I am using Dreamweaver 11.0 / CS5 on a 64 bit Windows 7 PC. All the latest patches/updates have been installed.
In split view I am editing a web page that contains the following: <img src=http://www.mysite.com/images/logo.jpg>. I am editing and uploading the images outside of DW in an FTP Program. The problem is that I can't get the image file to reload unless I restart DW.
Clicking on Refresh or F5 SHOULD reload the preview window, but it doesn't.
Please help! This is a MAJOR deal for me. I am new to DW (came over from FrontPage) and I use this functionality on a daily basis.
PS: I've searched high and low and run across others with similar complaints. See the following:
http://forums.adobe.com/message/2181158#2181158
http://forums.adobe.com/message/171007#171007
I did not know about "Live View" as I am new to DW. Thank you for the suggestion.
Indeed, the image does seem to refresh in the Live View mode.
However, in the Design Mode the image refuses to refresh even if I toggle between Live Mode and Design Mode.
Are you able to reproduce this? How does Adobe handle issues like this, which I consider a bug.
Try going to 'View -> Refresh Design View' in the menu across the top. I know the keyboard shortcut is F5 but that doesn't seem to work all the time for some reason, yet actually selecting it from the menu seems to work.
Brad Lawryk
Adobe Community Professional: Dreamweaver
Northern British Columbia Adobe Usergroup: Manager
Thompson Rivers University: Dreamweaver Instructor
My Adobe Blog: http://blog.lawryk.com
I know this is an ancient thread, but it's also an unfixed issue. For those of us who work on rich email messages for corporate clients, this issue is a real PitA.
If I update an image and upload it, DW's Design View never ever refreshes -- not for love or money. Live View does refresh, but once I switch back (so I can work on the HTML rather than simply admire my beautiful handiwork) Design View stubbornly refuses to refresh the image.
F5 won't do it. View > Refresh Design View won't do it. Screaming at my computer won't do it. And I've tried all three methods many times.
Is this an issue that's fixed in DW 5.5?
Ancient, yet persistent! I have this issue in CS6 and it annoys me to no end. Any way to fix in design view besides restarting?
If I forget to upload the images to the server first, then I lose any preview, it's all broken images. If I have the images uploaded, then I can get the updates. Sometimes. Opening and closing the document doesn't refresh the view either.
Recreating the site cache doesn't work either and takes too long for large sites.
Dreamweaver cache's the images downloaded on your HTML page outwith the physical site cache. When Live View is used, it draws a live connection from the image hosted on the web and thats why you see the recent image. In Design View, it simply views the cached image that it downloaded the first time - so if you have changed it numerous times on the web, you will not see the change.
You need to clear the image cache. in CS5.5 and on Mac, this can be found in Library > Application Support > Adobe > Dreamweaver CS5.5 > en_US > Configuration > Temp.
I'm on PC, CS6. Have gone to \Users\<user>\AppData\Roaming\Adobe\Dreamweaver CS6\en_US\Configuration\Temp and emptied out the folder. Still no preview. Recreated site cache, nope. Save as a new file. Still nada.
Opening and closing Dreamweaver is the only way to get the preview. Some process on launch refreshes the design view. The funny thing is that in the Temp folder, it had the correct version of the server images, but nothing was displaying in the design view. Even after deleting the temp files and refreshing the design view it still would not preview. Had to open and close the application. Some connection between the temp folder and design view is broken. Again, it's only when the image urls are absolute. Local files are fine.
This is surely a bug. The images *should* reload with Refresh Design View, but they don't.
I agree, it should. I am a little confused though as to what you are expecting to happen. The absolute URL means files are hosted on the web. So this piece from your earlier post:
is perfectly correct. If you don't upload the images, how do you expect them to show?
I am then confused by this one from your latest post:
How do you mean "no preview"? You should always have a preview, it might just not be the most recent image you uploaded. No preview to me sounds like a bad link. When you close and re-open DW, it wipes out the Temp folder and then starts a new one from scratch the next time you open it up - effectively the same as removing the files manually. Do you have the page online to see if we can replicate the issue?
In my own experience, it does take a little while (3 seconds or so) for the images to appear in Design View. I can speed it up by using Live View.
Hi Rik. Yeah, it sounds a little confusing. I will try to be more clear. When I'm working on a file with absolute links, I do most of the work with local image links, then switch it to the absolute link towards the end of the work. If I save the file before I have uploaded the images to the server (it automatically refreshes on save), I see a broken image placeholder, as one would expect. Then, after uploading the images and refreshing the design view, I do not get any change. When the images are uploaded before the file is saved, the design preview will happen only once. Any further image changes do not refresh.
There is only one shot at a preview. Emptying the cache/temp files does not work to fix the preview refresh. I have to close/reopen Dreamweaver to get a second preview. Not super convenient when I have a dozen files open.
It's not so important which page is used for a test. This has happened on every single file I have edited that uses full, absolute links for images (ex. http://www.daserver.com/images/refreshme.jpg).
Switching back and forth between live view and design view doesn't refresh the design preview either.
A couple of things that you might like to check:
I have a vague recollection of discussing this issue with Dreamweaver engineers some time ago. As I recall it, refreshing external files was deliberately made low priority to avoid slowing down other processes within Dreamweaver.
It sounds as though you might be able to make a good business case for adding an option to refresh external files. Submit a feature request through the form at http://adobe.ly/DWBug. When submitting the request, explain why it's important to your workflow. There's no guarantee that the idea will be adopted, but it's worth making a case for it.
