Date filter not reading dates correctly
Sep 7, 2010 6:05 PM
I've noticed that since Bridge CS5 came out, the filter on date is not working correctly. For example,I'm looking at a series of images that I captured today (Sept 7th), and the date shown in the metadata panel of Bridge ays "Today". Yet, the Filter pane shows only "yesterday", not "today" as an option. When I click on "yesterday", Bridge displays the files that I took today! (And for the record, I'm using Bridge on Sept 7th, at 6 PM Pacific time when I'm posting this.)
  • Omke Oudeman
    Nov 27, 2004
    Sep 8, 2010 2:32 AM   in reply to dkosiur
    correctly.
    Don't experience this behavior on my system, works as expected. Can you
    specify which date are viewing, date created or date modified or both?
    And can you provide a screenshot of what you are seeing including the
    metadata panel content panel and filter panel?
    Have you already tried a purge cache for selection (choose the file you are
    looking at and with right mouse click choose purge cache for selection)
  • Omke Oudeman
    Nov 27, 2004
    Sep 13, 2010 2:51 AM   in reply to dkosiur
    Sorry, hope you can read the details...
    Thanks, screenshot is clear, I see it but can't believe my eyes I'm
    afraid....
    Tried to reproduce it on my system but can't achieve this, pictures shot at
    same day as 'today' give today in the filter panel and yesterday also
    correctly filtered.
    You have of course already checked the date and time of your camera?
    But that should reflect also the data in the EXIF shown under file
    properties in the Metadata section.
    Assuming you have already tried to reset the Bridge Preferences (holding
    down option key while restarting Bridge) you could also repeat this after
    having manual deleted the AdobeBridge4.plist file from the preference folder
    in the User library.
    If still no luck, a way to narrow the possibilities down is if you have CS4
    still installed you could try it in Bridge CS4 with the same files.
    If it shows correct in CS4 it might be related to your CS5 install  or to
    NEF from D200 and Bridge CS5.
    If it shows also incorrect in CS4 it might be related with your User account
    or OSX.
    Sep 25, 2010 2:55 PM   in reply to dkosiur
    dkosiur wrote:
    … Omar, and nothing changed…
    "Omar" ???
  • Omke Oudeman
    Nov 27, 2004
    Oct 1, 2010 1:44 PM   in reply to dkosiur
    I should also have mentioned that this only happens with one of my 3 cameras,
    the Olympus EP-2. Images from both the Leica DLUX-4 and Nikon D200 do not show
    this behavior.
    Then there lies probably your answer, it is due to Olympus Exif. Wether it
    has wrong exif or Adobe does not correspond with it I don't know but since
    others files do have no problem it is almost certain the EP-2 I'm afraid.
    Best go is to dive into Google for other stories or try the the contact
    button at the top of this forum page to open a case with Adobe Tech Support
    and find also tech support for your Olympus.
  • Omke Oudeman
    Nov 27, 2004
    Oct 1, 2010 2:26 PM   in reply to dkosiur
    I edited out that comment about the EP-2 .ORF files. If you go back and look
    at the screenshot I posted earlier, you'll see that the example I gave was for
    NEF files from my D200. So it is NOT camera specific.
    Sorry for that, have been away some time and respond using email so did not
    see the whole thread...
    Still puzzled and can't reproduce this behavior on my system. For the sake
    of experiment you could try to create a new user account just for testing
    and see if this is giving same behavior.
    I agree it is still a wild shot (but then again also a wild problem...) and
    it will tell if the current user account is the problem or not
    Nov 18, 2010 1:24 PM   in reply to Omke Oudeman
    I just upgraded to CS5 yesterday on two of our machines here and it looks like we're having similar problems - both machines. Could be a time zone thing? We're in New Zealand.
    Check this out:
    The first Today is today, the second yesterday, and the yesterday is the day before. Very confusing.
    Nov 24, 2010 1:14 PM   in reply to LukasPrime
    Does anyone have any clues on this? I use this feature a lot... I'm tempted to go back to CS4 until it's resolved.
    Jan 10, 2011 6:17 PM   in reply to LukasPrime
    I'm having the same issue in my Bridge CS5.  CS5 displays modified date of files I worked on today as "yesterday."
    I do not have the issue looking at the same files/folder in Bridge CS3. (CS3 displays correct modified date)
    Mar 11, 2011 2:28 PM   in reply to danr_photo
    Come on Adobe - how hard would this be to fix???
  • Pierre Courtejoie
    Jan 11, 2006
    May 18, 2012 3:15 AM   in reply to LukasPrime
    Moved this discussion to the enduring forum.
