Unable to print numerous different PDFs from a corporate website. Each file has similar header, images, length, appearance. Opening the files online I receive the message "Insufficient data for an image" but the images do appear after I scroll down a bit. They disappear if I scroll up again. Try to print and this message appears " Document could not be printed". I have tried saving and reopening in Reader 9.1, also printing to file and printing as an image. Nothing works. I think the two issues are connected. I have seen similar discussions on this and other forums but they seem to lead nowhere. Can anyone help please?
it sounds like the pdfs are corrupt. Didi you get them from the net? If so how? Is there a url for the file so we can take a look at it?
Hi Michael
Thanks much for the prompt reply.
The documents are on the Morningstar Australia site and only accessible to
paid subscribers.
The location of the files is here:
http://www.morningstar.com.au/Funds/ResearchReportsAll
You can sign up for a free trial of premium membership to gain access to the
files.
Once into a research report, there is a small print icon which loads the
pdf.
The pdf struggles to load the images.
I also discovered another message beneath the "Cannot Print" message, which
says "There were no pages selected to print".
Thanks again for your time.
Michael
Hi Michael,
I am seeing similar Error while printing PDF doc. I get following two errors:
1. The Document could not be printed. when I click ok, I get second error listed below
2. There were no pages selected to print.
I started to get this Error when I tried to print few pages of another PDF document using PDF writer (cutepdf).
I tried to delete the PDF application as suggested on one of the forum.
run:
type %APPDATA%\Adobe\Acrobat
delete PDF9.0
It didn't help.
Attached is PDF file I am trying to print.
Thank you for your help.
Sanjay
ps: I am using PDF version 9.0
I am having the exact same issue. "Document could not be printed", then the error "There were
no pages selected to print."
I selected 9 pages to print, but none of them will print. This is from a PDF I created/exported myself from a Visio 2006 document.
Interesting... since the only reason I buy Acrobat Pro is so I can PRINT. 😕
I got both messages after clicking through an automatic upgrade. Saw the post about Foxit and tried that. No go. (No error messages but no print job, either.)
But this worked:
Open Adobe reader
Select HELP
Select REPAIR ADOBE READER INSTALLATION
Done and done. Prints fine now.
Profile:
Adobe 9.4.4
Printer: networked
Windows 7/Dell
I contacted Morningstar, who sent the following message:
"We are currently working on this issue and I expect that you will be able to print without any problems within the next week. The problem is only affecting a small number of people but we are aware of it and we are working to have the issue resolved."
Thanks again - I'll let you know how this goes.
Morningstar have been unable to help so far.
They have fixed other issues for other people, but not this problem.
I can print the attachment sent by sanjaysh with no difficulty.
Can anyone assist please?
It turned out to be a problem with our network printer. Once the problem got resolved I could print the document. No more assistance is needed.
Sanjay
After reading quite a few posts it seems to me that the problem rests squarely with Adobe Reader V9.1. All users have reported a problem with their Printer Drivers that didn't exsist prior to the upgrade. I am not up to uninstalling all my drivers to fix a problem not origionating with the printers. Surely Adobe would have provided a fix by now?
This same problem is happening with me. It just started today after I upgraded Illustrator to CS4. I save the .ai file as a PDF and try to print from Acrobat 9 Pro. I get the "The document could not be printed" then "There were no pages selected to print". The only workaround I've found is to print to a postscript file, then Distill to a PDF. Then it prints fine but it's a time consuming PITA.
Somebody suggested it was a Acrobat Reader issue. It seems maybe not.
An update... somebody suggested it may be a network printer problem. I indeed was trying to print over a network but I checked and I have the same issue with a USB printer trying to print the same PDFs.
Any solution yet? I have the same problem, "Document could not be printed" & "there were no pages selected to print" only difference is that I printed all the odd numbered pages of a 59 page document & can't print the even numbers.
Greg
Maybe the solution is around the corner. I just installed the RTM of Snow Leopard on my Mac Pro and the "Document could not be printed" problem has gone away.
Previously it was only the PDF's made from .ai files received from clients that got this error. If I copied and pasted their art into a new Illustrator document and made the PDF it would print with no problems.
Perhaps this could be your workaround until Snow Leopard hits at the end of the month.
Then... Snow Leopard may just have fixed it for me. Who knows?
Thanks for the reply. I worked around it by installing Foxit PDF Reader
(free program) & whooooosh the printer jumped into action. Easy.
Greg
I upgraded Vista Business 64 to Windows 7 Prof 64 just because
I could not print any pdf.
The problem is the same as others wrote "Document could not be printed".
I can print from other applications (word, firefox, etc.), so the printer works fine.
The printer driver was downloded directly from the printer vendor's site for Win 7 64.
I cannot even print with Foxit reader !
I tried to uninstall Acrobat reader 9, and install 8.1.3, 8.1.2, but none of them
can print pdf files.
Now I have Acrobat Reader 9.3 installed and I still cannot print ANY PDF files, with
ANY application (Acrobat, Foxit)
Whoosh is right. I just installed Foxit pdf reader, and my file printed with no hesitation.
Carol
When I installed Adobe it used COM1 for the printer port. What worked for me was going in to the printer properties for the Adobe printer and changing the printer port from COM1 to Documents\*.pdf.
Running Adobe Standard 8, Windows 7, 64 bit
I think this issue has been resolved by Adobe over the past few updates. Seems Adobe has been doing a lot of updates lately. But instead of telling they fixed it and admitting it, Adobe just silently fixed it and we can go on our merry way.
They do mention the bug fixes included in the release notes.
Sent from my iPhone
While I appreciate ultimately the issue resolved, as an IT Manager with over ten thousand users worldwide, I personally don't have time to read every release note for every application that my organization uses. nor do I expect my staff to bury themselves in this kinda of stuff. Perhaps when the issue arises, Adobe could have fixed it right away instead of almost 2 years later.
Just got a new Mac with Snow Leopard installed on it. Installed Adobe CS4 and, bingo, Acrobat 9 has been a real pain. I've had to reinstall it several times as it never seems to understand that it should work. After most problems have been resolved, I am now faced with being unable to print any Illustrator/PDF documents to any of our printers. PDF files sent to me work, only the former .ai files seem to fail as others have mentioned. I get the same message others are getting, "The document could not be printed" and then "There were no pages selected to print." Will Adobe ever fix this? What good is an error message without some hint of what to do? All my drivers are up-to-date. Does anyone from Adobe read this forum?
larry orr
My experience with this problem may or may not be releated to the situation that others have reported, but it may help.
In my particular case, those "The document could not be printed " and "There were no pages selected to print. " messages were caused by an expired domain password that was used by my network printers.
Apparently, the network printer response was incorrectly interpreted by the Acrobat's print routine, generating those bogus messages.
By dropping and remapping my network printers (with my new password, of course), the problem printing PDFs disappeared. By the way, I am using Acrobat Reader v9.2.
Thanks LarrryScott. Your suggestion worked perfectly for me.
Hi all
I also get the following:
I have tried to print docs that have previuosly been printed, the same problem i.e.:
