I'm currently working on a really simple Parameterized TestCase. I'm using flexunit 4.0-rc1 and flexmojos 3.5.0.
When I do 'mvn clean test' I get the following error:
<testsuite errors="0" failures="1" name="com.finams.bnpflexlib.utils.StringUtilsTest" tests="1" time="0">
<testcase name="initializationError" time="0">
<failure message="Custom runner class org.flexunit.runners.Parameterized cannot be instantiated" type="com.finams.bnpflexlib.utils.StringUtilsTest">Error: Custom runner class org.flexunit.runners.Parameterized cannot be instantiated
at org.flexunit.internals.runners::InitializationError()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\internals\runners\InitializationError.as:50]
at org.flexunit.internals.builders::MetaDataBuilder/createInitializationError()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\internals\builders\MetaDataBuilder.as:209]
at org.flexunit.internals.builders::MetaDataBuilder/buildWithSecondSignature()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\internals\builders\MetaDataBuilder.as:179]
at org.flexunit.internals.builders::MetaDataBuilder/buildRunner()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\internals\builders\MetaDataBuilder.as:146]
at org.flexunit.internals.builders::MetaDataBuilder/runnerForClass()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\internals\builders\MetaDataBuilder.as:115]
at org.flexunit.runners.model::RunnerBuilderBase/safeRunnerForClass()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\runners\model\RunnerBuilderBase.as:63]
at org.flexunit.internals.builders::AllDefaultPossibilitiesBuilder/runnerForClass()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\internals\builders\AllDefaultPossibilitiesBuilder.as:106]
at org.flexunit.runners.model::RunnerBuilderBase/localRunners()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\runners\model\RunnerBuilderBase.as:119]
at org.flexunit.runners.model::RunnerBuilderBase/runners()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\runners\model\RunnerBuilderBase.as:87]
at org.flexunit.runners::Suite()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\runners\Suite.as:170]
at org.flexunit.runner::Request$/classes()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\runner\Request.as:201]
at Function/http://adobe.com/AS3/2006/builtin::apply()
at org.flexunit.runner::FlexUnitCore/runClasses()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\runner\FlexUnitCore.as:191]
at org.flexunit.runner::FlexUnitCore/run()[C:\Users\dmoore\Documents\_Production\Flex Unit 4\GIT\FlexUnit4\src\org\flexunit\runner\FlexUnitCore.as:171]
at org.sonatype.flexmojos.unitestingsupport.flexunit4::FlexUnit4Listener/run()[/home/nexus/flexmojos/trunk/target/checkout/flexmojos-testing/flexmojos-unittest-flexunit4/src/main/flex/org/sonatype/flexmojos/unitestingsupport/flexunit4/FlexUnit4Listener.as:42]
at org.sonatype.flexmojos.unitestingsupport::SocketReporter/runTests()[/home/nexus/flexmojos/trunk/target/checkout/flexmojos-testing/flexmojos-unittest-support/src/main/flex/org/sonatype/flexmojos/unitestingsupport/SocketReporter.as:243]
at org.sonatype.flexmojos.unitestingsupport::TestApplication/runTests()[/home/nexus/flexmojos/trunk/target/checkout/flexmojos-testing/flexmojos-unittest-support/src/main/flex/org/sonatype/flexmojos/unitestingsupport/TestApplication.as:40]
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/dispatchEvent()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\core\UIComponent.as:9298]
at mx.core::UIComponent/set initialized()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\core\UIComponent.as:1169]
at mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\managers\LayoutManager.as:718]
at mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\core\UIComponent.as:8628]
at mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\3.2.0\frameworks\projects\framework\src\mx\core\UIComponent.as:8568]</failure>
</testcase>
</testsuite>
Here is my TestCase (StringUtils is a simple class with a single method that converts numbers to strings, I did it to manage the specific case of a NaN parameter):
package com.finams.bnpflexlib.utils
import org.flexunit.Assert;
import org.flexunit.runners.Parameterized;
import com.finams.bnpflexlib.utils.StringUtils;
[RunWith("org.flexunit.runners.Parameterized")]
public class StringUtilsTest
[Datapoints]
static public var referential:Array = [
{numeric: 0, alpha: '0'},
{numeric: 1500, alpha: '1500'},
{numeric: 42, alpha: '42'},
{numeric: 15.15, alpha: '15.15'},
{numeric: 999, alpha: '999'},
{numeric: 17.0123456789, alpha: '17.0123456789'},
{numeric: 123456789, alpha: '123456789'},
{numeric: 0.00000000001, alpha: '0.00000000001'},
{numeric: -1, alpha: '-1'},
{numeric: 0.00000000015, alpha: '0.00000000015'},
{numeric: -1.01, alpha: '-1.01'},
{numeric: 0.12345678912, alpha: '0.12345678912'},
{numeric: -123456789, alpha: '-123456789'},
{numeric: 0.0, alpha: '0.0'},
{numeric: -1.123456789, alpha: '-1.123456789'},
{numeric: -0.0, alpha: '-0.0'}
public function StringUtilsTest() {}
[Test(description="Ensure that a NaN number will produce an empty string.")]
public function checkNbToStringWithNaNParameter():void
var result:String;
result = StringUtils.nbToString(NaN);
Assert.assertEquals(result, '');
[Ignore]
[Test(dataprovider="referential", description="Check conversion with a set of values")]
public function checkNumbers(nb:Number, ref:String):void
var result:String;
result = StringUtils.nbToString(nb);
Assert.assertEquals('Conversion fault: expected ' + ref + ', got ' + nb.toString(),
result,
'ref');
I wonder what's wrong...
Latest reply:
pdkn, Oct 7, 2010 10:07 AM
