"failed to retrieve item info" error when publising to Facebook
Sep 26, 2010 12:25 PM
I started to get the error mentioned in the title when I try to to pulish new pics to my Facebook account (existing folder, additional photos). This has worked before. Any idea what this means and how to resolve it?
It seems to always add the first photo on the list to Facebook, despite of the error. And it does it multiple times (multiple copies in Facebook) if I try to publish multiple times...
Using Lightroom 3.2 on Windows 7 x64.
Replies 1 2 Previous Next
    Sep 28, 2010 6:54 PM   in reply to AaliAlikoski
    I am having this exact same problem.  I'm using a MacBook Pro with Snow Leopard and Lightroom 3.2.  Publishing to SmugMug works every time.  Each time I try to publish to a Facebook folder I get this same error "failed to retrieve item info".  The first picture gets published over and over again but the others do not.  I have tried authorizing and deauthorizing my Facebook account and also deleting the publish services setup in Lightroom.  No luck!
    Any help would be appreciated.  Thanks.
    Sep 29, 2010 11:00 AM   in reply to BrianDesigns
    My problem occurs when I am exporting within LR - I don't export out to another program.
    Sep 30, 2010 6:08 PM   in reply to AaliAlikoski
    I am having the same issue... 1st photo gets uploaded over and over.. i have removed the publishing services over and over again and same thing.. please help
    Oct 13, 2010 2:08 PM   in reply to AaliAlikoski
    Exact same issue (one pic only and same error message) - so I was glad to see your suggestion of the jF plugin, and yes - that works fine - thanks
    Would be nice for the built in to work though.
    Nov 6, 2010 7:50 PM   in reply to AaliAlikoski
    I have the same problem, using Lightroom 3.2 and tyring to publish photos to Facebook.  I think it may have something to do with a previously published photo that had a modification to keyword.  It originally asked to republish these photos, but I would lose any comments associated with them.  I answered no to this, but then seems to get stuck in a publishing loop.  The first photo I am trying to publish appears to e getting duplicated on Facebook.
    I suspect this is a bug with the Publish to Facebook feature in 3.2.
    Nov 7, 2010 8:01 PM   in reply to AaliAlikoski
    Getting same error. LR 3.2. WinXP 32.
    Nov 14, 2010 10:48 AM   in reply to AaliAlikoski
    I've just stared getting the same error, is there any solution to this problem without resorting to third party pluggins?
    Dec 4, 2010 4:32 PM   in reply to AaliAlikoski
    I keep getting this error as well.  Is there any way to fix it yet?
    Dec 4, 2010 4:58 PM   in reply to bmiraflo1
    I haven't seen one.  The problem appears to be after uploading the image to FB and requesting the object info via the API. This fails, causing Lr to abort the operation.  But one image actually has been uploaded. Sounds like an API communications issue not handled gracefully by the plugin.
    Honestly, I may just switch to Friedl's uploaders since everything he does is usually pretty bullet-proof.
    Dec 11, 2010 3:16 PM   in reply to AaliAlikoski
    I've got exactly the same problems, same time ago i manged to public entire collections on facebook but three week ago it suddenly stop working giving me this error
    Dec 31, 2010 1:31 AM   in reply to AaliAlikoski
    I'm using Lightroom 3.3 with exactly the same issue on Windows 7 64bit.
    Anyone found a work-around?
    Jan 14, 2011 6:45 AM   in reply to AaliAlikoski
    I'm having the same issue. I'm a new LR user so at first I thought it was my noobness....Only workaround I have figured out is to resort the images so after each failed upload so you can then upload the next first image in your collection....very annoying.
    Jan 15, 2011 5:23 PM   in reply to AaliAlikoski
    This is definitely a bug somewhere.  I'm having the same problem.  I have created several Facebook albums, all from Lightroom.  However, today I can't, and I get this error.  It publishes one photo, renamed (not the way I told it to), then stops.  Each time it publishes another copy of the same photo (incorrectly renamed).  It doesn't matter if I create a new album, or try to republish one that's worked before.  It doesn't matter if I re-authenticate LR to Facebook.
    However, Jeffrey Friedl's plug-in, which I've downloaded today, works perfectly.
    Using LR 3.3 W7 64-bit.  When it was working OK, it might have been with the previous version (3.1?).
    Jan 31, 2011 11:13 PM   in reply to AaliAlikoski
    HI All,
    I too am having this issue.  Lightroom 3.3 / Win7 / x64.  Have tried the following without success.
         Renamed preference file and had the system build a new one.
         Created a new catalogue.
         Removed facebook authentication and started again.
         tried existing albums
         tried new albums
         Have not tried a rebuild of my machine.
         None of it works, always exactly the same error:  first picture is load to facebook, and then your out of there.
         My vote is that this is a bug as the third party plugin works perfectly.
    Not so patiently  waiting for a solution.
    Craig
    Feb 10, 2011 3:30 AM   in reply to AaliAlikoski
    Same problem as everyone else "Failed to retrieve item info" after upload. Photo uploads OK but does not transfer to the 'published' area in Lightroom and remains in 'to publish'. This problem has been around for months now but has only occurred after I re-installed LR3.3, could the problem lie here somewhere, but why hasn't it righted itself?
    Feb 10, 2011 5:38 AM   in reply to Colin Cadle
    Try logging out of the publish service and reauthenticating. But make sure you do this with a different browser -- one that you have never used to login to FB in the past so it forces you to authenticate fully via the browser, too. Do this by making your default browser some other browser temporarily.
    Feb 14, 2011 7:07 AM   in reply to AaliAlikoski
    Same error.
    Using Lightroom 3.3 on Windows 7 x64.
    This is clearly a bug and I hope Adobe addresses it in the next update.
    Feb 17, 2011 7:05 AM   in reply to AaliAlikoski
    Same here.
    LR 3.3/OS X 10.6.6
    Feb 17, 2011 8:31 AM   in reply to ChrisCasciano
    The FB publish service is really a proof-of-concept more than anything -- like it or not! I recommend using Friedl's FB service. It has a lot more useful bells and whistles, and it can be cheap as you feel.
    Other than that, this is some problem with getting publish/republish item info on the first rendition, which fails out the whole operation. We don't know why this is failing, and there is no debugging available to figure out why. Someone would have to create a similar plugin with debugging and hope they found the same problem.  FB recently updated their API, so this may be a problem that reflects that changes.
    Friedl's stuff is updated a lot more often.
    Feb 21, 2011 1:29 AM   in reply to AaliAlikoski
    Same problem Here.
    Tried removing authentication with no luck.
    Might it have something to do with recent Facebook gallery changes?
    Feb 23, 2011 11:38 AM   in reply to AaliAlikoski
    I have had the same problem...I use LR 3.3 on a Mac with the latest version of Snow Leopard.  However, the publish to Facebook function worked just fine on Nov. 21, 2010, when I successfully uploaded 12 photos to Facebook without incident.  I also had no problem posting just one photo on Jan. 1, 2011.  As far as I can recall, there have been no upgrades to LR since that time.  Nonetheless, when I tried to upload 6 photos a couple of days ago, I got the error message.  My own work around is to publish just one at a time, which is ok for me since I don't put much on Facebook.  Still, it would be really nice to know why this problem is happening.
    Feb 26, 2011 1:25 AM   in reply to AaliAlikoski
    I dont understand why this issue has been around since at least September and yet I do not see any response from someone on the LightRoom team.  What gives?  Can't you at least give us a status update as to what is going on here?  This is rediculous.
    Feb 26, 2011 3:52 AM   in reply to sirhensley555
    These are user-to-user forums; Adobe does not troll these forums looking for work.
    EIther raise this with Adobe, if you like, or wait Or use Friedl's plugin, which is much better.
    Feb 27, 2011 7:25 AM   in reply to AaliAlikoski
    I have the same error problem since last week.
    Mar 8, 2011 7:46 PM   in reply to CSS Simon
    We have been looking at this but haven't been able to reproduce it in house yet. CSS Simon, if you're still watching, I'd appreciate if you could explain what renaming option you're trying to use and how the names are coming out on Facebook instead. That sounds suspicious.
    Are others who are hitting this error also using renaming options or finding that photos are ending up on Facebook with unexpected names?
    Mar 8, 2011 8:17 PM   in reply to AaliAlikoski
    Same here.
    LR 3.3/OS X 10.6.6
    Mar 9, 2011 2:40 PM   in reply to Julie Kmoch
    Hi Julie,
         Thanks for looking at this.  The profile that I was using does not rename the files.  Sorry.
         Still consistent in failure, No diagnostic log being created.
    Craig
    Mar 9, 2011 2:57 PM   in reply to craigray
    Thanks, Craig. We're working directly with another customer who's seeing this and hope to have it figured out soon. Will keep this thread posted.
    Mar 9, 2011 11:55 PM   in reply to Julie Kmoch
    Only just read this.  I can't remember exactly what happened now, but if it's still useful, I'll try again tonight.
    Mar 11, 2011 2:56 AM   in reply to Julie Kmoch
    Hi Julie,
    I too am having the same issue, Win 7 x64 and LR 3.3. The issue is happening since around Sep or Nov 2010. The issue is the following: if you have a bunch of pictures marked to be published to FB, and try to publish them, it will only upload 1 picture, and then an error message will pop up "Failed to Retrieve Item Info". In FB only 1 picture gets uploaded (correctly named in my case). But the main bug I think we are all experiencing in this thread is NOT the random renaming of pictures (maybe that's a different bug, doesn't happen to me). The bug people are writing about in this thread is that the Publish to Facebook functionality has been broken for several months now, exiting with an error message. Functionality to publish to other services is not damaged, since I can publish to Flickr and others completely fine (the same pics that are giving me problems for FB).
    Thank you
    Mar 16, 2011 11:55 AM   in reply to newyuppie
    We think we have a fix but would appreciate getting a few more people to help test it since we have never been able to reproduce it ourselves. It would involve swapping in a different version of the Facebook plug-in. Any volunteers?
    Mar 16, 2011 12:19 PM   in reply to Julie Kmoch
    Try Me!
    Colin Cadle
    Photography by Colin Cadle
    Stoke Gabriel
    Devon
    United Kingdom
    Website - www.colincadle.co.uk
    Stock Library - www.cadledesign.co.uk
    Property Photography - www.cadledesign.com
    Photo clinic - www.thepropertyphotoclinic.com
    Phone: +44 (0) 1803 782858
    (Hours 08.00 - 18.30)
    Mobile: +44 (0) 7703 440777
    Mar 16, 2011 12:25 PM   in reply to Colin Cadle
    I'm happy to give it a go...
    Mar 16, 2011 12:28 PM   in reply to AaliAlikoski
    Hi Julie,
    I would love to try it out for you.  It would be great to see this problem finally resolved!  I've resorted to exporting out of Lightroom, importing in to iPhoto and then uploading to Facebook.  Not fun!
    Thanks for your work on this issue.
    Brian
    Mar 16, 2011 12:28 PM   in reply to Julie Kmoch
    I also want to volunteer, count me in!
    Mar 16, 2011 5:39 PM   in reply to Julie Kmoch
    Hi Julie,
         Happy to try out a new version of the plugin.
    Craig
    Mar 17, 2011 6:27 AM   in reply to AaliAlikoski
    I would be happy to try out the new facebook plug-in to see if it solves my everlasting problem with uploading from Lightroom.
1 2 Previous Next
Actions
