    A window pops up and click on execute (i think that what is says in English) I have a non-English operating system.
    Or if you have already made a recording.
    Download Virtual Dub.
    http://sourceforge.net/projects/virtualdub/files/virtualdub-win/1.9.10 .32839/VirtualDub-1.9.10.zip/download
    No need to install just unzip and click on the last Virtual Dub exe in the list.
    Import camtasia file and save as with the Lagarith codec which you selected before under Video/Compression.
    Sep 20, 2010 2:07 PM   in reply to kaizer1981
    It is possible she meant Camtasia 3.0 (it's up to 7 now ).  Here's a link I found from a couple of years ago
    http://forums.creativecow.net/thread/3/885656#892308
    I tried it, but I found out I needed Quicktime Pro (I think about $29) to make it work. (check out the last post in this link).
    While this guy was able to edit the .mov file he created in Premiere Pro, I found for some reason when I imported the .mov file into my Prem Pro cs3, it would play from the time line, but the audio and video seemed to be combined into a file that only showed up on the video track of the timeline.  Since he supposedly got it to work, I assumed it was something I was doing wrong .
    It might be worth a trial.
    John Rich
    Sep 20, 2010 2:10 PM   in reply to kaizer1981
    Just to add my two cents...
    Thanks to Ann Benns for the info on this 64 bit lossless codec. While not perfect it is a huge improvement on just exporting a lossless avi from Camtasia.
    For example.
    18.5mb Techsmith File - 1 minute
    366mb Lagarith - 1 minute (Yellow MPE with GTX 470)
    1.89gb Uncompressed AVI - 1 minute
    Now don't get me wrong if Techsmith came out with a 64 bit codec that same 18.5mb file could be exported at almost the same size. But as a workaround a 366mb file is still easier to work with than 1.89gb!
    Thanks again,
    Martin
    BTW, I am still using Premiere Pro CS3 (for techsmith) along with CS5 without any problems.
    Aug 3, 2012 7:52 PM   in reply to kaizer1981
    Kaizer, I have the same problem.  I export out of Camtasia as AVI and import into Premiere (CS5).  Sometimes the files play fine.  Other times, they play as you describe, blurry/blocky, poor details.  At first, I thought perhaps it was simply the way Premiere plays it back for editing...but it renders out that way too.
    My workaround is to import the file into AfterEffects then render it back out as AVI.  Import the new AVI into Premiere, and the problem is no longer there.
    There must be another solution to this issue???
    Also, I've had issues with AVIs out of camtasia only playing partially inside premiere.  My solution to that was to export the file out as quicktime instead of AVI coming out of camtasia.
