PSE 9 organizer Mac not loading iPhoto
Sep 23, 2010 2:02 PM
One of the options is to import photos into Organizer from iPhoto. When I do this all I get is a spinning beachball forever. Any ideas how to fix this?
Replies 1 2 Previous Next
    Sep 23, 2010 9:31 PM   in reply to Neal Tobochnik
    Neal,
    How large is your iPhoto catalog? Are you able to import selected albums(a few of them) from Import from iPhoto dialog? There is an option in the dialog for that. if you click More option, you would see a listing of albums and events. You can selectively import them to Organizer. Please let me know if you are able to import from a few albums selected.
    ~V
    Sep 24, 2010 2:36 AM   in reply to Neal Tobochnik
    I am also getting this issue - my iphoto album is large.  I get the spinning beachball.  In activity monitor the app/process still seems to be using processing time but the OS reports it as hung.
    Is it worth just leaving it to see what happens?  The oranizer directory has zero files in it which is leading me to think it has actually hung.
    Sep 24, 2010 2:38 AM   in reply to swimboy1
    I would advice you to wait for sometime. Your iPhoto catalog must be large. Could you import some selected albums as I described above?
    ~V
    Sep 24, 2010 7:09 AM   in reply to ~V
    It still hangs with one small event
    Sep 24, 2010 9:11 AM   in reply to swimboy1
    It would be interesting information to just let it run for a while, even though the OS reports it as hung.
    Sep 26, 2010 10:15 AM   in reply to Neal Tobochnik
    I am also having this problem.  I have tried importing the entire library, then a small event. Neither works.  I have left the program running for over 2 hours to see if it would work and it does not.  I have been able to manually drag and drop photos from the iPhoto window into PSE 9 Organizer if I create an empty album and then select the photos in iPhoto and drag and drop to the Organizer window.  It them imports the photos.  Then I must select the photos I want and drop them into the new album I created.  Very cumbersome.  I must say that this a lot of trouble, especially when you have almost 5000 photos to move to PSE.
    Sep 26, 2010 10:56 AM   in reply to Neal Tobochnik
    Just tried something different which overcomes this problem.  In Organizer click the Display icon on the top right of the window and choose Folder location instead of thumbnail view.  The iPhoto files and folders them show on the left column in Organizer, then right click the folder you want and choose "import into organizer".  Once this is done click the "create instant album" icon in the center Organizer column and voila..you have imported the album on photos successfully.
    Sep 26, 2010 11:04 AM   in reply to jcazakoff
    Unfortunately, unless you have a referenced iphoto library, this is not good to do. If you are pointing the organizer to files in the iphoto library and letting it write there (the Import from iphoto option is designed to avoid doing this), you are going to corrupt your iphoto library, which can't stand much touching from outside iphoto itself. You could lose your photos.
    Sep 26, 2010 8:46 PM   in reply to Barbara B.
    Barbara,
    Import from iPhoto does not touch the iPhoto library and cannot corrupt it as it creates separate copies of the images in the folder that one specifies in the preference for saved files in the Organizer. So not by any chances, the iPhoto library should get corrupted. Please let us know if you are facing any issues with your iPhoto catalog.
    ~V
    Sep 26, 2010 8:51 PM   in reply to ~V
    I'm talking about the fact that it appears from jcazakoff's last post that possibly he or she made an end run around the import from iphoto command and is maybe using plain old Get Photos on the folders in the iphoto library, which would be a Bad Thing.
    Sep 26, 2010 8:52 PM   in reply to swimboy1
    Hi Neal/Swimboy1,
    Could you please attach the logs for the hang. You can get them while the application is hanging and you open Process monitor, select Adobe Elements 9 Organizer exe and click on "Sample Process" on the top. Please attach these logs so that we can look closely at them We appreciate your help.
    V
    Sep 26, 2010 9:28 PM   in reply to Barbara B.
    Yes Barbara. You are indeed correct. Importing from the iPhoto library through normal import command may lead to some problems as user would be further editing the pictures in Organizer which would get created in iPhoto library folder by default which may cause issues. So ideal would be to use import from iPhoto command specifically.
    V
    Sep 27, 2010 7:25 AM   in reply to ~V
    Here's my log, as requested (if easier give me an email address and I'll mail you the log):
    Sampling process 1139 for 3 seconds with 1 millisecond of run time between samples
    Sampling completed, processing symbols...
    Analysis of sampling Adobe Elements 9 Organizer (pid 1139) every 1 millisecond
    Process:         Adobe Elements 9 Organizer [1139]
    Path:            /Applications/Adobe Elements 9 Organizer.app/Contents/MacOS/Adobe Elements 9 Organizer
    Load Address:    0x1000
    Identifier:      com.adobe.ElementsOrganizer9
    Version:         9.0.(20100905.m.9093) (9.0)
    Code Type:       X86 (Native)
    Parent Process:  launchd [248]
    Date/Time:       2010-09-27 15:20:42.959 +0100
    OS Version:      Mac OS X 10.6.4 (10F569)
    Report Version:  6
    Call graph:
        2006 Thread_38102   DispatchQueue_1: com.apple.main-thread  (serial)
          2006 start
            2006 main
              2006 QCoreApplication::exec()
                2006 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
                  2006 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
                    2006 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFl ag>)
                      2006 -[NSApplication run]
                        2006 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:]
                          2006 _DPSNextEvent
                            2006 _NSHandleCarbonMenuEvent
                              2006 _HandleMenuSelection
                                2006 _HandleMenuSelection2
                                  2006 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*)
                                    2006 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*)
                                      2006 SendMenuItemSelectedEvent
                                        2006 SendMenuCommandWithContextAndModifiers
                                          2006 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**)
                                            2006 SendEventToEventTarget
                                              2006 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*)
                                                2006 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*)
                                                  2006 NSSLMMenuEventHandler
                                                    2006 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:]
                                                      2006 -[NSMenuItem _internalPerformActionThroughMenuIfPossible]
                                                        2006 -[NSMenu _internalPerformActionForItemAtIndex:]
                                                          2006 -[NSMenu performActionForItemAtIndex:]
                                                            2006 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:]
                                                              2006 -[NSMenuItem _corePerformAction]
        2006 -[NSApplication sendAction:to:from:]
        2006 -[QCocoaMenuLoader qtDispatcherToQAction:]
        2006 QAction::activate(QAction::ActionEvent)
        2006 QAction::triggered(bool)
        2006 QMetaObject::activate(QObject*, QMetaObject const*, int, void**)
        2006 QMenu::qt_metacall(QMetaObject::Call, int, void**)
        2006 QMenuPrivate::_q_actionTriggered()
        2006 QMenu::triggered(QAction*)
        2006 PtMenus::qt_metacall(QMetaObject::Call, int, void**)
        2006 PtMenus::slotImportMenuTriggered(QAction*)
        2006 QDialog::exec()
        2006 -[NSApplication runModalSession:]
        2006 -[NSApplication _realDoModalLoop:peek:]
        2006 -[NSApplication sendEvent:]
        2006 -[QCocoaPanel sendEvent:]
        2006 -[NSWindow sendEvent:]
        2006 -[QCocoaView mouseUp:]
        2006 qt_mac_handleMouseEvent(void*, void*, QEvent::Type, Qt::MouseButton)
        2006 qt_sendSpontaneousEvent(QObject*, QEvent*)
        2006 QCoreApplication::notifyInternal(QObject*, QEvent*)
        2006 PtApplication::notify(QObject*, QEvent*)
        2006 QApplication::notify(QObject*, QEvent*)
        2006 QApplicationPrivate::notify_helper(QObject*, QEvent*)
        2006 QPushButton::event(QEvent*)
        2006 QAbstractButton::event(QEvent*)
        2006 QWidget::event(QEvent*)
        2006 QAbstractButton::mouseReleaseEvent(QMouseEvent*)
        2006 QAbstractButtonPrivate::click()
        2006 QAbstractButtonPrivate::emitClicked()
        2006 QAbstractButton::clicked(bool)
        2006 PtImportFromIPhotoDlg::qt_metacall(QMetaObject::Call, int, void**)
        2006 PtImportFromIPhotoDlg::slotOkClicked()
        2006 getKeywordsOfMedia(sqlite3**, std::vector<std::string, std::allocator<std::string> >, std::map<std::string, std::map<eMetadataOrgType, std::string, std::less<eMetadataOrgType>, std::allocator<std::pair<eMetadataOrgType const, std::string> > >, std::less<std::string>, std::allocator<std::pair<std::string const, std::map<eMetadataOrgType, std::string, std::less<eMetadataOrgType>, std::allocator<std::pair<eMetadataOrgType const, std::string> > > > > >*)
        2006 iputil::getKeywordsOfMedia(sqlite3**, std::vector<std::string, std::allocator<std::string> >, std::map<std::string, std::map<eMetadataOrgType, std::string, std::less<eMetadataOrgType>, std::allocator<std::pair<eMetadataOrgType const, std::string> > >, std::less<std::string>, std::allocator<std::pair<std::string const, std::map<eMetadataOrgType, std::string, std::less<eMetadataOrgType>, std::allocator<std::pair<eMetadataOrgType const, std::string> > > > > >*)
        2006 sqlite3_get_table
        2006 sqlite3_exec
        2005 sqlite3_step
        2005 sqlite3Step
        1365 moveToLeftmost
        1351 moveToChild
        1318 getAndInitPage
        1315 sqlite3BtreeGetPage
        1307 pagerAcquire
        1249 readDbPage
        1241 unixRead
        817 read
        390 lseek
        34 unixRead
        5 readDbPage
        2 dyld_stub_lseek
        1 _sysenter_trap
        32 pagerAcquire
        10 __bzero
        9 sqlite3PagerPagecount
        5 unlinkPage
        3 unlinkPage
        2 listRemove
        2 unlinkHashChain
        4 memset
        4 sqlite3BtreeGetPage
        3 getAndInitPage
        24 sqlite3BtreeInitPage
        17 sqlite3BtreeInitPage
        7 decodeFlags
        7 moveToChild
        2 sqlite3PagerUnref
        11 moveToLeftmost
        3 sqlite3PagerUnref
        509 sqlite3Step
        35 btreeNext
        17 sqlite3BtreeMoveToParent
        11 sqlite3BtreeMoveToParent
        6 sqlite3PagerUnref
        5 sqlite3PagerUnref
        1 pageDestructor
        12 moveToChild
        12 getAndInitPage
        12 sqlite3BtreeGetPage
        12 pagerAcquire
        12 readDbPage
        12 unixRead
        10 read
        2 lseek
        5 btreeNext
        1 moveToLeftmost
        1 moveToChild
        1 getAndInitPage
        1 sqlite3BtreeGetPage
        1 pagerAcquire
        1 readDbPage
        1 unixRead
        1 read
        20 sqlite3BtreeDataSize
        11 sqlite3BtreeParseCellPtr
        8 sqlite3BtreeParseCellPtr
        3 sqlite3GetVarint
        6 sqlite3BtreeParseCell
        3 sqlite3BtreeDataSize
        20 sqlite3VdbeSerialGet
        19 sqlite3VdbeMemMakeWriteable
        16 sqlite3MemCompare
        8 applyAffinity
        5 applyAffinity
        3 applyNumericAffinity
        7 sqlite3VdbeCursorMoveto
        3 fetchPayload
        1 sqlite3BtreeMoveto
        1 moveToRoot
        1 getAndInitPage
        1 pagerAcquire
        1 sqlite3VdbeIdxKeyCompare
        1 sqlite3VdbeRecordCompare
        1 sqlite3MemCompare
        1 sqlite3_malloc
        1 malloc
        1 malloc_zone_malloc
        1 szone_malloc_should_clear
        1 tiny_malloc_from_free_list
        1 tiny_free_list_add_ptr
        1 sqlite3_column_text
        1 columnMem
        2006 Thread_38116   DispatchQueue_2: com.apple.libdispatch-manager  (serial)
          2006 start_wqthread
            2006 _pthread_wqthread
              2006 _dispatch_worker_thread2
                2006 _dispatch_queue_invoke
                  2006 _dispatch_mgr_invoke
                    2006 kevent
        2006 Thread_38129
          2006 thread_start
            2006 _pthread_start
              2006 C_AMTUISwitchSuppressUpdates
                2006 C_EULA_SetState
                    2006 pthread_cond_wait
                      2006 _pthread_cond_wait
                        2006 semaphore_wait_signal_trap
        2006 Thread_38139
          2006 thread_start
            2006 _pthread_start
              2006 ScObjects::Thread::go(void*)
                2006 ScObjects::BridgeTalkThread::run()
                  2006 ScObjects::Thread::sleep(unsigned int)
                    2005 nanosleep$UNIX2003
                      2005 __semwait_signal
                    1 cerror
        2006 Thread_38146
          2006 thread_start
            2006 _pthread_start
              2006 PrivateMPEntryPoint
                2006 0x34020ed
                  2006 0x34026f1
                    2006 MPWaitOnQueue
                      2006 TSWaitOnConditionTimedRelative
                          2006 pthread_cond_wait$UNIX2003
                              2006 __semwait_signal
        2006 Thread_38150
          2006 thread_start
            2006 _pthread_start
                2006 0x22e6ea56
                  2006 0x22e6f158
                    2006 MPWaitOnQueue
        2006 Thread_38151
          2006 thread_start
            2006 _pthread_start
              2006 0x22d74606
                2006 EntryFM
                  2006 0x22cb3dca
        2006 Thread_38157
          2006 thread_start
            2006 _pthread_start
                2006 OLSThread::ThreadProc(void*)
                  2006 OLSTaskThread::Run()
                    2006 OLSWorkerThreadTaskManager::ProcessTasks(OLSTaskThread*)
                      2006 OLSTask::Execute()
                        2006 OLSServiceTask::ExecuteInternal()
                          2006 OLSExecuteAutomatedTask::ExecuteStateInitialize()
                            2006 OLSSemaphore::Wait(unsigned int)
                              2006 MPWaitOnSemaphore
                                2006 semaphore_timedwait_trap
        2006 Thread_38159
          2006 thread_start
            2006 _pthread_start
              2006 Pt::ThreadStartInternal(void*)
                2006 PtSignalThread::start()
                  2006 sigwait
                    2006 __sigwait
        2006 Thread_38162
          2006 thread_start
            2006 _pthread_start
                2006 PtBackground::start()
                  2006 Pt::CondVar::wait_(Pt::Mutex&, int)
        2006 Thread_38163
          2006 thread_start
            2006 _pthread_start
        2006 Thread_38169
          2006 thread_start
            2006 _pthread_start
              2006 ExternalPlayer_Initialize
                2006 mach_msg
                  2006 mach_msg_trap
        2006 Thread_38170
          2006 thread_start
            2006 _pthread_start
              2006 0x23b27f98
                  2006 0x23b27ba6
        2006 Thread_38171
          2006 thread_start
            2006 _pthread_start
              2006 0x23b27f98
                  2006 0x23b27ba6
        2006 Thread_38188
          2006 thread_start
            2006 _pthread_start
              2006 waitformsg(void*)
                2006 open$UNIX2003
        2006 Thread_38190
          2006 thread_start
            2006 _pthread_start
              2006 __CFSocketManager
                2006 select$DARWIN_EXTSN
        2006 Thread_38223
          2006 thread_start
            2006 _pthread_start
              2006 tbb::internal::rml::private_worker::thread_routine(void*)
                2006 tbb::internal::rml::private_worker::run()
        2006 Thread_38225
          2006 thread_start
            2006 _pthread_start
              2006 QThreadPrivate::start(void*)
                2006 QHostInfoAgent::run()
                  2006 QWaitCondition::wait(QMutex*, unsigned long)
    Total number in stack (recursive counted multiple, when >=5):
            16       _pthread_start
            16       thread_start
            10       _pthread_cond_wait
            6       pthread_cond_wait
            5       __semwait_signal
    Sort by top of stack, same collapsed (when >= 5):
            semaphore_wait_signal_trap        12036
            __semwait_signal        10029
            __sigwait        2006
            kevent        2006
            mach_msg_trap        2006
            open$UNIX2003        2006
            select$DARWIN_EXTSN        2006
            semaphore_timedwait_trap        2006
            read        828
            sqlite3Step        509
            lseek        392
            unixRead        34
            pagerAcquire        33
            sqlite3VdbeSerialGet        20
            sqlite3VdbeMemMakeWriteable        19
            sqlite3BtreeInitPage        17
            sqlite3MemCompare        17
            moveToLeftmost        11
            sqlite3BtreeMoveToParent        11
            __bzero        10
            sqlite3PagerUnref        10
            sqlite3PagerPagecount        9
            sqlite3BtreeParseCellPtr        8
            decodeFlags        7
            moveToChild        7
            sqlite3VdbeCursorMoveto        7
            sqlite3BtreeParseCell        6
            applyAffinity        5
            btreeNext        5
            readDbPage        5
    Binary Images:
        0x1000 -  0x10d0fff +com.adobe.ElementsOrganizer9 9.0.(20100905.m.9093) (9.0) <FAB5FB92-4935-7DC6-AB9F-9A8BA2259EE3> /Applications/Adobe Elements 9 Organizer.app/Contents/MacOS/Adobe Elements 9 Organizer
    0x1ab6000 -  0x1b6bfe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
    0x1bb1000 -  0x1bd7fff  libssl.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <32607000-7573-6D51-ABC3-420B4A0D6629> /usr/lib/libssl.0.9.7.dylib
    0x1be6000 -  0x221afeb +AdobePDFL ??? (???) <FE54E313-3DE6-9491-DDBF-92F3D0CC5AE4> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/Adob ePDFL
    0x2346000 -  0x3089fff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <CFBCB19A-03F7-D095-1F48-8D68F05A25C5> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobePSL.framework/Versions/A/Adobe PSL
    0x33c8000 -  0x34dcfff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeACE.framework/Versions/A/Adobe ACE
    0x34ff000 -  0x380eff7 +AdobeAGM ??? (???) <202752CE-8950-5114-DD17-D5B087297A1F> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/Adobe AGM
    0x38c4000 -  0x38dffff +AdobeBIB ??? (???) <6E3DC6A9-066C-B736-6465-7F91D18860FB> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/Adobe BIB
    0x38e9000 -  0x3bdbff7 +AdobeCoolType ??? (???) <AEC9EB8F-2122-1708-3207-2A8BE3308FFA> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/ AdobeCoolType
    0x3c63000 -  0x3cceffb +com.adobe.amtlib amtlib 3.5.0.22 (3.5.0.22) <5F1923C1-CACB-1A7F-261D-580C26E50429> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
    0x3ce5000 -  0x3d7dfff +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7573) <F68E96A7-E657-7275-09DF-4C412554CD4A> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeExtendScript.framework/Version s/A/AdobeExtendScript
    0x3ddc000 -  0x3e6aff7 +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.1) <3B009A65-E429-12D2-A923-D26BA8425BF7> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/Ad obeScCore
    0x3ead000 -  0x3f05ff7 +AdobeXMP ??? (???) <81804842-72EB-80EC-0A9E-72368BC14C14> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/Adobe XMP
    0x3f14000 -  0x3fa0fef +AdobeXMPFiles ??? (???) <03DDE52B-E9AB-EFDD-CA13-C8DF1DB345D0> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/ AdobeXMPFiles
    0x3fd7000 -  0x4047feb +com.adobe.adobe_caps adobe_caps 3.5.4.0 (3.5.4.0) <36D53A2C-0DAB-34C6-48C7-49D2ECF52D0D> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/adobe_caps.framework/Versions/A/ado be_caps
    0x4052000 -  0x4075ff6 +AdobeAXE8SharedExpat ??? (???) <00010203-0405-0607-0809-0A0B0C0D0E0F> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Vers ions/A/AdobeAXE8SharedExpat
    0x4087000 -  0x40a8ff7 +AdobeBIBUtils ??? (???) <0405CA59-8136-7A32-CCDE-D5289F02B4EC> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/ AdobeBIBUtils
    0x40b4000 -  0x44b3fe7 +BreezeDB ??? (???) <6C98047B-531D-B244-AAFD-7C22794A8ABF> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/BreezeDB.framework/Versions/A/Breez eDB
    0x487a000 -  0x492efe3 +BreezePreprocess ??? (???) <A9F4DCE1-A993-C83E-5CB8-BA6704ADC46F> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/BreezePreprocess.framework/Versions /A/BreezePreprocess
    0x4a45000 -  0x4b38fe7 +BreezeRecognition ??? (???) <20F5C078-3BAE-43AA-3CF9-F1C77F5FAF9E> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/BreezeRecognition.framework/Version s/A/BreezeRecognition
    0x4d47000 -  0x4d69ff3 +CognitecRecognizer ??? (???) <E4027B48-770A-9BB9-17A6-B27D67BCD59E> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/CognitecRecognizer.framework/Versio ns/A/CognitecRecognizer
    0x4d95000 -  0x4e3affb +FaceDetector ??? (???) <1275F007-B8A7-CA23-8F89-570E182FCBA8> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/FaceDetector.framework/Versions/A/F aceDetector
    0x4f59000 -  0x4ff4fff +FaceTracker ??? (???) <73185DAE-21EE-F1F5-4C09-FA46463A7FE6> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/FaceTracker.framework/Versions/A/Fa ceTracker
    0x50b6000 -  0x50baffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeCrashReporter.framework/Versio ns/A/AdobeCrashReporter
    0x50c1000 -  0x50ddfff +com.yourcompany.mediacorewrapper 1.0 (1) <76E50328-640A-A393-0689-764A81DF9B10> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/mediacorewrapper.framework/Versions /A/mediacorewrapper
    0x50fe000 -  0x530afe3 +QtCore 4.6 (???) <14560A54-77F1-6154-199D-453F3587E889> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
    0x53ac000 -  0x5c6dffb +QtGui 4.6 (???) <E10E1EE9-C6FA-5486-AA6B-CAA3012E7763> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
    0x5f41000 -  0x602afe2 +QtNetwork 4.6 (???) <996C00E2-D32E-BC76-BEEB-EE1E2B8F2E32> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNe twork
    0x6083000 -  0x60b0ffd +QtSql 4.6 (???) <CD14AF34-DA95-733E-1965-9ADD23395A89> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/QtSql.framework/Versions/4/QtSql
    0x60c7000 -  0x6166fe2 +QtOpenGL 4.6 (???) <A85DADE1-53A4-E839-D31B-25F83A77AE79> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/QtOpenGL.framework/Versions/4/QtOpe nGL
    0x61a2000 -  0x61e5ff7 +QtSvg 4.6 (???) <90FF7407-7A16-E1E3-65C8-B21F1B138B2C> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/QtSvg.framework/Versions/4/QtSvg
    0x6205000 -  0x6252fff +QtXml 4.6 (???) <D2EF2476-4E15-E1A1-56B5-23B282532D47> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
    0x6273000 -  0x6359fe7 +com.yourcompany.ems 1.0 (1) <8AA2CFE8-DE2A-710B-8868-43DD9CC4E4D4> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ems.framework/Versions/A/ems
    0x63e0000 -  0x6401ff7 +pdf2img ??? (???) <82887C3D-8ACA-F652-4992-2ED5EFB7BF48> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/pdf2img.framework/Versions/A/pdf2im g
    0x6427000 -  0x6481ff7 +iplib ??? (???) <5703D3E1-34F2-7AF0-00E2-3AD972ECEEAF> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/iplib.framework/Versions/A/iplib
    0x6494000 -  0x65212cb +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <00010203-0405-0607-0809-0A0B0C0D0E0F> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6 /libicucnv.dylib.36.0
    0x654e000 -  0x656980f +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <00010203-0405-0607-0809-0A0B0C0D0E0F> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libi cudata.dylib.36.0
    0x656c000 -  0x66a4fe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/WRServices.framework/Versions/A/WRS ervices
    0x66e6000 -  0x6708ff7 +libtbb.dylib ??? (???) <AAA2AFA2-789A-41B8-D03D-C03861305060> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/libtbb.dylib
    0x671b000 -  0x671bff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
    0x671e000 -  0x7520fc7 +libfrsdk-8.3.1.so ??? (???) <94776BEC-AC4C-3B72-5355-6FB376C12D1A> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/libfrsdk-8.3.1.so
    0x7b3c000 -  0x7b7cff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
    0x7b95000 -  0x7bffff1 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <EFC0BBFC-3F87-64A6-1110-D1B453ACB255> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ ASLFoundation
    0x7cbf000 -  0x7cd4fff +ASLMessaging ??? (???) <A4554244-33F5-1F0A-2957-1783A906A4D7> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/A SLMessaging
    0x7cf4000 -  0x7d0dff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <CB61D760-918A-27BD-913C-1297F4BF42DC> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AudioFilterHost.framework/Versions/ A/AudioFilterHost
    0x7d34000 -  0x7d67fef +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <AE391B95-70B2-0610-8F4E-1F0DED369F62> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AudioFilters.framework/Versions/A/A udioFilters
    0x7dc7000 -  0x7e0cfef +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <72AAB04E-3423-E9FF-A067-962FA25AE728> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AudioSupport.framework/Versions/A/A udioSupport
    0x7e55000 -  0x8981fe7 +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <74CE7CE9-4204-22FF-01C0-9EE14E0A1EBC> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/Backend.framework/Versions/A/Backen d
    0x9673000 -  0x9674ffb +com.adobe.boost_system.framework boost_system version 8.0.0 (8.0.0.0) <0D07D6A7-9487-A0E3-927A-D83A05D7B11D> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/boost_system.framework/Versions/A/b oost_system
    0x967c000 -  0x97fafe7 +com.adobe.dvacore.framework dvacore version 8.0.0 (8.0.0.0) <37CEE7F0-8A20-5EA2-662D-E9F083F37070> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacor e
    0x9980000 -  0x99a1ff7 +com.adobe.dvamediatypes.framework dvamediatypes version 8.0.0 (8.0.0.0) <4BEF116D-9509-D615-F301-ABAA98355B38> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/ dvamediatypes
    0x99c2000 -  0x9b5bfff +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <9A1C6A8B-7F95-7AD7-6E87-55FC6C2238EF> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ImporterHost.framework/Versions/A/I mporterHost
    0x9d0b000 -  0x9d3ffe7 +com.adobe.MediaFoundation ??? (1.0) <F0752B77-0A58-A548-DF99-708025396D0D> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/MediaFoundation.framework/Versions/ A/MediaFoundation
    0x9d82000 -  0x9dbaff3 +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <16451533-9C73-D45C-A749-55D26C578056> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/MLFoundation.framework/Versions/A/M LFoundation
    0x9e08000 -  0x9e7dfff +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <A9165250-2A85-B9D7-8D0C-2E2432FCE470> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/PlayerHost.framework/Versions/A/Pla yerHost
    0x9f11000 -  0x9f4afff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <AAEBFE10-8CEE-6F49-A4E4-C75C1AA33123> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/PluginSupport.framework/Versions/A/ PluginSupport
    0x9f8b000 -  0x9f8bffb +PRM ??? (???) <E130E9E8-2A7E-CC4B-A16C-3705D3E4B5E9> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
    0x9f92000 -  0x9f9fff3 +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <6B2DB747-3DE0-4CC6-6411-774BFBEF01A2> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ProjectSupport.framework/Versions/A /ProjectSupport
    0x9fb4000 -  0x9fedfff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <ABA6A834-4B99-0BB8-E720-D892D3BD1FEB> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/ A/SweetPeaSupport
    0xa03e000 -  0xa10afff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <FDA10C7C-AADE-2103-B92C-F6BF2100DD3D> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/VideoFilterHost.framework/Versions/ A/VideoFilterHost
    0xa1c1000 -  0xa2dafff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <B58D30F8-1AE8-B8EE-13A8-58C8E1A7B53F> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/ VideoRenderer
    0xa43e000 -  0xa444fef +com.adobe.boost_date_time.framework boost_date_time version 8.0.0 (8.0.0.0) <E9665598-9C21-28BD-CA0F-D8B01F2B1DC7> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/boost_date_time.framework/Versions/ A/boost_date_time
    0xa456000 -  0xa45dff2 +com.adobe.boost_threads.framework boost_threads version 8.0.0 (8.0.0.0) <7489E61B-46B7-37C8-769B-2E5E3CB725A4> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/boost_threads.framework/Versions/A/ boost_threads
    0xa46d000 -  0xa46efff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <4A9B7FAA-F6EE-53FC-BAF3-0EA37F7C8463> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
    0xa475000 -  0xa485ffd +ASLUnitTesting ??? (???) <C9DD1D9D-05D7-C96E-2C9C-9322066B75D8> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A /ASLUnitTesting
    0xa49f000 -  0xa50ffff +com.adobe.dvatransport.framework dvatransport version 8.0.0 (8.0.0.0) <EBA903E4-F7E2-8082-FC6B-BCCBA3DFE644> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/dvatransport.framework/Versions/A/d vatransport
    0xa58f000 -  0xa5c9ffb +com.adobe.dvamarshal.framework dvamarshal version 8.0.0 (8.0.0.0) <0572647C-7CF1-F9D5-126E-6CD96B0EA738> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dva marshal
    0xa63f000 -  0xa804fe7 +com.adobe.dynamiclink.framework dynamiclink version 8.0.0 (8.0.0.0) <AC2861DD-B53F-54FB-8CA5-B337869101D4> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dy namiclink
    0xa929000 -  0xa99cff7 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <1B7A31C0-10D5-D99E-C687-BD142D6E2CAA> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/ AudioRenderer
    0xaa2f000 -  0xabbbffd +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <D20D0277-B7E6-3CB2-2702-FC16FA93ABE3> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ ImageRenderer
    0xacb1000 -  0xacfcff7 +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <F637A936-1A54-08A4-04CA-AA06E970A42B> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/VideoFrame.framework/Versions/A/Vid eoFrame
    0xad46000 -  0xad48ff3 +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <CF5134A6-F4B7-D115-A91E-2F5D87EF5593> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/MediaUtils.framework/Versions/A/Med iaUtils
    0xad4f000 -  0xafddfec +libxerces-c-3.0.dylib ??? (???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/libxerces-c-3.0.dylib
    0xb1d5000 -  0xb1d6ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0xb6e2000 -  0xb6eeff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.6 (2.2.6) <E0E936BE-D51D-AE16-B796-41B5028720C5> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
    0xb6f9000 -  0xb75efe7 +com.adobe.amt.services AMTServices 3.5.0.22 (BuildVersion: 3.5; BuildDate: Thu Aug 5 2010 21:49:00) (3.5.0.22) <928B1A16-6031-6BE2-C3DE-6E9C919C6C43> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/amtservices.framework/Versions/A/am tservices
    0xb77a000 -  0xb782fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
    0xb797000 -  0xb7d0ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.5.0.13 (1.5.0.13) <4F8229DD-D239-3773-1A53-51ECFA787463> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/UpdaterNotifications.framework/Vers ions/A/UpdaterNotifications
    0xfba0000 -  0xfbc5fe3 +libqjpeg.dylib 4.6.0 (compatibility 4.6.0) <05286F51-8EB2-DF36-5331-E872B8E2667B> /Applications/Adobe Elements 9 Organizer.app/Contents/QtPlugins/imageformats/libqjpeg.dylib
    0x10400000 - 0x1042dff3 +libcurl ??? (???) <00010203-0405-0607-0809-0A0B0C0D0E0F> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/libcurl.framework/libcurl
    0x21e1a000 - 0x21ed1ff7 +Photoshop Adapter ??? (???) <860F71FC-FA0A-EF68-1B79-91A1F55DFB2E> /Applications/Adobe Elements 9 Organizer.app/Contents/Plug-Ins/Organizer Only/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter
    0x2203f000 - 0x22181fe7 +com.adobe.ols.library 4.0 (4.0) <060FE05E-3C15-D620-D054-91EED2628F5C> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeOLS.framework/AdobeOLS
    0x22326000 - 0x2234ffe3  com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudi oKit
    0x223d9000 - 0x223d9ffe +org.xlife.InquisitorLoader 3.2 (58) <E4877EE4-5825-62D9-8C95-D447C8F77397> /Library/InputManagers/Inquisitor/Inquisitor.bundle/Contents/MacOS/In quisitor
    0x2240e000 - 0x22411fef  com.apple.LiveType.component 2.1.3 (2.1.3) <00010203-0405-0607-0809-0A0B0C0D0E0F> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x22416000 - 0x2247bfde  com.apple.LiveType.framework 2.1.3 (2.1.3) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveT ype
    0x2249b000 - 0x224f0fdf +com.DivXInc.DivXDecoder 6.8.3.5 (6.8.3.5) <00010203-0405-0607-0809-0A0B0C0D0E0F> /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0x2251e000 - 0x22521ff3 +com.divx.divxtoolkit 1.0 (1.0) <00010203-0405-0607-0809-0A0B0C0D0E0F> /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
    0x22536000 - 0x22537fff +com.cooliris.safariplugin ??? (1.7) <5568367D-4A7A-13C4-15BD-543AAB199199> /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Coolir is
    0x2253c000 - 0x2253dfff +com.1passwd.InputManager 2.5.9 (6080) <148EB390-8534-CE9B-D80B-DF45E20C013C> /Library/InputManagers/1PasswdIM/1PasswdIM.bundle/Contents/MacOS/1Pas swdIM
    0x22c6e000 - 0x234bffe7 +com.adobe.CameraRaw 6.1 (250) (6.1.0f250) <3A299A4B-A870-ED39-01E7-BC3B8CF56198> /Library/Application Support/Adobe/Plug-Ins/Elements 9/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
    0x23840000 - 0x23ee2fef +com.macromedia.Flash Player.authplaylib 10.0.2.31 (1.0.1d333) <E0851D48-16C9-4BDC-B3A7-7BAC9E7638F5> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/authplaylib.bundle/Contents/MacOS/A uthPlayLib
    0x24065000 - 0x24066ffd +com.newsfirex.Safari140 1.0 (2) <703BC772-6E36-EB66-526B-882432FEBAE4> /Library/InputManagers/Safari140/Safari140.bundle/Contents/MacOS/Safa ri140
    0x2406b000 - 0x24075fff +com.unsanity.smartcrashreports Smart Crash Reports version 1.5b3 (1.5b3) <7E3E7D42-BB62-6D09-E262-0140BA963851> /Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
    0x25200000 - 0x252c0fff +net.sourceforge.webcam-osx.common 0.9.2 (0.9.2) <00010203-0405-0607-0809-0A0B0C0D0E0F> /Library/QuickTime/macam.component/Contents/MacOS/macam
    0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <EF392886-5A95-6A96-C95D-43DA0322925C> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/Adob eJP2K
    0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
    0x90003000 - 0x9005eff7  com.apple.framework.IOKit 2.0 (???) <A013B850-6ECB-594A-CBD6-DB156B11871B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x90173000 - 0x9018bff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x901ac000 - 0x9041cffb  com.apple.Foundation 6.6.3 (751.29) <E77D3906-99F4-FEF4-FBB0-86FB3C94073E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x90459000 - 0x90509ff3  com.apple.ColorSync 4.6.3 (4.6.3) <AA1076EA-7665-3005-A837-B661260DBE54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x9050a000 - 0x9050bff7  com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
    0x9073d000 - 0x907a7fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
    0x907a8000 - 0x907b9ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x90879000 - 0x908affff  libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
    0x908b0000 - 0x908b0ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
    0x908b1000 - 0x9094cff7  com.apple.ApplicationServices.ATS 275.11.1 (???) <5FF65EC7-F512-530A-7771-3DE240EE6E43> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x90e4a000 - 0x90e4cff7  libRadiance.dylib ??? (???) <AB06F616-E3EA-5966-029A-8AA44BBE5B28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x90e8e000 - 0x91008fe3  com.apple.CoreFoundation 6.6.3 (550.29) <00373783-3744-F47D-2191-BEEA658F0C3D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x91011000 - 0x910baff7  com.apple.CFNetwork 454.9.8 (454.9.8) <DB2A5C33-E833-1B3A-4DE0-5FF172B2048B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x910bb000 - 0x911bcfe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
    0x911bd000 - 0x911caff7  com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x911cb000 - 0x9121bff7  com.apple.framework.familycontrols 2.0.1 (2010) <B9762E20-543D-13B9-F6BF-E8585F04CA01> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
    0x91273000 - 0x912e2ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x912e3000 - 0x912eaff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x912eb000 - 0x912f1ff7  libCGXCoreImage.A.dylib 543.50.0 (compatibility 64.0.0) <94F66BA6-A4E8-63A4-1B70-EFAA4C75D668> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage. A.dylib
    0x91334000 - 0x913dcffb  com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x913dd000 - 0x913ddff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x914e5000 - 0x91593ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x91594000 - 0x91595ff7  com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x91596000 - 0x91671fe7  com.apple.DesktopServices 1.5.7 (1.5.7) <A69072AD-C47E-A00D-4A69-6E46A7FB2119> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x91672000 - 0x916a3ff7  libGLImage.dylib ??? (???) <9340012D-595A-6243-9C97-7D30D76D9D9E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x918c7000 - 0x91cddff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x91cde000 - 0x91dedfe7  com.apple.WebKit 6533.18 (6533.18.1) <157D0DD9-F3CE-4339-858B-B0EFFAA3B008> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x91df1000 - 0x91e13fef  com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
    0x91e14000 - 0x91e29fff  com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x91f09000 - 0x91f17ff7  com.apple.opengl 1.6.9 (1.6.9) <4F06C166-00CF-5ACF-77E3-5A960A5E8AD3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x91f29000 - 0x91f76feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
    0x9207a000 - 0x9208cff7  com.apple.MultitouchSupport.framework 204.13 (204.13) <F91A4E32-01AA-49DB-2205-3DBE1FEFFC43> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
    0x9208d000 - 0x9210fffb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
    0x922ea000 - 0x92305ff7  libPng.dylib ??? (???) <36A3D75E-5178-4358-7F02-444E276D61AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x92307000 - 0x92435fe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x92467000 - 0x9249bff7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <0B900F26-51C1-7639-346F-24B080AEDAF3> /usr/lib/libssl.0.9.8.dylib
    0x924a6000 - 0x924ceff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
    0x925e7000 - 0x925e9ff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x92816000 - 0x92a0dfeb  com.apple.JavaScriptCore 6533.18 (6533.18.1) <EE3897A8-E1C0-DE28-A631-4B0C32DF737B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
    0x92a15000 - 0x92acefe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
    0x92b2a000 - 0x92ce4fe3  com.apple.ImageIO.framework 3.0.3 (3.0.3) <A93A514B-C1BF-21D0-FB03-CB775DE4FFAA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x92d04000 - 0x92d04ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x92d05000 - 0x92d19fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
    0x92d1a000 - 0x92d1dffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x92d2c000 - 0x92d6eff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x92db0000 - 0x92dbaff7  com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
    0x92f9e000 - 0x92fe2ff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x92fe3000 - 0x9302cfe7  libTIFF.dylib ??? (???) <9CFF48CC-4852-4D06-17AC-3C947C824159> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x9302d000 - 0x93030ff7  libCGXType.A.dylib 543.50.0 (compatibility 64.0.0) <3B49AED9-0DBA-9D21-F9AC-8784363AD762> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
    0x93031000 - 0x93820557  com.apple.CoreGraphics 1.545.0 (???) <DCED8E1A-7504-C31A-B6EF-98BFF1A61060> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x93878000 - 0x939afff7  com.apple.CoreAUC 6.04.01 (6.04.01) <B6E035A9-8DA2-82FC-9C2F-F57B9B62BE5F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
    0x93bbb000 - 0x93bc4ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x93bd5000 - 0x93bf6fe7  com.apple.opencl 12.1 (12.1) <DA2AC3FA-ED11-2D10-21E9-7BDF4778B228> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x93bf7000 - 0x93cadffb  libFontParser.dylib ??? (???) <067DC1A2-764B-41EA-B07E-4205472749B7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x93cae000 - 0x93cb3ff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
    0x93df7000 - 0x93e32feb  libFontRegistry.dylib ??? (???) <A102F61F-25D5-001A-20C3-56304C585072> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x93e33000 - 0x93e3aff3  com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x93e3b000 - 0x93e47ff7  libkxld.dylib ??? (???) <322A4B52-8305-3081-6B74-813C3A87A56D> /usr/lib/system/libkxld.dylib
    0x93e48000 - 0x93e66ff7  com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x93e67000 - 0x94747ff7  com.apple.AppKit 6.6.6 (1038.29) <6F28C335-6DC2-AE0E-B79A-F256DBD0BB45> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x94825000 - 0x94828fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
    0x94837000 - 0x94868ff3  libTrueTypeScaler.dylib ??? (???) <7601D717-236D-8F4E-91F5-E69BB2920478> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x94869000 - 0x9488dff7  libJPEG.dylib ??? (???) <5CE96981-6B2A-D15B-4A17-E7BD329095B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x9488e000 - 0x948a6ff3  com.apple.ScriptingBridge 1.1.2 (???) <01EEBDAB-C818-C2F4-576C-E916448F5D06> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/Scrip tingBridge
    0x94df4000 - 0x94e27ff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x94e28000 - 0x94e6bff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x94e6c000 - 0x94f1cfe3  com.apple.QuickTimeImporters.component 7.6.6 (1742) <76B0E668-214A-AB71-AAB8-E39E7F227C9B> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS /QuickTimeImporters
    0x94f1d000 - 0x94f39fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x94f45000 - 0x94f83ff7  com.apple.QuickLookFramework 2.2 (327.4) <88A59C42-A200-FCB6-23EC-E848D0E14963> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x94fc8000 - 0x95048feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x95049000 - 0x9536dfef  com.apple.HIToolbox 1.6.3 (???) <0A5F56E2-9AF3-728D-70AE-429522AEAD8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x9536e000 - 0x9540bfe3  com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x95424000 - 0x95444fe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
    0x956d6000 - 0x95802fff  com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x95803000 - 0x95806ff7  libCoreVMClient.dylib ??? (???) <CA0BA8DC-0159-A808-A300-750358A6970C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
    0x95807000 - 0x95807ff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x95808000 - 0x9598afe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <2314BD12-0821-75BB-F3BC-98D324CFD30A> /usr/lib/libicucore.A.dylib
    0x9598b000 - 0x9598bff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x9598c000 - 0x959b2fff  com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x959b3000 - 0x95abfff7  libGLProgrammability.dylib ??? (???) <1B315838-F477-5416-7504-67EC3433AD4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
    0x95ac0000 - 0x95ad4ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x95afd000 - 0x95b0dff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
    0x95b0e000 - 0x95ba0fe3  com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x95bcb000 - 0x95bcfff7  libGFXShared.dylib ??? (???) <2D32BDBF-C941-93FD-E233-F03D28DB9E94> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
    0x95c0e000 - 0x96b5efe3  com.apple.QuickTimeComponents.component 7.6.6 (1742) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
    0x96b6a000 - 0x96b74fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x96b75000 - 0x96bb9fe7  com.apple.Metadata 10.6.3 (507.10) <630494FA-3BB3-EDD3-E10B-8DAAF4831E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x96bbc000 - 0x96bf4ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <76C02F5C-98FD-BD64-B5FB-C698FB76EA25> /usr/lib/libcups.2.dylib
    0x96ff9000 - 0x9719ffeb  libSystem.B.dylib 125.2.0 (compatibility 1.0.0) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
    0x971a0000 - 0x971a6fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x971a7000 - 0x971a7ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x971a8000 - 0x971a8ffb  libffi.dylib ??? (???) <58985323-6EC6-9AD2-B9F0-8787C0B2791C> /usr/lib/libffi.dylib
    0x971a9000 - 0x971d3ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
    0x971d4000 - 0x97235fe7  com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x97236000 - 0x97241ff7  libGL.dylib ??? (???) <B87E0676-F5EF-8DA3-6DEE-13C43B3832A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x97242000 - 0x97334ff7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <D2C86308-F998-C83D-F49B-CD484D4EFE6A> /usr/lib/libcrypto.0.9.8.dylib
    0x97335000 - 0x9733fffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x97340000 - 0x9740afef  com.apple.CoreServices.OSServices 357 (357) <CF9530AD-F581-B831-09B6-16D9F9283BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x9740b000 - 0x97448ff7  com.apple.SystemConfiguration 1.10.2 (1.10.2) <398BB007-41FD-1A30-26D8-CB86ED5E467E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x97449000 - 0x97481fe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <242954AD-3BE1-29E8-E2E0-08063201F105> /usr/lib/libcurl.4.dylib
    0x97482000 - 0x976e6fef  com.apple.security 6.1.1 (37594) <3F68A006-6B30-85D5-1A75-8D748F72A6D5> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x976ec000 - 0x9773dff7  com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x9773e000 - 0x977b9fe7  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <51D0E2DC-B15F-AF6C-70D8-026DDAD4E2A5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x977dc000 - 0x98227ff7  com.apple.WebCore 6533.18 (6533.18.1) <B96BFDB8-3D11-E220-1148-206D8A176352> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/Web Core.framework/Versions/A/WebCore
    0x98241000 - 0x9824cff7  libCSync.A.dylib 543.50.0 (compatibility 64.0.0) <4FA0CE4A-BDE5-0E3D-37F0-03B41F0C2637> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x9824d000 - 0x98293ff7  libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
    0x98294000 - 0x98388ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
    0x98389000 - 0x98421fe7  edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x98422000 - 0x984f3fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <8FDB4C40-D453-DA53-2A66-9A53998AB23C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/C olorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x98507000 - 0x9854aff7  libGLU.dylib ??? (???) <2093A1FB-67BD-39E0-CDE5-A97A77BDDBCE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x9854b000 - 0x9886bfeb  com.apple.CoreServices.CarbonCore 861.13 (861.13) <52803668-3669-36BD-57DD-078FBA835081> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x9886c000 - 0x9886cff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x9886d000 - 0x98871ff7  IOSurface ??? (???) <66E11D8E-CF4B-EFD0-37F9-20177C647021> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x98872000 - 0x9894fff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x98950000 - 0x9895efe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
    0x9895f000 - 0x989a0ff7  libRIP.A.dylib 543.50.0 (compatibility 64.0.0) <8BAE1FC1-A478-F151-17C7-2D5DE470AC4F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x989a1000 - 0x98d4ffe3  com.apple.RawCamera.bundle 3.3.0 (533) <05A38D21-8556-434C-8BAA-850A6EC99B37> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
    0x98d50000 - 0x98db4ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x98db5000 - 0x9911dff7  com.apple.QuartzCore 1.6.2 (227.22) <4288F0D2-0C87-F054-C372-8764B44DE024> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x9911e000 - 0x99417fef  com.apple.QuickTime 7.6.6 (1742) <89720F2A-F33B-FF09-3D81-F9F25A99F3EB> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x99418000 - 0x99418ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x99419000 - 0x994c6fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
    0x994c7000 - 0x998fcff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x99904000 - 0x99908ff7  libGIF.dylib ??? (???) <3ECD4D2C-40FE-E9A0-A2D2-E36D1C00D3A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x99964000 - 0x9999cff7  com.apple.LDAPFramework 2.0 (120.1) <001A70A8-3984-8E19-77A8-758893CC128C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0xb0000000 - 0xb000fff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <24B39C2F-79B0-BDE3-C6D0-1F0E943070C7> /Applications/Adobe Elements 9 Organizer.app/Contents/Frameworks/ahclient.framework/Versions/A/ahcli ent
    0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
    Sample analysis of process 1139 written to file /dev/stdout
    Sep 27, 2010 10:35 AM   in reply to ~V
    Sep 27, 2010 3:46 PM   in reply to jcazakoff
    Sampling process 3889 for 3 seconds with 1 millisecond of run time between samples
    Analysis of sampling Adobe Elements 9 Organizer (pid 3889) every 1 millisecond
    Call graph:
        2132 Thread_124658   DispatchQueue_1: com.apple.main-thread  (serial)
          2132 start
            2132 main
              2132 QCoreApplication::exec()
                2132 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)
                  2132 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
                    2132 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFl ag>)
                      2132 -[NSApplication run]
                        2132 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:]
                          2132 _DPSNextEvent
                            2132 _NSHandleCarbonMenuEvent
                              2132 _HandleMenuSelection
                                2132 _HandleMenuSelection2
                                  2132 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*)
                                    2132 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*)
                                      2132 SendMenuItemSelectedEvent
                                        2132 SendMenuCommandWithContextAndModifiers
                                          2132 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**)
                                            2132 SendEventToEventTarget
                                              2132 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*)
                                                2132 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*)
                                                  2132 NSSLMMenuEventHandler
                                                    2132 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:]
                                                      2132 -[NSMenuItem _internalPerformActionThroughMenuIfPossible]
                                                        2132 -[NSMenu _internalPerformActionForItemAtIndex:]
                                                          2132 -[NSMenu performActionForItemAtIndex:]
                                                            2132 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:]
                                                              2132 -[NSMenuItem _corePerformAction]
        2132 -[NSApplication sendAction:to:from:]
        2132 -[QCocoaMenuLoader qtDispatcherToQAction:]
        2132 QAction::activate(QAction::ActionEvent)
        2132 QAction::triggered(bool)
        2132 QMetaObject::activate(QObject*, QMetaObject const*, int, void**)
        2132 QMenu::qt_metacall(QMetaObject::Call, int, void**)
        2132 QMenuPrivate::_q_actionTriggered()
        2132 QMenu::triggered(QAction*)
        2132 PtMenus::qt_metacall(QMetaObject::Call, int, void**)
        2132 PtMenus::slotImportMenuTriggered(QAction*)
        2132 QDialog::exec()
        2132 -[NSApplication runModalSession:]
        2132 -[NSApplication _realDoModalLoop:peek:]
        2132 -[NSApplication sendEvent:]
        2132 -[QCocoaPanel sendEvent:]
        2132 -[NSWindow sendEvent:]
        2132 -[QCocoaView mouseUp:]
        2132 qt_mac_handleMouseEvent(void*, void*, QEvent::Type, Qt::MouseButton)
        2132 qt_sendSpontaneousEvent(QObject*, QEvent*)
        2132 QCoreApplication::notifyInternal(QObject*, QEvent*)
        2132 PtApplication::notify(QObject*, QEvent*)
        2132 QApplication::notify(QObject*, QEvent*)
        2132 QApplicationPrivate::notify_helper(QObject*, QEvent*)
        2132 QPushButton::event(QEvent*)
        2132 QAbstractButton::event(QEvent*)
        2132 QWidget::event(QEvent*)
        2132 QAbstractButton::mouseReleaseEvent(QMouseEvent*)
        2132 QAbstractButtonPrivate::click()
        2132 QAbstractButtonPrivate::emitClicked()
        2132 QAbstractButton::clicked(bool)
        2132 PtImportFromIPhotoDlg::qt_metacall(QMetaObject::Call, int, void**)
        2132 PtImportFromIPhotoDlg::slotOkClicked()
        2132 getMediaOfAlbums(sqlite3**, std::vector<std::string, std::allocator<std::string> >, bool, std::map<std::string, std::map<eMetadataOrgType, std::string, std::less<eMetadataOrgType>, std::allocator<std::pair<eMetadataOrgType const, std::string> > >, std::less<std::string>, std::allocator<std::pair<std::string const, std::map<eMetadataOrgType, std::string, std::less<eMetadataOrgType>, std::allocator<std::pair<eMetadataOrgType const, std::string> > > > > >*)
        2132 iputil::getMediaOfAlbums(sqlite3**, std::vector<std::string, std::allocator<std::string> >, bool, std::map<std::string, std::map<eMetadataOrgType, std::string, std::less<eMetadataOrgType>, std::allocator<std::pair<eMetadataOrgType const, std::string> > >, std::less<std::string>, std::allocator<std::pair<std::string const, std::map<eMetadataOrgType, std::string, std::less<eMetadataOrgType>, std::allocator<std::pair<eMetadataOrgType const, std::string> > > > > >*)
        2132 sqlite3_get_table
        2132 sqlite3_exec
        2132 sqlite3_step
        2132 sqlite3Step
        1464 moveToLeftmost
        1454 moveToChild
        1414 getAndInitPage
        1409 sqlite3BtreeGetPage
        1404 pagerAcquire
        1327 readDbPage
        1313 unixRead
        867 read$NOCANCEL$UNIX2003
        411 lseek
        35 unixRead
        9 readDbPage
        2 _sysenter_trap
        2 dyld_stub_lseek
        1 dyld_stub_read
        31 unlinkPage
        22 listRemove
        9 unlinkPage
        26 pagerAcquire
        11 sqlite3PagerPagecount
        9 __bzero
        3 sqlite3BtreeGetPage
        1 dyld_stub_memset
        1 memset
        5 getAndInitPage
        26 sqlite3BtreeInitPage
        23 sqlite3BtreeInitPage
        3 decodeFlags
        12 moveToChild
        2 sqlite3PagerUnref
        9 moveToLeftmost
        1 sqlite3PagerUnref
        510 sqlite3Step
        40 btreeNext
        21 sqlite3BtreeMoveToParent
        10 sqlite3PagerUnref
        7 sqlite3PagerUnref
        3 pageDestructor
        2 pageDestructor
        1 sqlite3PagerUnref
        15 moveToChild
        14 getAndInitPage
        14 sqlite3BtreeGetPage
        14 pagerAcquire
        13 readDbPage
        13 unixRead
        6 lseek
        5 read$NOCANCEL$UNIX2003
        2 unixRead
        1 __bzero
        1 sqlite3PagerUnref
        4 btreeNext
        28 sqlite3VdbeSerialGet
        26 sqlite3BtreeDataSize
        14 sqlite3BtreeParseCellPtr
        6 sqlite3GetVarint
        23 sqlite3MemCompare
        13 applyAffinity
        7 applyAffinity
        6 applyNumericAffinity
        12 sqlite3VdbeMemMakeWriteable
        9 sqlite3VdbeCursorMoveto
        6 fetchPayload
        1 sqlite3VdbeMemRelease
        1 sqlite3_free
        1 free
        1 __spin_lock
        2132 Thread_124673   DispatchQueue_2: com.apple.libdispatch-manager  (serial)
          2132 start_wqthread
            2132 _pthread_wqthread
              2132 _dispatch_worker_thread2
                2132 _dispatch_queue_invoke
                  2132 _dispatch_mgr_invoke
                    2132 kevent
        2132 Thread_124682
          2132 thread_start
            2132 _pthread_start
              2132 C_AMTUISwitchSuppressUpdates
                2132 C_EULA_SetState
                    2132 pthread_cond_wait
                      2132 _pthread_cond_wait
                        2132 semaphore_wait_signal_trap
        2132 Thread_124685
          2132 thread_start
            2132 _pthread_start
              2132 ScObjects::Thread::go(void*)
                2132 ScObjects::BridgeTalkThread::run()
                  2130 ScObjects::Thread::sleep(unsigned int)
                    2130 nanosleep$UNIX2003
                      2130 __semwait_signal
                  2 ScObjects::BridgeTalkThread::runLocked()
                    1 MacInterAppStream::messagePending() const
                      1 CFRunLoopRunInMode
                        1 CFRunLoopRunSpecific
                          1 __CFRunLoopRun
                            1 CFAllocatorDeallocate
                    1 ScObjects::BridgeTalk::processIncomingMessage(unsigned long, bool)
                      1 BridgeTalkData::MessageQueue::removeExpiredMessages()
                        1 hasTimedOut(ScObjects::BridgeTalk::Message const&)
                          1 BridgeTalkUtils::getTimeSeconds()
        2132 Thread_124691
          2132 thread_start
            2132 _pthread_start
              2132 PrivateMPEntryPoint
                2132 0x33f70ed
                  2132 0x33f76f1
                    2132 MPWaitOnQueue
                      2132 TSWaitOnConditionTimedRelative
                          2132 pthread_cond_wait$UNIX2003
                              2132 __semwait_signal
        2132 Thread_124693
          2132 thread_start
            2132 _pthread_start
                2132 0x22538a56
                  2132 0x22539158
                    2132 MPWaitOnQueue
        2132 Thread_124694
          2132 thread_start
            2132 _pthread_start
              2132 0x2243e606
                2132 EntryFM
                  2132 0x2237ddca
        2132 Thread_124695
          2132 thread_start
            2132 _pthread_start
                2132 OLSThread::ThreadProc(void*)
                  2132 OLSTaskThread::Run()
                    2132 OLSWorkerThreadTaskManager::ProcessTasks(OLSTaskThread*)
                      2132 OLSTask::Execute()
                        2132 OLSServiceTask::ExecuteInternal()
                          2132 OLSExecuteAutomatedTask::ExecuteStateInitialize()
                            1879 OLSSemaphore::Wait(unsigned int)
                              1879 MPWaitOnSemaphore
                                1879 semaphore_timedwait_trap
                            253 OLSHTTPTransactionManager::IsConnected() const
                              253 SCNetworkCheckReachabilityByName
                                253 SCNetworkReachabilityGetFlags
                                  253 __SCNetworkReachabilityGetFlags
                                    253 getaddrinfo
                                      253 si_addrinfo
                                        253 search_addrinfo
                                          236 _mdns_addrinfo
                                            236 _mdns_search
                                              236 _mdns_query_mDNSResponder
                                                236 kevent
                                          17 ds_addrinfo
                                            17 LI_DSLookupQuery
                                              17 libinfoDSmig_Query
                                                17 mach_msg
                                                  17 mach_msg_trap
        2132 Thread_124697
          2132 thread_start
            2132 _pthread_start
              2132 QThreadPrivate::start(void*)
                2132 QHostInfoAgent::run()
                  2132 QWaitCondition::wait(QMutex*, unsigned long)
        2132 Thread_124698
          2132 thread_start
            2132 _pthread_start
              2132 Pt::ThreadStartInternal(void*)
                2132 PtSignalThread::start()
                  2132 sigwait
                    2132 __sigwait
        2132 Thread_124701
          2132 thread_start
            2132 _pthread_start
                2132 PtBackground::start()
                  2132 Pt::CondVar::wait_(Pt::Mutex&, int)
        2132 Thread_124702
          2132 thread_start
            2132 _pthread_start
        2132 Thread_124705
          2132 thread_start
            2132 _pthread_start
              2132 __CFSocketManager
                2132 select$DARWIN_EXTSN
        2132 Thread_124709
          2132 thread_start
            2132 _pthread_start
              2132 ExternalPlayer_Initialize
                2132 mach_msg
                  2132 mach_msg_trap
        2132 Thread_124710
          2132 thread_start
            2132 _pthread_start
              2132 0x234e7f98
                  2132 0x234e7ba6
        2132 Thread_124711
          2132 thread_start
            2132 _pthread_start
              2132 0x234e7f98
                  2132 0x234e7ba6
        2132 Thread_124782
          2132 thread_start
            2132 _pthread_start
              2132 waitformsg(void*)
                2132 open$UNIX2003
        2132 Thread_124790
          2132 thread_start
            2132 _pthread_start
              2132 tbb::internal::rml::private_worker::thread_routine(void*)
                2132 tbb::internal::rml::private_worker::run()
            16       _pthread_start
            16       thread_start
            6       pthread_cond_wait
            5       __semwait_signal
            5       sqlite3PagerUnref
            semaphore_wait_signal_trap        12792
            __semwait_signal        10658
            kevent        2368
            mach_msg_trap        2149
            __sigwait        2132
            open$UNIX2003        2132
            select$DARWIN_EXTSN        2132
            semaphore_timedwait_trap        1879
            read$NOCANCEL$UNIX2003        872
            sqlite3Step        510
            lseek        417
            unixRead        37
            sqlite3VdbeSerialGet        28
            pagerAcquire        26
            sqlite3BtreeInitPage        23
            sqlite3MemCompare        23
            listRemove        22
            moveToChild        12
            sqlite3PagerUnref        12
            sqlite3VdbeMemMakeWriteable        12
            sqlite3PagerPagecount        11
            __bzero        10
            moveToLeftmost        9
            readDbPage        9
            sqlite3VdbeCursorMoveto        9
            unlinkPage        9
            applyAffinity        7
            applyNumericAffinity        6
            fetchPayload        6
            sqlite3BtreeDataSize        6
            sqlite3GetVarint        6
            getAndInitPage        5
    Sample analysis of process 3889 written to file /dev/stdout
    Sep 27, 2010 5:05 PM   in reply to Barbara B.
    Actually neither of the two methods seems to write anything over the originals in the iPhoto Library.  I have done checks of both methods and made edits of some photos which I then saved in PSE 9.  The edited images are saved as edited copies and the original iPhoto data is not altered.  I reopened iPhoto and the original was there untouched. I would much rather use the import from iPhoto dialogue but it does not seem to work.  So if someone has an answer, it would be great.
    BTW when I used the "folder display" method, organizer "showed" the animation of files being "imported" on the display, so I don't think that there is any damage done to the data and it imported correctly.  No other problems yet anyway.
    Oct 21, 2010 9:49 PM   in reply to jcazakoff
    After studying the logs and investigating it further with the help of one of the users(Richard Leake) facing this issue, we could see that the copying of the data(17-20GB) of files is taking the most of the time. After a wait of 16 minutes, Richard was able to import these files into Organizer.
    We are working on finding a resolution to this issue. In the meantime, we would recommend you to log a bug in our bug database at https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform.
    jcazakoff,
    Importing from folder view imports only the files. File metadata, albums, tags and events do not get imported. Importing from iPhoto imports all the metadata, tags, albums, events etc.
    Regarding your point about writing in iPhoto library, we create copies of all files from iPhoto in order to avoid corruption of iPhoto library. Since user can edit a file in PSE 9 with the same name through PSE Editor, so it was not good to overwrite anything in iPhoto library.
    I hope that helps.
    ~V
    Oct 22, 2010 12:18 PM   in reply to ~V
    I had the same problem as the others are experiencing...I downloaded trial version of PSE9 and at the point when the Organizer was ready to upload photos from my iphoto I got the spinning beach ball that lasted forever until I finally gave up and "force quit" the program.  After going through this process 3 different times and receiving the same results I lost my entire iphoto library!  I have not been able to locate my entire iphoto library anywhere at this point and it is not in the organizer.  I was able to find some of my pictures on the hard drive but not all of them?  Thankfully, I did have most everything backed up online.  I did sent a report when the error occurred as prompted on the screen, however I was hoping someone might direct to me to where (if anywhere) all of my pictures from iphoto might be on my hard drive?
    Any ideas when a fix will be available for this...thus far I feel it is useless to me if I cannot get my photos in pse to edit...and honestly I am fearful of losing what I was able to find again my continuing to mess with the program.
    Thanks.
    J. Lewis
    Oct 22, 2010 12:25 PM   in reply to jennlutz
    The iphoto library is normally in your username>Pictures, unless you deliberately moved it. Be sure you are looking at a high enough level in your user folder, not in your username>library, for instance.
    Oct 22, 2010 12:45 PM   in reply to Barbara B.
    That is where I looked initially...thinking that they would still be there!  Unfortunately, only about 4 albums were actually there and the others had vanished.  I looked further and ended up finding most of my photos under username/pictures/Adobe/Organizer/iphoto library media/modified.  Then there are two folders dated 2009 and 2010 with the majority of my photos in them.  Also there is a folder underneath modified "originals" which also has some photos in it.  This would suggest to me that my photos are in pse9 organizer...BUT they are not??  When I open up pse9 organizer...nothing is in the albums column??
    Unfortunately I am not mac savvy enough to have moved my iphotos anywhere...I have been a windows user forever until last year so I am still learning the ins and outs of mac.
    Thanks for your help!
    J. Lewis
    Oct 22, 2010 12:51 PM   in reply to jennlutz
    Unless you went to the trouble of setting up a referenced library, the important file for iphoto is the one called iphoto library. Do not mess around with that file or go poking around in it from outside iphoto, or you will eventually have trouble, lots of it. Just look to see if it's there.
    Oct 22, 2010 12:52 PM   in reply to Barbara B.
    Nope...completely empty!  When I click on it it asks me to create a new library or to select a library...however there are no other libraries to select from?
    J. Lewis
    Oct 22, 2010 12:58 PM   in reply to jennlutz
    Click on what? You don't click on anything here. In a finder window, in your user folder, in the pictures folder, do you or don't you have that file?
    Oct 22, 2010 1:14 PM   in reply to Barbara B.
    Yes, I have this folder...but when I click on it...the iphoto program opens up and asks me to create a new library or select a library??
    Oct 22, 2010 1:25 PM   in reply to jennlutz
    Okay, then you do have your iphoto library. Open iphoto, and if it asks you, point it to that file.
    EDIT Not by double clicking the library. Open iphoto normally.
    Oct 23, 2010 4:19 AM   in reply to Neal Tobochnik
    I have the same problem :-(  as the others are experiencing...
    My iPhoto gallery is still importing (approx.20 minutes), and PS Elements 9 Organizer hangs! Just rotating, colorful ball and no progress bar, why?
    in iPhoto I have > 5000 pictures
    OK Update: after 25 minutes of rotating, colorful ball disappeared and finally the progress bar appeared importing my >5000 pictures. It's extremely frustrating that during 25 minutes there is no progress bar , no information what's going on. Definitely it's a bug demanding correction.
    Message was edited by: kondzik
    Oct 23, 2010 10:37 AM   in reply to kondzik
    I only had approximately 3000 pictures in my iphoto library and they are all gone with the exception of what I have been able to locate in other folders on my computer...so tread carefully and make sure your pictures are backed up!  I hope you have better luck with it than I have.  Thus far I have been unsuccessful in getting pictures into organizer and being able to edit in pse 9.
    I tried to get my library back but everytime I clicked on the program icon on my desk top a box opened up requesting that I create a "new library" or open a library, however nothing was listed in the box for me to select an existing library and there was no way for me to browse folders to locate a library elsewhere.  I finally gave up and selected to start a new library to just get myself into the program.  It would not even allow me into iphoto without selecting something.  So I guess I will start my iphoto library over again
    Unfortunately I am still not sure what to do about pse 9 or organizer at this point...not sure anyone else does either.
    J. Lewis
    Oct 23, 2010 4:04 PM   in reply to jennlutz
    But have you tried any of the repair options in iphoto yet?
    Hold down the command and option keys while launching iPhoto, which will give you a window where you have options for repairing. If that doesn't do it, you can try iPhoto library manager.
    Oct 23, 2010 8:01 PM   in reply to Barbara B.
    I had no idea!!!  This is exactly what I was looking for...I am going to attempt this now and if it doesn't work then I will download the other option and try it that way.  I finally was able to upload the iphoto library (about 2700 pics) that I pieced back together from the pictures I found elsewhere on my hard drive this afternoon to pse9 organizer!  If only I can retrieve some of my missing photos and the other library...I would be so happy!
    Since I uploaded the other iphoto library to pse9 organizer...things appear to be working smoothly!
    Thanks so much for all of your suggestions and help.  I will update if this works with rebuilding my old iphoto library!
    Oct 31, 2010 6:14 PM   in reply to Neal Tobochnik
    When I try to import pictures from iPhoto '11 using the PSE 9 Organizer, I get the following message:
    There is no media to import from iPhoto
    I wonder if Adobe has not yet caught up with iPhoto '11 that came with recently introduced iLife '11. The iPhoto '09 catalog was converted in some way when I ran iPhoto '11 for the first time.
    Oct 31, 2010 9:19 PM   in reply to EmileGur
    I tried to import from iPhoto 11 and got the same message.  "There is no media to import from iPhoto".  My iPhoto Library has over 20000 photos in it and all is working fine in iPhoto.  PSE 9 organizer has not worked properly right from the start with respect to importing from from iPhoto.  Very disappointed in this program and have not heard anything about a fix to date.  Tried to import jpegs from a folder on my desktop and that did not work either.
    Nov 22, 2010 2:10 PM   in reply to jcazakoff
    I am getting this same message - I can not import my iPhoto Library into PSE 9 Organizer!  I have iPhoto 11 (version 9.1).  Any suggestions?
    Nov 22, 2010 2:53 PM   in reply to Ashwana
    Just export the photos you want to import from iphoto, put them where you want to keep them, then use File>Get Folders to import them. I would strongly suggest making a test catalog first and trying it for a while to see how well it suits you. If it works as you wish, then you can export/import more photos.
    Nov 22, 2010 3:45 PM   in reply to Barbara B.
    I'll give that a try - Thank You!
    Nov 22, 2010 5:30 PM   in reply to Ashwana
    Excuse me for getting into this as I abandoned iPhoto for Lightroom and PSE 8 some time ago but I don't see anyone bringing up the fact that Bridge, which is the "organizer" in reality, is just a data base and doesn't actually "import" images .. just points to them on the HD.  Before, when PSE was used only as an editor the file went directly to PSE and not to Bridge.   For those of us using a Mac the package structure of iPhoto isn't compatible without changing to the originals for the "organizer" to work, I THINK.  After all, iPhoto is an organizer, just different since it went to the packages ..This is why Aperture works so well with iPhoto.
    Now, before the world descends in wrath of anger .. I am not a nerd not particualr qualified other than through the agonies of trying to do what seemed intuitive only to find that the kids that develop this stuff have a different sense of "intuitive.:"
    So my intention is to try to be helpful and hope everyone finds the answer to their particuar problem.. I have AppleCare on all my machines and my iPad just to avoid this sort of thing eventually after I have messed around for a week or so.
    ed
    Nov 22, 2010 5:38 PM   in reply to n781lc
    Actually, Bridge no longer has anything to do with it. In PSE 9, Adobe ported the windows organizer into the mac version, so it's different from previous versions.
    Nov 23, 2010 1:30 PM   in reply to Barbara B.
    Barbara, not meaning to be Smart ... but "A rose by any other name is.."
    The organizer in the PSE 8 for Windows or the PSE 9 in both has the same characteristics regardless of what it is called.   They are both only data bases, as is the Catalog in Lightroom or Bridge in Phtoshop.
    It is THIS that I was questioning as to how iPhoto with its package system can work with any of them without first exporting as "originals."
    Has anyone checked with AppleCare or Adobe?  So far the topic is one on one of folks with the same problem or answere from folks, like me, without the problem.  But, I did run into it when I first started moving my iPhoto library to Lightroom
1 2 Previous Next
Actions
