as3 image load position
Sep 29, 2010 1:38 AM
q1)where do i set screen dimensions?
q2)how can i set the images position on screen without using the imageLoaded function because I need to display many images and dont want to create  this imageLoaded for every image.
package
    import flash.display.Sprite;
    public class atest1 extends Sprite
        import flash.display.Bitmap;
        import flash.display.Loader;
        import flash.events.Event;
        import flash.net.URLRequest;
        public function atest1()
            var loader:Loader = new Loader;
            loader.contentLoaderInfo.addEventListener(Event.COMPLETE, imageLoaded);
            loader.load(new URLRequest("ladybug.png"));
            //loader.x=200;
            //loader.y=100;
        private function imageLoaded(event:Event):void
            var image:Bitmap = new Bitmap(event.target.content.bitmapData);
            addChild(image);
            //image.x=200;
            //image.y=10;
var li:atest1= new atest1 ()
    Sep 29, 2010 1:57 AM   in reply to jagguy999
    You can use a double loop  and increase
    x and y positions for every loader.
    Sep 29, 2010 3:35 AM   in reply to jagguy999
    here is an example (with just one loop):
    var array:Array=["url1","url2","url3"]; // u should fill that array somehow with more data...
    var wid:Number=150;
    var hei:Number=100;
    var x_counter:int=0;
    var y_counter:int=0;
    var columns:int=4;
    function loaderFunc():void{
    for (var i:Number = 0; i < array.length; i++){
    var thumb_url = array[i].toString();
    var thumb_loader = new Loader();
    thumb_loader.load(new URLRequest(thumb_url));
    thumb_loader.x = (wid+10)*x_counter;
    thumb_loader.y = (hei+10)*y_counter;
    addChild(thumb_loader);
    if (x_counter+1 < columns){
    x_counter++;
    } else {
    x_counter = 0;
    y_counter++;
    Sep 29, 2010 4:05 AM   in reply to Hakan KIRIK
    An easier way is using paramters in the constructors but it doesnt work??
    why does this code fail to load anything without an error?
    package
    import flash.text.*;
    private var myy:int;
    private var myx:int;
    private var txt1:TextField = new TextField();
    public function atest1(x:int,y:int)
    myx=x;
    myy=y;
    loader.load(
    txt1.text =
    "Text1";
    addChild(txt1);
    image.x=myx;
    image.y=myy;
    addChild(image);
    var
    li:atest1= new atest1(10,200); //doesnt work
    Sep 29, 2010 4:21 AM   in reply to jagguy99
    Scene 1, Layer 'Layer 1', Frame 1, Line 1    1198: Attributes are not allowed on package definition.
    Scene 1, Layer 'Layer 1', Frame 1, Line 2    1084: Syntax error: expecting identifier before mult.
    Scene 1, Layer 'Layer 1', Frame 1, Line 4    1037: Packages cannot be nested.
    Scene 1, Layer 'Layer 1', Frame 1, Line 6    1084: Syntax error: expecting identifier before mult.
    Scene 1, Layer 'Layer 1', Frame 1, Line 9    1071: Syntax error: expected a definition keyword (such as function) after attribute *, not public.
    Scene 1, Layer 'Layer 1', Frame 1, Line 9    1084: Syntax error: expecting rightbrace before leftbrace.
    Scene 1, Layer 'Layer 1', Frame 1, Line 50    1071: Syntax error: expected a definition keyword (such as function) after attribute *, not private.
    Sep 29, 2010 4:24 AM   in reply to jagguy99
    You will need again a loop if you wanna use more than one image (and calculate each time x and y positions)
    Sep 29, 2010 4:32 AM   in reply to Hakan KIRIK
    I thought AS3 was OOP?
    I cant pass paramters in constructors so I need to pass them when an imge is loaded .
    If I need to load 3 images how do i do this in as3 without constructors????
    var li:atest1= new atest1("img1");
    var li:atest1= new atest1("img2");
    var li:atest1= new atest1("img3");
    Sep 29, 2010 5:04 AM   in reply to jagguy99
    it works.
    You need to use:
    var li:atest1= new atest1(10,200);
    addChild(li);
    Sep 29, 2010 5:10 AM   in reply to Hakan KIRIK
    Sep 29, 2010 5:16 AM   in reply to Hakan KIRIK
    no it doesnt work.
    Here is my whole code and I get1 error with addchild
    package
    SWF(backgroundColor="blue", width="400",height="300")]
    SWF(backgroundColor="0x00ff00", width="400",height="300")]
    private var img1:String;
    public function atest1(myimage:String)
    img1=myimage;
    myx=100;
    myy=100;
    loader.load(
    new URLRequest(img1));
    image.x=myx;
    image.y=myy;
    addChild(image);
    var li:atest1= new atest1("ladybug.png");
    var addChild(li);
    Sep 29, 2010 6:01 AM   in reply to jagguy99
    it works.
    Please download my example (fla+as) and test it.
    Sep 29, 2010 6:15 AM   in reply to Hakan KIRIK
    I have flashbuilder and
    my code has changed a little since then as you can see.
    Could you try my current code where I want to load a file by passing the filename in the constructor?
    Might be flashbuilder is no good.
    Sep 29, 2010 6:43 AM   in reply to jagguy999
    I did it before:
    codes in fla file:
    var aa:atest1=new atest1(33,44);
    addChild(aa);
    The .as file is in the Rar file and with Flashbuilder you can open it.
