Why won't files open in Camera Raw from Bridge?
Sep 21, 2010 7:15 AM
I am trying to open files in Camera raw from Bridge but get the following message.
"Bridge's parent application is not active."
Both Bridge and CS5 are open and I have opened camera raw previously.
Any suggestions.
Cheers
    Sep 23, 2010 5:37 PM   in reply to ozanota
    Which version of Camera Raw do you have?
    Sep 24, 2010 12:59 AM   in reply to MadManChan2000
    It is Version 6.2.
    If I double click on a .NEF image in Bridge then it opens into Camera Raw.
    It I right click or use the icon to "Open in Camera Raw..." the I get the error message.
    I would like the option to open JPG files in Camera Raw so I could batch process some adjustments on my old files, particularly my photos taken underwater.
    Thanks for your help,
    Sep 27, 2010 5:56 AM   in reply to ozanota01
    Not sure why you're getting the "parent" error message. With regarding to editing JPEGs, though, you can do that by visiting the Camera Raw preferences. At the bottom of the dialog is a section titled "JPEG and TIFF Handling". Set the JPEG popup menu to "Automatically open all supported JPEGs" so that you can open your JPEG images into ACR (instead of directly into PS, for example).
    Sep 27, 2010 6:34 AM   in reply to MadManChan2000
    I have changed the settings as you suggested but can't see how to open jpegs in Camera Raw. Thanks for your help.
    Sep 27, 2010 11:17 AM   in reply to ozanota
    I am with the same problem. I worked  in Camera Raw from Bridge, and since last week, I receive the same message.
  • Noel Carboni
    Dec 23, 2006
    Sep 28, 2010 10:14 AM   in reply to ozanota01
    function(){return A.apply(null,[this].concat($A(arguments)))}
    With the suggested changes, with the Photoshop application open, the choice of File - Open in Photoshop and picking a JPEG file will cause the JPEG file to be read into the Camera Raw plug-in, where you'll have the choice to use the controls there on it.  That has nothing to do with Bridge, and may explain your difficulty with the answer.
    -Noel
    Oct 7, 2010 5:48 PM   in reply to ozanota
    I doble clicked on the DNG file in Bridge and it appears also. but if I open it in Photoshop, at first the image is opened in camera raw so it works but not in Bridge. any suggestions?
    Oct 14, 2010 7:41 AM   in reply to ozanota
    Yeah i have just the same problem. And it also happens when i want to copy development settings from a adjusted raw-file. Alot of different things won't work. Almost half the options in right-click is stopped by this strange error.
    I doubt it can have anything with the raw-file converter to do since it's no problem to open with doubleclick.
    So, ADOBE, what is the problem here?
    Just for the record, both Photoshop and Bridge is open when this happens and i got my CS5 Design Premium only a week ago.....so i'm scratching my head and cursing at the same time here.
    This is a work-PC with Windows XP Professional if that matters.
    Really hope ADOBE or some other smart people can come up with a sollution for this problem....really soon
    Oct 15, 2010 1:13 AM   in reply to ozanota
    I just fixed this problem with installing the new Adobe Patch Installer. Apparently there was a shitload of little bugs that needed fixing and our problem was one of them...so now everything works perfectly.
    Here's the link to the download area.: http://www.adobe.com/support/downloads/thankyou.jsp?ftpID=4733&fileID= 4431
    Hope it works for you too!
    Nov 22, 2010 9:00 AM   in reply to PerMarius
    I ran the Patch Installer and it didn't help me with the "Bridge's Parent Application is Not Active" message.
    Feb 1, 2011 8:01 AM   in reply to ozanota
    I use cs4 and recently had to reinstall my software after a hardware problem and hardware replaced. Never had a problem before. I now get the same error code as mentioned in first complaint. It will not let me open camera raw at all. I have print orders for costomers due TODAY! Starting to make me mad. Expensive software we pay for and we can't use! Nothing makes me more mad! SO HOW DO WE FIX IT?
    Feb 1, 2011 8:39 AM   in reply to hainangel2000
    After you reinstalled CS4 did you do all the updates for Photoshop via the Adobe website?
    Richard Southworth
    Jun 18, 2011 12:31 AM   in reply to hainangel2000
    Did you get this fixed?  I'm running into the same problem now too?
    Thank you
  • Noel Carboni
    Dec 23, 2006
    Jun 18, 2011 12:33 PM   in reply to Corinna Hoffman
    General question, but worth asking:
    Have you updated your software to the latest release?  That would be Photoshop CS5 12.0.4 (or 12.1) and Camera Raw 6.4.1.
    -Noel
    Jun 21, 2011 9:21 AM   in reply to Noel Carboni
    Thank you for the reply.  I have figured out on what to do.  I did update by logging on to CS4, then clicked on the Help button in the toolbar, clicked on "Updates" .. once it updated that, the Camera Raw update I had uploaded from the Adobe site worked.
    Thank you
    Jul 13, 2011 7:34 PM   in reply to PerMarius
    I have the same problem! Can anybody have a solution?
    Jul 13, 2011 7:41 PM   in reply to ozanota
    I have same problem! I tried everithing from forum suggestions. Nothing worked!
    Jul 16, 2011 6:15 AM   in reply to ozanota
    Same problem here, though now in Bridge, all jpegs are opening up in RAW first!!
    Wedding Photographer
    Oct 5, 2011 12:11 PM   in reply to ozanota
    Found the solution: copy and replace the file: amtlib.dll from program files/adobe/photoshop cs5/ folder to program files/adobe/bridge cs5/ folder You need to have permissions to do this. Hope will solve your problem.
  • Noel Carboni
    Dec 23, 2006
    Oct 5, 2011 12:26 PM   in reply to familistu2000
    Basic question:  How is it that you expect those files to differ?
    When your software is installed by Adobe's installer, they match already.
    -Noel
    Oct 10, 2011 9:10 AM   in reply to ozanota
    GUYS, HERE IS THE FIX!
    http://www.youtube.com/watch?v=gEuy_i7aNto   ---- I TRIED IT AND IT WORKD
  • Noel Carboni
    Dec 23, 2006
    Oct 10, 2011 12:25 PM   in reply to wombatvlogs123
    The video shows replacing a current DLL file with one from last year - the key issue being that the files found in the Bridge and Photoshop folders are DIFFERENT.
    Why would this be?  I checked a PS CS5.1 installation myself and the files are already the same.
    Is there an illegitimate copy of Photoshop being used or something, causing these files to differ?
    -Noel
    Oct 12, 2011 11:36 AM   in reply to Noel Carboni
    Ah this is just because I haven't fully updated my bridge yet, but the solution still works fine
    Date: Mon, 10 Oct 2011 13:25:37 -0600
    To: davidrocks@hotmail.co.uk
    Subject: Re: Why won't files open in Camera Raw from Bridge? Why won't files open in Camera Raw from Bridge?
        created by Noel Carboni in Adobe Camera Raw - View the full discussion
    The video shows replacing a current DLL file with one from last year - the key issue being that the files found in the Bridge and Photoshop folders are DIFFERENT. Why would this be?  I checked a PS CS5.1 installation myself and the files are already the same. Is there an illegitimate copy of Photoshop being used or something, causing these files to differ? -Noel
         Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: Why won't files open in Camera Raw from Bridge?
         To unsubscribe from this thread, please visit the message page at Re: Why won't files open in Camera Raw from Bridge?. In the Actions box on the right, click the Stop Email Notifications link.
         Start a new discussion in Adobe Camera Raw by email or at Adobe Forums
      For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
    Mar 8, 2012 4:39 PM   in reply to ozanota
    You need to update hosts File which you may find under C:\WINDOWS\system32\drivers\etc
    First you should Quit Adobe Bridge & Photoshop
    You Need to Enter # in front of each adobe entries
    for instance if you see
    127.0.0.1          activate.adobe.com
    change it to
    #127.0.0.1          activate.adobe.com
    & than save it
    You might have trouble opening it so open this file with notepad than make changes & save it under same location with same extension.
    It may ask you to replace this with previous file, Click on Yes
    Relaunch photoshop than launch Adobe Bridge
    It should fix this problem
    Jul 27, 2012 11:58 AM   in reply to singh.770
    How can the Hosts file be a cause of this problem?
    Which, by the way, I still have (the "parent application is not active" message) and I have nothing active in the host file.
    cvt
    Jul 27, 2012 2:29 PM   in reply to Vaclav_James
    The hosts file change mentioned 4 months ago would be if there had been some hacking going on that disabled the Adobe activation server using the “127.0.0.1 activate.adobe.com” line in the hosts file and the adding of the # in front disables that hosts entry, effectively re-enabling the activation server access  by programs on the computer.  Unless your hosts file actually has the entry to disable the adobe activation server or other adobe servers, then your problem would be different.
    The error in general means that when you are right-clicking and opening in ACR, the host application for ACR, which is Photoshop, cannot start.  One reason might be that the place the right-click Open in ACR command is looking for Photoshop doesn’t exist, anymore—maybe a registry or config-file has the wrong thing in it, and another reason would be the an existing version of Photoshop is being started up, but something went wrong before the startup completed.  If you are on a 64-bit Windows system, there are potentially two Photoshop executables, one 32-bit and one 64-bit.  With CS6, at least, there are also two versions of Bridge, so maybe it matters which 32-vs-64-bit Bridge you’re running.  To test this try starting up the 32-bit Photoshop and right-click-Open-in-ACR, and if that doesn’t work, then shut down the 32-bit version of PS and start up the 64-bit version of PS, and try the Open-In-ACR again.  If it still doesn’t work, then there is some other problem.  Adobe applications can sometimes be confused if there have been trials and release versions on the same system that aren’t uninstalled and installed in the right order.  There is a CS5 cleaner script you can search for on Adobe’s site that attempts to remove all traces of CS5 from your system.  You would only want to run this after you’d uninstalled as much as you could, yourself.
    Aug 1, 2012 5:39 PM   in reply to Vaclav_James
    My complaint is that Jpegs, selected in Bridge, will open in PS CS5 - but - I cannot, from Bridge, open jpgs in Camera RAW
    I've tried:
    Calling Adobe support, even got a promise of a call-back, twice (of course there wasn't any follow through), resetting the Bridge preference at start-up, deleting all the extra copies of LightRoom, and the DLL file substitute from YouTube - none of these worked.
    This is what I've got:
    Adobe Photoshop 12.0.4 x64
    Adobe Bridge version 4.0.5.11
    Adobe Photoshop Camera Raw version 6.7.0.339 ("Camera Raw 8bi" is in C:\Program files (x86)\Common File\Adobe\Plug-Ins\File Formats); Date created is 03/09/2010; Date modified is 4/20/2012.
    LightRoom 4.1 64-bit with Camera Raw 7.1
    cvt
