I havent used this component in about 2 months however when I
call any function from this component I recieve this error. "Branch
target offset too large for short" Ive searched and turned up
nothing.
I tested a really simple component that just returns the
argument sent to it even that threw this error. Im testing with CF7
on OS X using Jrun4. Ill include stack below, any help would be
awesome .
------------------------stack-------------------------------
Branch target offset too large for short
The error occurred in
/Applications/JRun4/servers/default/cfusion/BIGBLUE/v09/download/dlEngine.cfm:
line 5
3 : <cfif isDefined('ind_#ii#')>
4 : <cfinvoke component="COM.xDownload" method="tester"
returnvariable="fixal3Ret">
5 : <cfinvokeargument name="test" value="1"/>
6 : </cfinvoke>
7 : <cfabort showerror="#fixal3Ret#">
Resources:
* Check the ColdFusion documentation to verify that you are
using the correct syntax.
* Search the Knowledge Base to find a solution to your
problem.
Browser Mozilla/5.0 (Macintosh; U; PPC Mac OS X Mach-O;
en-US; rv:1.8.0.3) Gecko/20060426 Firefox/1.5.0.3
Remote Address 192.168.100.86
Referrer
http://192.168.100.86:8100/cfusion/BIGBLUE/v09/download/todays.cfm?mDir=%2FVolumes%2F192.168.100.16&...
Date/Time 24-May-06 06:54 AM
Stack Trace
at
cfdlEngine2ecfm322549419.runPage(/Applications/JRun4/servers/default/cfusion/BIGBLUE/v09/download/dlEngine.cfm:5)
org.apache.bcel.generic.ClassGenException: Branch target
at
org.apache.bcel.generic.BranchInstruction.dump(BranchInstruction.java:99)
at
org.apache.bcel.generic.InstructionList.getByteCode(InstructionList.java:980)
at
org.apache.bcel.generic.MethodGen.getMethod(MethodGen.java:587)
at
coldfusion.bytecode.JavaAssembler.getBytes(JavaAssembler.java:369)
at
coldfusion.compiler.FunctionAssembler.assemble(FunctionAssembler.java:56)
at
coldfusion.compiler.TemplateAssembler.assembleFunctions(TemplateAssembler.java:255)
at
coldfusion.compiler.TemplateAssembler.assemble(TemplateAssembler.java:66)
at
coldfusion.compiler.NeoTranslator.translateJava(NeoTranslator.java:308)
at
coldfusion.compiler.NeoTranslator.translateJava(NeoTranslator.java:106)
at
coldfusion.runtime.TemplateClassLoader$1.fetch(TemplateClassLoader.java:282)
at coldfusion.util.LruCache.get(LruCache.java:188)
at
coldfusion.runtime.TemplateClassLoader$TemplateCache.fetchSerial(TemplateClassLoader.java:223)
at
coldfusion.util.AbstractCache.fetch(AbstractCache.java:58)
at coldfusion.util.SoftCache.get(SoftCache.java:81)
at
coldfusion.runtime.TemplateClassLoader.findClass(TemplateClassLoader.java:422)
at
coldfusion.runtime.RuntimeServiceImpl.getFile(RuntimeServiceImpl.java:662)
at
coldfusion.runtime.RuntimeServiceImpl.resolveTemplatePath(RuntimeServiceImpl.java:629)
at
coldfusion.runtime.TemplateProxyFactory.getResolvedFile(TemplateProxyFactory.java:509)
at
coldfusion.runtime.TemplateProxyFactory.resolveName(TemplateProxyFactory.java:617)
at
coldfusion.tagext.lang.InvokeTag.doEndTag(InvokeTag.java:341)
at
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
at
coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:349)
at
coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at
coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:210)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at
coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
at
coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69)
at
coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:52)
at
coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at
coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at
coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at
coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at
coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:115)
at coldfusion.CfmServlet.service(CfmServlet.java:107)
at
coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
at
jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at
jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at
jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:259)
at
jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
at
jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at
jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
