Josh Cavalier
Captivate 5 Quiz Variables Bug?
Sep 12, 2010 7:29 AM
Hello fellow Captivaters!
I've been running into an issue with tracking the the internal quiz variables in Captivate 5. I think this is a bug, but I want to make sure that I'm not losing my mind. Check this out:
Yes, the variables get all out of wack for no apparent reason. To reproduce the error:
  1. Make a new blank .CPTX file in Captivate 5 .
  2. Generate 10 Multiple Choice quiz questions. Quiz > Question slide...
  3. On the results page make a text caption and display a few quiz variables: cpInfoTotalCOrrectAnswers is a good one.
  4. Run through the quiz and check out the variable values.
Anybody else running into this issue?
I'm trying to get these values out to JavaScript to post to a custom LMS framework. I can get a value to pass just fine - it's just incorrect.
Josh
    Community Member
    Sep 13, 2010 2:35 AM
    Hi Josh,
    Instead of placing the Text Caption at the start of the timeline on the result slide, move it a few notches to the right i.e make the Text caption start at 0.1s or 0.2s instead of 0s. You will see correct values being rendered.
    Can you please confirm if you are getting incorrect values into your JS too? Ideally, this result slide issue must have nothing to do with the values you get in your JS.
    Let me know if you face any issues with teh workaround.
    Thejas
    Community Member
    Sep 13, 2010 4:48 AM
    Hi again,
    I did try it and the workaround I suggested seems to work for me.
    There is another workaround that you may try. Copy that text caption from your result slide and paste it on your last Question Slide. Make it invisble by unchecking 'visible' in the Caption's PI. This way, in the published swf, the caption will be visible only on your result slide and not on the last slide of your quiz. Now preview the project. The values of the variables must be rendered correctly in the Text Caption on the Result Slide.
    Thejas
    Community Member
    Sep 19, 2010 1:50 AM
    Hi Josh,
    I have been following this thread, and thanks for posting what seems to be the cause (the moving playhead). But I do not understand the solution: are you talking about shortening the last Question slide to 0.5 sec? Is this because we cannot change the action to be performed when the user clicks to get on (think it is Continue instead of Jump to Next slide), and shortening reduces the movement of the playhead?
    Lilybiri
    Community Member
    Sep 19, 2010 12:55 PM
    Thanks, Josh, got it! Something to keep in mind, for sure.
    Lilybiri
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
